Install additional node to docker
I'm running node-red with docker-compose and try to preinstall a node to my environment.
I followed the example from the documentation and added
WORKDIR /usr/src/node-red
RUN npm install node-red-node-smooth
at the end of the Dockerfile.
But the smooth node does not show up in the node palette, after I create the container.
When I install the node manually with
docker exec -it nodered /bin/bash
cd /data
and restart nodered, anything works like expected and smooth shows up in the palette.
Does anyone have an idea, what I should change to make the preinstalling work?
