Insert values from http request into SQLite
In my flow I have two http-request nodes that I use (every ten minutes) to get data from an API. I filter the request data through five functions and I end up with five values:
  1. temperature
  2. humidity
  3. pressure
  4. PM10
  5. PM2.5
Now I have to store these variables into a new sqlite db, calculate the mean for each one (every two hours) and save it in a different table of my sqlite db. Lastly, I have to plot the mean.
I spent the last two days trying to store the values in a db but I'm so stuck. Can you please help me?
My flow is:
        "id": "9bd4d4a2aefc85ef",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": "",
        "env": []
        "id": "b8b922afb22bcc64",
        "type": "http request",
        "z": "9bd4d4a2aefc85ef",
        "method": "GET",
        "ret": "obj",
        "paytoqs": "ignore",
        "url": "data.sensor.community/airrohr/v1/sensor/56402/",
        "tls": "",
        "persist": false,
        "proxy": "",
        "insecureHTTPParser": false,
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 490,
        "y": 180,
                "a7c40c9260131891",
                "648ae758795c8323",
                "52f3e8cec5632c1d"
        "id": "972baebc079e5737",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "600",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 130,
        "y": 180,
                "cab8ba5f69ac662f"
        "id": "cab8ba5f69ac662f",
        "type": "function",
        "name": "msg headers",
        "func": "\nmsg.headers = {};\nmsg.headers['content-type'] = 'application/json';\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 310,
        "y": 180,
                "b8b922afb22bcc64",
                "4ce3f8e1f62d363c"
        "id": "a7c40c9260131891",
        "type": "function",
        "name": "Temperature",
        "func": "var temp = {};\n\ntemp.payload = Number(msg.payload[0].sensordatavalues[0].value);\n\ntemp.topic = \"Temperature: \";\n\nreturn temp;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 690,
        "y": 120,
                "a93e0c9e08a7b2ce"
        "id": "648ae758795c8323",
        "type": "function",
        "name": "Pressure",
        "func": "var press = {};\n\npress.payload = Number(msg.payload[0].sensordatavalues[1].value);\npress.topic = \"Pressure: \";\n\nreturn press;\n",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 180,
                "80fda223a34e984b"
        "id": "52f3e8cec5632c1d",
        "type": "function",
        "name": "Humidity",
        "func": "var hum = {};\n\nhum.payload = Number(msg.payload[0].sensordatavalues[2].value);\n\nhum.topic = \"Humidity: \";\n\nreturn hum;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 240,
                "905a3adce3845d77"
        "id": "a93e0c9e08a7b2ce",
        "type": "ui_chart",
        "group": "5ad727043a9a374f",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "Temperature",
        "chartType": "line",
        "legend": "false",
        "xformat": "HH:mm:ss",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "-10",
        "ymax": "40",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 890,
        "y": 120,
        "id": "80fda223a34e984b",
        "type": "ui_chart",
        "group": "eee15df9519e1362",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "Pressure",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 880,
        "y": 180,
        "id": "905a3adce3845d77",
        "type": "ui_chart",
        "group": "a13ed6592e65c37d",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "Humidity",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 880,
        "y": 240,
        "id": "4ce3f8e1f62d363c",
        "method": "GET",
        "ret": "obj",
        "url": "data.sensor.community/airrohr/v1/sensor/56401/",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": [],
        "x": 490,
        "y": 380,
                "332f6ceab8a668af",
                "c9ba0952a84ce5d1"
        "id": "332f6ceab8a668af",
        "type": "function",
        "name": "PM10",
        "func": "var pm10 = {};\n\npm10.payload = Number(msg.payload[0].sensordatavalues[0].value);\n\npm10.topic = \"PM10: \";\n\nreturn pm10;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 690,
        "y": 340,
                "8355037b867a0a36"
        "id": "c9ba0952a84ce5d1",
        "type": "function",
        "name": "PM2.5",
        "func": "var pm25 = {};\n\npm25.payload = Number(msg.payload[0].sensordatavalues[1].value);\n\npm25.topic = \"PM25: \";\n\nreturn pm25;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 690,
        "y": 440,
                "f6aec9e2bde9e73e"
