is that possible to let me insert the Access Token from others node? (e.g insert node)
If the creator of that config node supports that kind of feature, then yes. Otherwise, you're only option is to use an environment variable.
Environment variables are set at start time so it wouldn't be dynamic. But at least it would be set outside of the flow.
I will try on it
