i use docker-compose.yaml file from github main branch https://github.com/FlowFuse/docker-compose/
i use below command to start
DOMAIN=192.100.0.101.sslip.io docker-compose -p flowfuse up
in .env i set
TLS_ENABLED=true
TLS_CERTIFICATE= <self signed>
TLS_KEY=<self signed>
when i browse https://forge.192.100.0.101.sslip.io , i get error 500 Internal Server Error, nginx/1.27.0 , http is no issue. may i know how to fix this? i'm ok to use self signed cert as my ip is not publicly accessible.
in docker logs for nginx
nginx-1 | nginx.1 | localhost 127.0.0.1 - - [11/Apr/2025:03:17:55 +0000] "HEAD / HTTP/1.1" 503 0 "-" "curl/7.88.1" "-"
nginx-1 | nginx.1 | forge.192.100.0.101.sslip.io 172.18.0.1 - - [11/Apr/2025:03:17:56 +0000] "GET / HTTP/2.0" 500 579 "-" "Mozilla/5.0 (<privacy hidden>) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/135.0.0.0 Safari/537.36" "-"
nginx-1 | nginx.1 | forge.192.100.0.101.sslip.io 172.18.0.1 - - [11/Apr/2025:03:17:56 +0000] "GET /favicon.ico HTTP/2.0" 500 579 "https://forge.192.100.0.101.sslip.io/" "Mozilla/5.0 (<privacy hidden>) <privacy hidden>/537.36 (KHTML, like Gecko) Chrome/135.0.0.0 Safari/537.36" "-"
do i need to set env DOCKER_DRIVER_PRIVATE_CA_PATH when using self signed TLS ?
