INSERT hexadecimal in SQLITE
I would like to add a hexidecimal key of an RFID tag like 3D433FF4A in SQlite
This is my code to create a table in Sqlite:
CREATE TABLE userlist_9(currentdate DATE, rfid TEXT, number INTEGER)
This is my code to add something to Sqlite:
var timestamp = Date.now();
    var rfid = global.get("rfid_key")
    var counter_locker = global.get("counter_locker")
    var newMsg = {
     "topic": "INSERT INTO userlist_9 VALUES ( " + timestamp + "," + rfid + ", " + counter_locker + ")"
    return newMsg;
With normal numbers it works fine, but with hexidecimal numbers I get the following error:
"Error: SQLITE_ERROR: unrecognized token: "2b334f""
Put a debug node showing complete message on the output of the function node and show us what it says.
[Edit] also what data types are the fields in the table?
17-12-2018 16:21:56node: 7466966b.94f148INSERT INTO userlist_9 VALUES ( 1545060116109,2b334f, 1) : msg : Object
object
topic: "INSERT INTO userlist_9 VALUES ( 1545060116109,2b334f, 1)"
_msgid: "12917f9e.727e4"!
Knipsel
With normal numeric value: No error
Knipsel
If you want to insert text into the table you need to wrap it in quotes.
INSERT INTO userlist_9 VALUES ( 1545060116109,"2b334f", 1)
It works when you try inserting a number because it can be parsed without the quotes around it.
I think you can (should?) use single quotes in sqlite, which makes it a bit simpler coding the string.
Thank you, it works
The user (RFID KEY) is added to the system if he does not appear in the database.
var rfid2 = ('"' + rfid + '"');
var newMsg = {
"topic": "INSERT INTO userlist_9 VALUES ( " + timestamp + "," + rfid2 + ", " + counter_locker + ")"
return newMsg;
