Install extra node in docker
mmm something went wrong...
When i did the forst install like you says, it works
Only when i restart my container for the other instal for a node .. there is the same error:
2024-12-28T11:49:25.203Z Install : node-red-contrib-tasmota 1.0.0
2024-12-28T11:49:24.542Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-contrib-tasmota@1.0.0
2024-12-28T11:49:28.075Z [err] npm error code EACCES
2024-12-28T11:49:28.076Z [err] npm error syscall open
2024-12-28T11:49:28.076Z [err] npm error path /data/package-lock.json
2024-12-28T11:49:28.076Z [err] npm error errno -13
2024-12-28T11:49:28.080Z [err] npm error Error: EACCES: permission denied, open '/data/package-lock.json'
2024-12-28T11:49:28.080Z [err] npm error     at async open (node:internal/fs/promises:639:25)
2024-12-28T11:49:28.080Z [err] npm error     at async writeFile (node:internal/fs/promises:1212:14)
2024-12-28T11:49:28.080Z [err] npm error     at async Promise.all (index 0)
2024-12-28T11:49:28.080Z [err] npm error     at async [saveIdealTree] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:1526:7)
2024-12-28T11:49:28.080Z [err] npm error     at async Arborist.reify (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:148:5)
2024-12-28T11:49:28.080Z [err] npm error     at async Install.exec (/usr/local/lib/node_modules/npm/lib/commands/install.js:150:5)
2024-12-28T11:49:28.080Z [err] npm error     at async Npm.exec (/usr/local/lib/node_modules/npm/lib/npm.js:207:9)
2024-12-28T11:49:28.080Z [err] npm error     at async module.exports (/usr/local/lib/node_modules/npm/lib/cli/entry.js:74:5) {
2024-12-28T11:49:28.080Z [err] npm error   errno: -13,
2024-12-28T11:49:28.080Z [err] npm error   code: 'EACCES',
2024-12-28T11:49:28.080Z [err] npm error   syscall: 'open',
2024-12-28T11:49:28.080Z [err] npm error   path: '/data/package-lock.json'
2024-12-28T11:49:28.080Z [err] npm error }
2024-12-28T11:49:28.081Z [err] npm error
2024-12-28T11:49:28.081Z [err] npm error The operation was rejected by your operating system.
2024-12-28T11:49:28.081Z [err] npm error It is likely you do not have the permissions to access this file as the current user
2024-12-28T11:49:28.081Z [err] npm error If you believe this might be a permissions issue, please double-check the
2024-12-28T11:49:28.081Z [err] npm error permissions of the file and its containing directories, or try running
2024-12-28T11:49:28.081Z [err] npm error the command again as root/Administrator.
2024-12-28T11:49:28.083Z [err] npm error A complete log of this run can be found in: /data/.npm/_logs/2024-12-28T11_49_24_829Z-debug-0.log
2024-12-28T11:49:28.115Z rc=243
Can you please show again ls -la of /var/lib/docker/volumes/nodered_node-red-data/_data
root@odroidn2:~#  cd /var/lib/docker/volumes/nodered_node-red-data/_data
root@odroidn2:/var/lib/docker/volumes/nodered_node-red-data/_data# ls -la
totaal 2000
drwxrwxr-x   5 pi   root   4096 28 dec 12:43 .
drwx-----x   3 root root   4096  1 jun  2024 ..
-rw-r--r--   1 pi   pi    50815 28 dec 12:43 .config.nodes.json
-rw-r--r--   1 pi   pi    53463 28 dec 12:43 .config.nodes.json.backup
-rw-r--r--   1 pi   pi      133  1 jun  2024 .config.runtime.json
-rw-r--r--   1 pi   pi       95  1 jun  2024 .config.runtime.json.backup
-rw-r--r--   1 pi   pi      703 28 dec 12:43 .config.users.json
-rw-r--r--   1 pi   pi      701 28 dec 12:43 .config.users.json.backup
-rw-r--r--   1 pi   pi      211 27 dec 16:53 flows_cred.json
-rw-r--r--   1 pi   pi      135 27 dec 16:53 .flows_cred.json.backup
-rw-r--r--   1 pi   pi   839457 28 dec 11:09 flows.json
-rw-r--r--   1 pi   pi   843399 28 dec 11:09 .flows.json.backup
drwxr-xr-x   3 pi   pi     4096  1 jun  2024 lib
drwxr-xr-x 178 pi   pi    12288 28 dec 12:49 node_modules
drwxr-xr-x   4 pi   pi     4096  1 jun  2024 .npm
-rw-r--r--   1 pi   pi     1113 28 dec 12:49 package.json
-rw-r--r--   1 root root 169584 27 mrt  2024 package-lock.json
-rw-r--r--   1 pi   pi    22614 27 jul  2023 settings.js
this is still assigned to user root, hence not accessible.
