Input boolean in HA
Hi it seem very easy but i got trouble how to find out how to do it
i have created an input_boolean in HA for a blink doorbell.
The only way i found how to intercept the doorbell press, is to create a routine in alexa to toggle it on
this part is working and i can see it in nodered
what i want to do is after receiving a change in nodered, is to turn back the input boolean to off
how can i do it
thanks
With an action node.
[{"id":"b2e9b9d4017d44dc","type":"api-call-service","z":"8e6ef4f6cbb13d83","name":"turn off boolean","server":"","version":7,"debugenabled":false,"action":"input_boolean.turn_off","floorId":[],"areaId":[],"deviceId":[],"entityId":["input_boolean.enable_loop"],"labelId":[],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"input_boolean","service":"turn_off","x":1120,"y":200,"wires":[[]]},{"id":"94fbe2fa9421b83b","type":"server-state-changed","z":"8e6ef4f6cbb13d83","name":"","server":"","version":6,"outputs":2,"exposeAsEntityConfig":"","entities":{"entity":["input_boolean.enable_loop"],"substring":[],"regex":[]},"outputInitially":false,"stateType":"str","ifState":"on","ifStateType":"str","ifStateOperator":"is","outputOnlyOnStateChange":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":790,"y":110,"wires":[["b2e9b9d4017d44dc","beae69bda6c05771"],[]]},{"id":"beae69bda6c05771","type":"debug","z":"8e6ef4f6cbb13d83","name":"do something","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1110,"y":110,"wires":[]}]