        "id": "8355037b867a0a36",
        "type": "ui_chart",
        "group": "bbd1bb4c3c1006dc",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "PM10",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 870,
        "y": 340,
        "id": "f6aec9e2bde9e73e",
        "type": "ui_chart",
        "group": "12ead6f68e7681c4",
        "order": 1,
        "width": 0,
        "height": 0,
        "label": "PM2.5",
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 870,
        "y": 440,
        "id": "5ad727043a9a374f",
        "type": "ui_group",
        "tab": "922b63a179737013",
        "order": 1,
        "disp": true,
        "width": "8",
        "collapse": false,
        "className": ""
        "id": "eee15df9519e1362",
        "type": "ui_group",
        "name": "Pressure",
        "order": 2,
        "disp": true,
        "width": "8",
        "collapse": false,
        "className": ""
        "id": "a13ed6592e65c37d",
        "type": "ui_group",
        "name": "Humidity",
        "order": 3,
        "disp": true,
        "width": "8",
        "collapse": false,
        "className": ""
        "id": "bbd1bb4c3c1006dc",
        "type": "ui_group",
        "name": "PM10",
        "tab": "f7ca8a44f3ea797f",
        "order": 4,
        "disp": true,
        "width": "10",
        "collapse": false,
        "className": ""
        "id": "12ead6f68e7681c4",
        "type": "ui_group",
        "name": "PM2.5",
        "order": 5,
        "disp": true,
        "width": "10",
        "collapse": false,
        "className": ""
        "id": "922b63a179737013",
        "type": "ui_tab",
        "name": "Sensor 56402: Temperature, Pressure, Humidity",
        "icon": "dashboard",
        "order": 2,
        "disabled": false,
        "hidden": false
        "id": "f7ca8a44f3ea797f",
        "type": "ui_tab",
        "name": "Sensor 56401: PM2.5, PM10",
        "order": 1,
        "disabled": false,
        "hidden": false
You flow doesn't show anything involved with inserting into a sqlite DB, all it shows is you sending data to the dashboard.
Show us the flows dealing with formatting and sending the data to the database.
That's the problem. I'm using the sqlite node but I can't get my task done. I'm almost ashamed to send what I did but I'll try again shortly and I'll post it here.
Make sure you carefully read the help text for the sqlite node, decide what query you need and work out what you need to pass to the node, then concentrate on constructing that data and feeding it into a debug node. Only when it looks right, connect it to the dB node.
Ok so I tried something and I managed to store the values in a database. The flow is:
        "method": "GET",
        "ret": "obj",
        "tls": "",
        "persist": false,
        "proxy": "",
        "authType": "",
        "senderr": false,
        "headers": [],
        "credentials": {},
        "x": 450,
        "y": 540,
                "a7c40c9260131891",
                "648ae758795c8323",
                "52f3e8cec5632c1d",
                "2e5959cfb6f251a1",
                "5a368daa726e13bf"
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "600",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 90,
        "y": 540,
                "cab8ba5f69ac662f"
        "type": "function",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 270,
        "y": 540,
                "b8b922afb22bcc64",
                "4ce3f8e1f62d363c"
        "type": "function",
        "func": "var temp = 0;\n\nfor (let i = 0; i < msg.payload.length; i++) {\n    temp = temp + Number(msg.payload[i].sensordatavalues[0].value);\n}\n\nvar tempe = {};\ntempe.payload = temp/msg.payload.length;\ntempe.topic = \"Temperature: \";\n\nreturn tempe;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 690,
        "y": 540,
                "a93e0c9e08a7b2ce"
        "type": "function",
        "name": "Pressure",
        "func": "var press = 0;\n\nfor (let i = 0; i < msg.payload.length; i++) {\n    press = press + Number(msg.payload[i].sensordatavalues[1].value);\n}\n\nvar pressu = {};\npressu.payload = press / msg.payload.length;\npressu.topic = \"Pressure: \";\n\nreturn pressu;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 600,
                "80fda223a34e984b"
        "type": "function",
        "name": "Humidity",
        "func": "var hum = 0;\n\nfor (let i = 0; i < msg.payload.length; i++) {\n    hum = hum + Number(msg.payload[i].sensordatavalues[2].value);\n}\n\nvar humi = {};\nhumi.payload = hum / msg.payload.length;\nhumi.topic = \"Humidity: \";\n\nreturn humi;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 700,
        "y": 660,
