Hi, I know this should be a simple problem to solve, but is driving me crazy. I have installed node-red plenty of times, some problem to solve some times, but ok. Now I'm stuck here. It's a fresch buster legacy installation on a pi 3.
During the installation I always get problem at this point.
if you see it names the log /root/.npm/_logs/2023-02-21T08_54_04_699Z-debug-0.log. but this path doesn't exist.
Regarding internet connectivity, it shouldn't be a problem. I can update, do everything. Moreover I'm not behind a proxy.
I have tryed to clean, purge, reinstall, even with apt install. But nothing
test@test:~ $ npm config list
; "user" config from /home/test/.npmrc
registry = "http://registry.npmjs.org/"
update-notifier = false
; node bin location = /usr/bin/node
; node version = v16.19.1
; npm local prefix = /home/test
; npm version = 8.19.3
; cwd = /home/test
; HOME = /home/test
; Run `npm config ls -l` to show all defaults.
test@test:~ $ npm list -g
/usr/lib
├── corepack@0.15.1
├── node-red@3.0.2
└── npm@8.19.3
test@test:~ $ cd .node-red
test@test:~/.node-red $ npm install node-red-simple-gate
npm ERR! code E404
npm ERR! 404 Not Found - GET https://registry.npmjs.org/node-red-simple-gate - Not found
npm ERR! 404
npm ERR! 404 'node-red-simple-gate@*' is not in this registry.
npm ERR! 404
npm ERR! 404 Note that you can also install from a
npm ERR! 404 tarball, folder, http url, or git url.
npm ERR! /home/test/.npm/_logs/2023-02-21T10_31_37_536Z-debug-0.log
test@test:~/.node-red $ npm install node-red-contrib-simple-gate
npm notice Beginning October 4, 2021, all connections to the npm registry - including for package installation - must use TLS 1.2 or higher. You are currently using plaintext http to connect. Please visit the GitHub blog for more information: https://github.blog/2021-08-23-npm-registry-deprecating-tls-1-0-tls-1-1/
added 1 package in 1m
12 packages are looking for funding
run `npm fund` for details
test@test:~ $
I notice that node red 3.0.2 is in fact installed. Does it run correctly?
I did see in the log earlier that the install did not replace the service file as it has been manually modified. Given that you said this is a fresh buster install, it is surprising that it has been modified.
test@test:~ $ node-red
-bash: node-red: comando non trovato
test@test:~ $ node-red-start
Node-RED is not yet fully installed. Please re-run the install script again manually.
then retry node-red-start
test@test:~ $
Yes, it's a fresh installation ,but with this problem I've tryed several way to fix it before opening the topic. I don't understand which service file you are referring to.
It is in the second image you posted. This is an example of the problem with images, I can't copy/paste the text.
I also note that you installed it as the user iot, but you are now trying to run it as user test.
Why did you install buster rather than the current version?
In fact I haven't got any idea what the problem with npm is.
In your position I think I would start again, with a different, known good quality SD card, install the latest Pi OS, run apt update, apt full-upgrade and try again with the script. This time if it doesn't work come straight back and show us the install log.
Yes I'll do it. I'm using buster (legacy version) for standard policy. It is a kind of LTE. It is strange because this is the first time.that happens.
Thinking better, a main difference with the previous installation is that I'm doing it remotly. But I don't think it could be due to this, doesn't it?
I see it. I noticed it but I didn't got it meaning. I'll delete it and make another test
Thanks, you read my mind. I was just looking how t install with a previous nodejs version. I'm sure I did it with the previous one on a same buster legacy, the 16.19.0
# systemd service file to start Node-RED
[Unit]
Description=Node-RED graphical event wiring tool
Wants=network.target
Documentation=http://nodered.org/docs/hardware/raspberrypi.html
[Service]
Type=simple
# Run as normal pi user - change to the user name you wish to run Node-RED as
User=pi
Group=pi
WorkingDirectory=/home/pi
Environment="NODE_OPTIONS=--max_old_space_size=256"
# define an optional environment file in Node-RED's user directory to set custom vari$
EnvironmentFile=-/.node-red/EnvironmentFile
# uncomment and edit next line if you need an http proxy
#Environment="HTTP_PROXY=my.httpproxy.server.address"
# uncomment the next line for a more verbose log output
#Environment="NODE_RED_OPTIONS=-v"
# uncomment next line if you need to wait for time sync before starting
#ExecStartPre=/bin/bash -c '/bin/journalctl -b -u systemd-timesyncd | /bin/grep -q "s$
ExecStart=/usr/bin/env node-red-pi $NODE_OPTIONS $NODE_RED_OPTIONS
#ExecStart=/usr/bin/env node $NODE_OPTIONS red.js $NODE_RED_OPTIONS
# Use SIGINT to stop
KillSignal=SIGINT
# Auto restart on crash
Restart=on-failure
RestartSec=20
# Tag things in the log
SyslogIdentifier=Node-RED
#StandardOutput=syslog
[Install]
WantedBy=multi-user.target
Yes, I tested with several users, including pi. Always the same result
Probably the message was because you were running the script as a different user. If you start again make sure you run the command as the user you want to run node red as a service.