Stop the container.
chown 1000:1000 package-lock.json
ls -la
again.
root@odroidn2:~# sudo /var/lib/docker/volumes/nodered_node-red-data/_data
sudo: /var/lib/docker/volumes/nodered_node-red-data/_data: opdracht niet gevonden
root@odroidn2:/var/lib/docker/volumes/nodered_node-red-data/_data# chown 1000:1000 package-lock.json
totaal 2000
-rw-r--r--   1 pi   pi   169584 27 mrt  2024 package-lock.json
Start container and try to install tasmota again
remove a node was working fine...
Only when install:
2024-12-28T12:17:53.242Z Install : node-red-contrib-tasmotas 2.0.3
2024-12-28T12:17:52.566Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-contrib-tasmotas@2.0.3
2024-12-28T12:17:56.646Z [err] npm warn deprecated har-validator@5.1.5: this library is no longer supported
2024-12-28T12:17:56.737Z [err] npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
2024-12-28T12:17:56.755Z [err] npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
2024-12-28T12:17:56.978Z [err] npm error code EACCES
2024-12-28T12:17:56.979Z [err] npm error syscall symlink
2024-12-28T12:17:56.979Z [err] npm error path ../sshpk/bin/sshpk-conv
2024-12-28T12:17:56.979Z [err] npm error dest /data/node_modules/.bin/sshpk-conv
2024-12-28T12:17:56.980Z [err] npm error errno -13
2024-12-28T12:17:56.985Z [err] npm error Error: EACCES: permission denied, symlink '../sshpk/bin/sshpk-conv' -> '/data/node_modules/.bin/sshpk-conv'
2024-12-28T12:17:56.985Z [err] npm error     at async symlink (node:internal/fs/promises:1000:10)
2024-12-28T12:17:56.985Z [err] npm error     at async Promise.all (index 0)
2024-12-28T12:17:56.985Z [err] npm error     at async #createBinLinks (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:394:5)
2024-12-28T12:17:56.985Z [err] npm error     at async Promise.allSettled (index 0)
2024-12-28T12:17:56.985Z [err] npm error     at async #linkAllBins (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:375:5)
2024-12-28T12:17:56.985Z [err] npm error     at async #build (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:160:7)
2024-12-28T12:17:56.985Z [err] npm error     at async Arborist.rebuild (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:62:5)
2024-12-28T12:17:56.985Z [err] npm error     at async [reifyPackages] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:325:11)
2024-12-28T12:17:56.985Z [err] npm error     at async Arborist.reify (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5) {
2024-12-28T12:17:56.985Z [err] npm error   errno: -13,
2024-12-28T12:17:56.985Z [err] npm error   code: 'EACCES',
2024-12-28T12:17:56.985Z [err] npm error   syscall: 'symlink',
2024-12-28T12:17:56.985Z [err] npm error   path: '../sshpk/bin/sshpk-conv',
2024-12-28T12:17:56.985Z [err] npm error   dest: '/data/node_modules/.bin/sshpk-conv'
2024-12-28T12:17:56.985Z [err] npm error }
2024-12-28T12:17:56.986Z [err] npm error
2024-12-28T12:17:56.986Z [err] npm error The operation was rejected by your operating system.
2024-12-28T12:17:56.986Z [err] npm error It is likely you do not have the permissions to access this file as the current user
2024-12-28T12:17:56.986Z [err] npm error If you believe this might be a permissions issue, please double-check the
2024-12-28T12:17:56.986Z [err] npm error permissions of the file and its containing directories, or try running
2024-12-28T12:17:56.986Z [err] npm error the command again as root/Administrator.
2024-12-28T12:17:56.992Z [err] npm error A complete log of this run can be found in: /data/.npm/_logs/2024-1
You tried to install tasmotas 2.0.3 now as opposed to tasmota 1.0.0 before. Does latter work?