                "905a3adce3845d77"
        "type": "ui_chart",
        "order": 1,
        "width": 0,
        "height": 0,
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "-10",
        "ymax": "40",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 890,
        "y": 540,
        "type": "ui_chart",
        "order": 1,
        "width": 0,
        "height": 0,
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 880,
        "y": 600,
        "type": "ui_chart",
        "order": 1,
        "width": 0,
        "height": 0,
        "legend": "false",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "cutout": 0,
        "useUTC": false,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "className": "",
        "x": 880,
        "y": 660,
        "id": "b3fb7bc610ef2c8c",
        "type": "inject",
        "name": "Create DB",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "x": 140,
        "y": 40,
                "6c7b328f04d04678"
        "id": "6c7b328f04d04678",
        "type": "sqlite",
        "mydb": "c03247d7a40f32e6",
        "sqlquery": "msg.topic",
        "sql": "",
        "x": 550,
        "y": 40,
                "b06277d286ead2e8"
        "id": "b06277d286ead2e8",
        "type": "debug",
        "name": "debug 1",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 760,
        "y": 40,
        "id": "70db6777f07ec6b0",
        "type": "inject",
        "name": "Create Table (temp etc)",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "CREATE TABLE TEMP( TEMPERATURE NUMERIC, PRESSURE NUMERIC, HUMIDITY NUMERIC)",
        "payload": "",
        "x": 180,
        "y": 100,
                "f686c22b2a7d7ef2"
        "id": "f686c22b2a7d7ef2",
        "type": "sqlite",
        "sql": "",
        "x": 550,
        "y": 100,
                "71ff3c49529d2c8f"
        "id": "71ff3c49529d2c8f",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "topic",
        "targetType": "msg",
        "statusVal": "",
        "x": 760,
        "y": 100,
        "id": "2e5959cfb6f251a1",
        "type": "function",
        "name": "Add to table",
        "func": "//--------------------TEMPERATURE----------------------//\nvar temp = 0;\nfor (let i = 0; i < msg.payload.length; i++) {\n    temp = temp + Number(msg.payload[i].sensordatavalues[0].value);\n}\n\nvar tabletempe = {};\ntabletempe.payload = temp / msg.payload.length;\ntabletempe.topic = \"Temperature: \";\n\n//----------------------PRESSURE----------------------//\n\nvar press = 0;\nfor (let j = 0; j < msg.payload.length; j++) {\n    press = press + Number(msg.payload[j].sensordatavalues[1].value);\n}\n\nvar tablepressu = {};\ntablepressu.payload = press / msg.payload.length;\ntablepressu.topic = \"Pressure: \";\n\n//----------------------HUMIDITY---------------------//\n\nvar hum = 0;\nfor (let k = 0; k < msg.payload.length; k++) {\n    hum = hum + Number(msg.payload[k].sensordatavalues[2].value);\n}\n\nvar tablehumi = {};\ntablehumi.payload = hum / msg.payload.length;\ntablehumi.topic = \"Humidity: \";\n\n//----------------------MESSAGE---------------------//\n\nvar newMsg = {\n    \"topic\": \"INSERT INTO TEMP VALUES ( \" + tabletempe.payload + \", \" + tablepressu.payload + \", \" + tablehumi.payload + \")\"\n}\n\nreturn newMsg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 710,
        "y": 720,
                "048c143c6b197cc4"
        "id": "048c143c6b197cc4",
        "type": "sqlite",
        "sql": "",
        "x": 950,
        "y": 720,
                "00e7cfd146a07f16"
        "id": "5a368daa726e13bf",
        "type": "debug",
        "name": "debug 17",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "x": 680,
        "y": 480,
        "id": "00e7cfd146a07f16",
        "type": "debug",
        "name": "debug 18",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1180,
        "y": 720,
        "type": "ui_group",
        "order": 1,
        "disp": true,
        "width": "8",
        "collapse": false,
        "className": ""
        "type": "ui_group",
        "name": "Pressure",
        "order": 2,
        "disp": true,
        "width": "8",
        "collapse": false,
        "className": ""
        "type": "ui_group",
        "name": "Humidity",
        "order": 3,
        "disp": true,
        "width": "8",
        "collapse": false,
        "className": ""
        "id": "c03247d7a40f32e6",
        "type": "sqlitedb",
        "db": "CRETE_NEWNEW",
        "mode": "RWC"
        "type": "ui_tab",
        "order": 2,
        "disabled": false,
        "hidden": false
The problem is that now I have to get the values back from the database and write a function that will calculate the mean every two hours.
