Thank you,, I read the help text and configured the node, when i run the flow i get an http404error , pretty sure its a config and or permissions issue, with influxdb so i have to look into that, thank you for your help .
Which version of Influxdb are you using and how have you configured the influx server node?
Hi picklerick
off topic.
I’m interested in how are you getting the mqtt data from the morningstar ?
J
Influx 1.8.5
heres a copy of the influxdb node
"id": "5fbcc4def204bf4d",
"type": "influxdb out",
"z": "a8781b5b58ce12b5",
"influxdb": "4c0472df79128008",
"measurement": "voltage",
"precision": "",
"retentionPolicy": "",
"database": "sunsaver",
"precisionV18FluxV20": "ms",
"retentionPolicyV18Flux": "one_week",
"org": "organisation",
"bucket": "bucket",
"x": 640,
"y": 100,
"id": "4c0472df79128008",
"type": "influxdb",
"hostname": "192.168.1.11",
"port": "8086",
"protocol": "http",
"database": "database",
"name": "sunsaver",
"usetls": false,
"tls": "",
"influxdbVersion": "1.8-flux",
"url": "http://localhost:8086/sunsaver",
"rejectUnauthorized": false,
"credentials": {}
I have this C program running on a raspberry pi with a usb to meterbus connecting to the sunsaver.
heres the code
Can you connect to influx using the influx command line s/w?
Yes, I have created a Database sunsaver, and when i input
$ influx
it comes up
Connected to http://localhost:8086 version 1.8.5
InfluxDB shell version: 1.8.5
Can you access the sunsaver database via the command line?
Did you run the influx command line on the same computer that runs node red?
Don't specify flux in the influx node unless you want to use the flux query language, though that should not cause 404 error.
Yes i can access sunsaver database by the command line.
Yes the influx CL and node red are on the same computer
noted on the flux in the influx node, i will switch back to v1.x
here is a copy of the http section of the /etc/influxdb/influxdb.conf
[http]
Determines whether HTTP endpoint is enabled.
enabled = true
Determines whether the Flux query endpoint is enabled.
flux-enabled = false
Determines whether the Flux query logging is enabled.
flux-log-enabled = false
The bind address used by the HTTP service.
bind-address = ":8086"
Determines whether user authentication is enabled over HTTP/HTTPS.
auth-enabled = false
The default realm sent back when issuing a basic auth challenge.
realm = "InfluxDB"
Determines whether HTTP request logging is enabled.
log-enabled = true
Determines whether the HTTP write request logs should be suppressed when the log is enabled.
suppress-write-log = false
When HTTP request logging is enabled, this option specifies the path where
log entries should be written. If unspecified, the default is to write to stderr, which
intermingles HTTP logs with internal InfluxDB logging.
If influxd is unable to access the specified path, it will log an error and fall back to writing
the request log to stderr.
access-log-path = ""
Filters which requests should be logged. Each filter is of the pattern NNN, NNX, or NXX where N is
a number and X is a wildcard for any number. To filter all 5xx responses, use the string 5xx.
If multiple filters are used, then only one has to match. The default is to have no filters which
will cause every request to be printed.
access-log-status-filters =
Determines whether detailed write logging is enabled.
write-tracing = false
Determines whether the pprof endpoint is enabled. This endpoint is used for
troubleshooting and monitoring.
pprof-enabled = true
Enables authentication on pprof endpoints. Users will need admin permissions
to access the pprof endpoints when this setting is enabled. This setting has
no effect if either auth-enabled or pprof-enabled are set to false.
pprof-auth-enabled = false
Enables a pprof endpoint that binds to localhost:6060 immediately on startup.
This is only needed to debug startup issues.
debug-pprof-enabled = false
Enables authentication on the /ping, /metrics, and deprecated /status
endpoints. This setting has no effect if auth-enabled is set to false.
ping-auth-enabled = false
Determines whether HTTPS is enabled.
https-enabled = false
The SSL certificate to use when HTTPS is enabled.
https-certificate = "/etc/ssl/influxdb.pem"
Use a separate private key location.
https-private-key = ""
The JWT auth shared secret to validate requests using JSON web tokens.
shared-secret = ""
The default chunk size for result sets that should be chunked.
max-row-limit = 0
The maximum number of HTTP connections that may be open at once. New connections that
would exceed this limit are dropped. Setting this value to 0 disables the limit.
max-connection-limit = 0
Enable http service over unix domain socket
unix-socket-enabled = false
The path of the unix domain socket.
bind-socket = "/var/run/influxdb.sock"
The maximum size of a client request body, in bytes. Setting this value to 0 disables the limit.
max-body-size = 25000000
The maximum number of writes processed concurrently.
Setting this to 0 disables the limit.
max-concurrent-write-limit = 0
The maximum number of writes queued for processing.
max-enqueued-write-limit = 0
The maximum duration for a write to wait in the queue to be processed.
Setting this to 0 or setting max-concurrent-write-limit to 0 disables the limit.
enqueued-write-timeout = 0
# User supplied HTTP response headers
# [http.headers]
# X-Header-1 = "Header Value 1"
# X-Header-2 = "Header Value 2"
I dont understand enough about permissions to know if all this is ok. I tried changing the HTTPs to enabled yesterday but ended up failing to connect so i undid it and searched for more info
Also I note that you have specified an IP address there. Try it with version 1.x and localhost for the server.
Fantastic that worked,, I can now see in influx the database sunsaver with voltage and value.
Thank you very much. I really appreciate the time you have taken to help me with this.
Which change fixed it? The 1.x or the IP?
the change to 1.x
I never imagined that i needed to set it to 1.x as i have influxdb v1.8.5 so wrongly assumed that 1.8flux was the right one, now i have learnt that flux is a whole other ball game.
but i have also changed the ip to localhost as this will prevent any problems if the ip changes in future.
Thanks again
V1.8 can handle the old style query language but also the Flux query language (which is used in V2), so you have to tell it which one you want to use. You are not the first to be confused by the node setting, but it is not obvious how it could be improved.