My final guess is, that your persistent data needed a complete re-assignment. Hence I would stop the container and simply cd back to /var/lib/docker/volumes/nodered_node-red-data/_data as root and then run
chown -R 1000:1000 *
ALL files in /var/lib/docker/volumes/nodered_node-red-data/_data should then be accessible. I did so in the past, when I run into problems with file permissions as well. However, do it at your own risk!
mm there a lot of files in that area.. so i am not the hero to doe that.. With a risk my home automation is not working.,,, And my waf is going down the freeze.... Looking futher for other solutions...
Also this is not wokring...
2024-12-30T08:50:57.834Z Install : node-red-contrib-tasmotas 2.0.3
2024-12-30T08:50:57.018Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict node-red-contrib-tasmotas@2.0.3
2024-12-30T08:51:01.364Z [err] npm warn deprecated har-validator@5.1.5: this library is no longer supported
2024-12-30T08:51:01.526Z [err] npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
2024-12-30T08:51:01.558Z [err] npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
2024-12-30T08:51:01.888Z [err] npm error code EACCES
2024-12-30T08:51:01.888Z [err] npm error syscall symlink
2024-12-30T08:51:01.888Z [err] npm error path ../sshpk/bin/sshpk-conv
2024-12-30T08:51:01.888Z [err] npm error dest /data/node_modules/.bin/sshpk-conv
2024-12-30T08:51:01.890Z [err] npm error errno -13
2024-12-30T08:51:01.894Z [err] npm error Error: EACCES: permission denied, symlink '../sshpk/bin/sshpk-conv' -> '/data/node_modules/.bin/sshpk-conv'
2024-12-30T08:51:01.894Z [err] npm error     at async symlink (node:internal/fs/promises:1000:10)
2024-12-30T08:51:01.894Z [err] npm error     at async Promise.all (index 0)
2024-12-30T08:51:01.894Z [err] npm error     at async #createBinLinks (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:394:5)
2024-12-30T08:51:01.894Z [err] npm error     at async Promise.allSettled (index 0)
2024-12-30T08:51:01.894Z [err] npm error     at async #linkAllBins (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:375:5)
2024-12-30T08:51:01.894Z [err] npm error     at async #build (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:160:7)
2024-12-30T08:51:01.894Z [err] npm error     at async Arborist.rebuild (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/rebuild.js:62:5)
2024-12-30T08:51:01.894Z [err] npm error     at async [reifyPackages] (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:325:11)
2024-12-30T08:51:01.894Z [err] npm error     at async Arborist.reify (/usr/local/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:142:5) {
2024-12-30T08:51:01.894Z [err] npm error   errno: -13,
2024-12-30T08:51:01.894Z [err] npm error   code: 'EACCES',
2024-12-30T08:51:01.894Z [err] npm error   syscall: 'symlink',
2024-12-30T08:51:01.894Z [err] npm error   path: '../sshpk/bin/sshpk-conv',
2024-12-30T08:51:01.894Z [err] npm error   dest: '/data/node_modules/.bin/sshpk-conv'
2024-12-30T08:51:01.894Z [err] npm error }
2024-12-30T08:51:01.895Z [err] npm error
2024-12-30T08:51:01.895Z [err] npm error The operation was rejected by your operating system.
2024-12-30T08:51:01.895Z [err] npm error It is likely you do not have the permissions to access this file as the current user
2024-12-30T08:51:01.895Z [err] npm error If you believe this might be a permissions issue, please double-check the
2024-12-30T08:51:01.895Z [err] npm error permissions of the file and its containing directories, or try running
2024-12-30T08:51:01.895Z [err] npm error the command again as root/Administrator.
2024-12-30T08:51:01.904Z [err] npm error A complete log of this run can be found in: /data/.npm/_logs/2024-12-30T08_50_57_277Z-debug-0.log
2024-12-30T08:51:01.933Z rc=243
If you choose to backup your docker volume, as per my suggestion earlier in this thread, it shouldn't be a problem. But I do understand your concern :slight_smile:
my wife kill me hahaaha When my home automation is not working any more.. And specialy with holidays:-) [ perhaps after the holidays i try ]
If you have not got a backup, what will you do when the SD card dies?