So you need to use a SELECT statement. here is a set of flows showing different SQLite statements that might help you out.
[{"id":"b996e9de.cd54c8","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"INSERT INTO hvac4(\n    ID,\n    UTC,\n    DateTime,\n    hp, \n    lp  \n    )\nVALUES\n    (1695,1583209921955,\"2020/03/02T20:32:01\",77.1,74.2),\n(1694,1583207096121,\"2020/03/02T19:44:56\",78.2,76.6),\n(1693,1583206453163,\"2020/03/02T19:34:13\",77.9,76.4),\n(1692,1583164232433,\"2020/03/02T07:50:32\",74,78.1),\n(1691,1583163932418,\"2020/03/02T07:45:32\",73.3,75.2),\n(1690,1583163632415,\"2020/03/02T07:40:32\",73.1,73.7),\n(1689,1583163332419,\"2020/03/02T07:35:32\",73.1,72),\n(1688,1583163032423,\"2020/03/02T07:30:32\",73,72.1),\n(1687,1583162732413,\"2020/03/02T07:25:32\",73.4,72.7),\n(1686,1583162432401,\"2020/03/02T07:20:32\",73.5,73.3),\n(1685,1583162132391,\"2020/03/02T07:15:32\",72.6,71),\n(1684,1583161832396,\"2020/03/02T07:10:32\",72.7,71.2),\n(1683,1583161532392,\"2020/03/02T07:05:32\",72.9,71.8),\n(1682,1583161232394,\"2020/03/02T07:00:32\",72.9,72.2),\n(1681,1583160932396,\"2020/03/02T06:55:32\",72.9,72),\n(1680,1583160632397,\"2020/03/02T06:50:32\",72.9,71.6),\n(1679,1583160332382,\"2020/03/02T06:45:32\",73.3,72.1),\n(1678,1583160032392,\"2020/03/02T06:40:32\",73.2,71.9),\n(1677,1583159732387,\"2020/03/02T06:35:32\",72.6,70.2),\n(1676,1583159432365,\"2020/03/02T06:30:32\",72.7,70.3),\n(1675,1583159132367,\"2020/03/02T06:25:32\",72.8,70.4),\n(1674,1583158832363,\"2020/03/02T06:20:32\",73,70.9),\n(1673,1583158532364,\"2020/03/02T06:15:32\",73.4,71.7),\n(1672,1583158232344,\"2020/03/02T06:10:32\",73.7,72.5),\n(1671,1583157932355,\"2020/03/02T06:05:32\",72.8,70.2),\n(1670,1583157632345,\"2020/03/02T06:00:32\",72.9,70.1),\n(1669,1583157332343,\"2020/03/02T05:55:32\",73,70.2),\n(1668,1583157032339,\"2020/03/02T05:50:32\",73.1,70.6),\n(1667,1583156732330,\"2020/03/02T05:45:32\",73.3,71.1),\n(1666,1583156432324,\"2020/03/02T05:40:32\",73.8,72),\n(1665,1583156132316,\"2020/03/02T05:35:32\",73.8,72.4),\n(1664,1583155832318,\"2020/03/02T05:30:32\",73,70.3),\n(1663,1583155532312,\"2020/03/02T05:25:32\",73.1,70.3),\n(1662,1583155232313,\"2020/03/02T05:20:32\",73.2,70.4),\n(1663,1582887743604,\"2020/02/28T03:02:23\",72.9,69.6)\n","output":"str","x":360,"y":100,"wires":[["25b23f04.053a1"]]}]
Can you please re-paste the JSON? I think that something might be missing
Whoops, I had to edit the flow to reduce the number of characters and then just selected the template instead of the complete flow :face_with_open_eyes_and_hand_over_mouth:
