Install two Node Red on same device/server
Hello Everyone,
Is it possible to install Node red two times on the same device so that I can use two different Node Red Systems on the same device or server?
For the moment I use Node red on a virtual machine. Now I would like to use two Node red Systems on a virtual machine, this would make it easier and even clearer to work with the dashboard.
Thanks for your help!
Yannick
Yes.
Look at the command line parameters - you can start multiple instances each with own port number, folder & flows.
No need to install multiple copies.
Search for node-red multiple instances
thank you, I dont found this Topic before...
