Dear all,
I try to use npm lib "Bitgener" through Node-Red.
It's works but partially.
I use folowed script in function-node, but inner parameter "hri" just passed and ignoring by Node-red.
At same time if run this script through Node.js all works complitelly.
Please, give me solution or direction.
const bitgener = context.global.get('bitgener');
const ret = await bitgener({
data: 'DTR111222',
type: 'code93',
output: 'QA13.svg',
encoding: 'utf8',
crc: false,
padding: 25,
barWidth: 5,
barHeight: 150,
original1DSize: true,
addQuietZone: true,
color: '#000000',
opacity: 1,
bgColor: '#FFFFFF',
bgOpacity: 0.1,
hri: {
show: true,
fontFamily: 'Futura',
fontSize: 25,
marginTop: 20,
[{"id":"1e6c154b.1609bb","type":"tab","label":"FRONT","disabled":false,"info":""},{"id":"36d8f29a.04b69e","type":"function","z":"1e6c154b.1609bb","name":"svg","func":"const bitgener = context.global.get('bitgener');\n\n const ret = await bitgener({\n data: 'DTR111222',\n type: 'code93',\n output: 'QA13.svg',\n encoding: 'utf8',\n crc: false,\n padding: 25,\n barWidth: 5,\n barHeight: 150,\n original1DSize: true,\n addQuietZone: true,\n color: '#000000',\n opacity: 1,\n bgColor: '#FFFFFF',\n bgOpacity: 0.1,\n hri: {\n show: true,\n fontFamily: 'Futura',\n fontSize: 25,\n marginTop: 20,\n },\n });\n\n msg.payload = ret;\n ","outputs":1,"noerr":0,"initialize":"","finalize":"","x":630,"y":340,"wires":[[]]},{"id":"f6d8d50e.524768","type":"inject","z":"1e6c154b.1609bb","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":430,"y":340,"wires":[["36d8f29a.04b69e"]]}]