[{"id":"b54cfc20.fecb38","type":"tab","label":"Flow 1","disabled":false,"info":"","_mcu":{"mcu":false}},{"id":"5d644bc7.ff4e5c","type":"sqlite","z":"b54cfc20.fecb38","mydb":"b48607bf.623f88","sqlquery":"msg.topic","sql":"","name":"Sqlite","x":110,"y":140,"wires":[["f82e9731.4a16a"]]},{"id":"771a4816.0c4cd","type":"inject","z":"b54cfc20.fecb38","name":"Create Table","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":60,"wires":[["1f7f15b5.e2d6aa"]]},{"id":"f82e9731.4a16a","type":"debug","z":"b54cfc20.fecb38","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":110,"y":180,"wires":[]},{"id":"1f7f15b5.e2d6aa","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"CREATE TABLE hvac4(\n    ID INTEGER PRIMARY KEY AUTOINCREMENT, \n    UTC INTEGER,\n    DateTime TEXT,\n    hp NUMERIC, \n    lp NUMERIC \n)","output":"str","x":120,"y":100,"wires":[["5d644bc7.ff4e5c"]]},{"id":"25b23f04.053a1","type":"sqlite","z":"b54cfc20.fecb38","mydb":"b48607bf.623f88","sqlquery":"msg.topic","sql":"","name":"Sqlite","x":350,"y":140,"wires":[["16c71ea.b668961"]]},{"id":"56c189c6.5cab38","type":"inject","z":"b54cfc20.fecb38","name":"Insert multi rows","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":380,"y":60,"wires":[["b996e9de.cd54c8"]]},{"id":"16c71ea.b668961","type":"debug","z":"b54cfc20.fecb38","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":350,"y":180,"wires":[]},{"id":"b996e9de.cd54c8","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"INSERT INTO hvac4(\n    ID,\n    UTC,\n    DateTime,\n    hp, \n    lp  \n    )\nVALUES\n    (1695,1583209921955,\"2020/03/02T20:32:01\",77.1,74.2),\n(1694,1583207096121,\"2020/03/02T19:44:56\",78.2,76.6),\n(1693,1583206453163,\"2020/03/02T19:34:13\",77.9,76.4),\n(1692,1583164232433,\"2020/03/02T07:50:32\",74,78.1),\n(1691,1583163932418,\"2020/03/02T07:45:32\",73.3,75.2),\n(1690,1583163632415,\"2020/03/02T07:40:32\",73.1,73.7),\n(1689,1583163332419,\"2020/03/02T07:35:32\",73.1,72),\n(1688,1583163032423,\"2020/03/02T07:30:32\",73,72.1),\n(1687,1583162732413,\"2020/03/02T07:25:32\",73.4,72.7),\n(1686,1583162432401,\"2020/03/02T07:20:32\",73.5,73.3),\n(1685,1583162132391,\"2020/03/02T07:15:32\",72.6,71),\n(1684,1583161832396,\"2020/03/02T07:10:32\",72.7,71.2),\n(1683,1583161532392,\"2020/03/02T07:05:32\",72.9,71.8),\n(1682,1583161232394,\"2020/03/02T07:00:32\",72.9,72.2),\n(1681,1583160932396,\"2020/03/02T06:55:32\",72.9,72),\n(1680,1583160632397,\"2020/03/02T06:50:32\",72.9,71.6),\n(1679,1583160332382,\"2020/03/02T06:45:32\",73.3,72.1),\n(1678,1583160032392,\"2020/03/02T06:40:32\",73.2,71.9),\n(1677,1583159732387,\"2020/03/02T06:35:32\",72.6,70.2),\n(1676,1583159432365,\"2020/03/02T06:30:32\",72.7,70.3),\n(1675,1583159132367,\"2020/03/02T06:25:32\",72.8,70.4),\n(1674,1583158832363,\"2020/03/02T06:20:32\",73,70.9),\n(1673,1583158532364,\"2020/03/02T06:15:32\",73.4,71.7),\n(1672,1583158232344,\"2020/03/02T06:10:32\",73.7,72.5),\n(1671,1583157932355,\"2020/03/02T06:05:32\",72.8,70.2),\n(1672,1582887743604,\"2020/02/28T03:02:23\",72.9,69.6)\n","output":"str","x":360,"y":100,"wires":[["25b23f04.053a1"]]},{"id":"d58df386.29cda","type":"sqlite","z":"b54cfc20.fecb38","mydb":"b48607bf.623f88","sqlquery":"msg.topic","sql":"","name":"Sqlite","x":630,"y":140,"wires":[["79c33077.edf418"]]},{"id":"5959dc0c.ad3044","type":"inject","z":"b54cfc20.fecb38","name":"select count","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":650,"y":60,"wires":[["9bd539da.7d961"]]},{"id":"79c33077.edf418","type":"debug","z":"b54cfc20.fecb38","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":630,"y":180,"wires":[]},{"id":"9bd539da.7d961","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"SELECT COUNT(*) from hvac4","output":"str","x":640,"y":100,"wires":[["d58df386.29cda"]]},{"id":"b519b9b3.50ea8","type":"catch","z":"b54cfc20.fecb38","name":"","scope":null,"uncaught":false,"x":400,"y":240,"wires":[["4191d6d0.a0cd38"]]},{"id":"4191d6d0.a0cd38","type":"debug","z":"b54cfc20.fecb38","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":570,"y":240,"wires":[]},{"id":"bbe03555.3275f8","type":"sqlite","z":"b54cfc20.fecb38","mydb":"b48607bf.623f88","sqlquery":"msg.topic","sql":"","name":"Sqlite","x":610,"y":440,"wires":[["32019594.6436a2"]]},{"id":"5a533e19.2c36a8","type":"inject","z":"b54cfc20.fecb38","name":"Insert customer data","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":420,"wires":[["dd91b199.b445f8"]]},{"id":"32019594.6436a2","type":"debug","z":"b54cfc20.fecb38","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":750,"y":440,"wires":[]},{"id":"dd91b199.b445f8","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"INSERT INTO customers\n\t(CustomerID,CustomerName,ContactName,Address,City,PostalCode,Country)\nVALUES\n\t(1,\"Alfreds Futterkiste\",\"Maria Anders\",\"Obere Str. 57\",\"Berlin\",\"12209\",\"Germany\"),\n\t(2,\"Ana Trujillo Emparedados y helados\",\"Ana Trujillo\",\"Avda. de la Constitución 2222\",\"México D.F.\",\"05021\",\"Mexico\"),\n\t(3,\"Antonio Moreno Taquería\",\"Antonio Moreno\",\"Mataderos 2312\",\"México D.F.\",\"05023\",\"Mexico\"),\n\t(4,\"Around the Horn\",\"Thomas Hardy\",\"120 Hanover Sq.\",\"London\",\"WA1 1DP\",\"UK\"),\n\t(5,\"Berglunds snabbköp\",\"Christina Berglund\",\"Berguvsvägen 8\",\"Luleå\",\"S-958 22\",\"Sweden\"),\n\t(6,\"Blauer See Delikatessen\",\"Hanna Moos\",\"Forsterstr. 57\",\"Mannheim\",\"68306\",\"Germany\"),\n\t(7,\"Blondel père et fils\",\"Frédérique Citeaux\",\"24, place Kléber\",\"Strasbourg\",\"67000\",\"France\"),\n\t(8,\"Bólido Comidas preparadas\",\"Martín Sommer\",\"C/ Araquil, 67\",\"Madrid\",\"28023\",\"Spain\"),\n\t(9,\"Bon app'\",\"Laurence Lebihans\",\"12, rue des Bouchers\",\"Marseille\",\"13008\",\"France\"),\n\t(10,\"Wolski\",\"Zbyszek\",\"ul. Filtrowa 68\",\"Walla\",\"01-012\",\"Poland\" )\n\t","output":"str","x":380,"y":420,"wires":[["bbe03555.3275f8"]]},{"id":"724fcf56.87c3b","type":"sqlite","z":"b54cfc20.fecb38","mydb":"b48607bf.623f88","sqlquery":"msg.topic","sql":"","name":"Sqlite","x":850,"y":140,"wires":[["3c34509f.0411d8"]]},{"id":"50f1479e.da212","type":"inject","z":"b54cfc20.fecb38","name":"delete data","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":860,"y":60,"wires":[["6fbe4803.d0e52"]]},{"id":"3c34509f.0411d8","type":"debug","z":"b54cfc20.fecb38","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":850,"y":180,"wires":[]},{"id":"6fbe4803.d0e52","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"DELETE FROM hvac4","output":"str","x":860,"y":100,"wires":[["724fcf56.87c3b"]]},{"id":"d98abcd1.951c48","type":"comment","z":"b54cfc20.fecb38","name":"Customers table - sql examples","info":"","x":170,"y":320,"wires":[]},{"id":"654a2d93.1a9494","type":"inject","z":"b54cfc20.fecb38","name":"Create CUSTOMERS Table","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":380,"wires":[["adf54a0f.2e44f8"]]},{"id":"adf54a0f.2e44f8","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"CREATE TABLE customers (\n    CustomerID INTEGER PRIMARY KEY AUTOINCREMENT,\n    CustomerName TEXT,\n    ContactName TEXT,\n    Address TEXT,\n    City TEXT,\n    PostalCode TEXT,\n    Country TEXT\n)","output":"str","x":380,"y":380,"wires":[["bbe03555.3275f8"]]},{"id":"12851785.ee1568","type":"inject","z":"b54cfc20.fecb38","name":"select count","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":130,"y":460,"wires":[["c5f03349.753ed8"]]},{"id":"c5f03349.753ed8","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"SELECT COUNT(*) from customers","output":"str","x":380,"y":460,"wires":[["bbe03555.3275f8"]]},{"id":"abdfe668.954998","type":"inject","z":"b54cfc20.fecb38","name":"select count by country","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":160,"y":500,"wires":[["21c0f11.f808a8e"]]},{"id":"21c0f11.f808a8e","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"SELECT Country, COUNT(Country) from customers\nGROUP BY Country","output":"str","x":380,"y":500,"wires":[["bbe03555.3275f8"]]},{"id":"1dbb655b.5f83b3","type":"debug","z":"b54cfc20.fecb38","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":610,"y":360,"wires":[]},{"id":"637eca86.f8d084","type":"inject","z":"b54cfc20.fecb38","name":"select * by country","repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":150,"y":540,"wires":[["fd213018.5a542"]]},{"id":"fd213018.5a542","type":"template","z":"b54cfc20.fecb38","name":"","field":"topic","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"SELECT * from customers\nORDER BY Country","output":"str","x":380,"y":540,"wires":[["bbe03555.3275f8"]]},{"id":"b48607bf.623f88","type":"sqlitedb","db":"/Users/Paul/databases/hvac4.db","mode":"RWC"}]
You can get sqlite to sum the values for you SQLite SUM: Return The Sum value in A Set of Values
[Edit Or indeed to work out the mean SQLite AVG: Calculate The Average Value In a Set
