I need to get nodered to work with home assistant and get this error:
SSL has been enabled using the ‘ssl’ option,
[20:53:10] FATAL: this requires a SSL certificate file which is
[20:53:10] FATAL: configured using the ‘certfile’ option in the
[20:53:10] FATAL: add-on configuration.
[20:53:10] FATAL:
[20:53:10] FATAL: Unfortunately, the file specified in the
[20:53:10] FATAL: ‘certfile’ option does not exists.
[20:53:10] FATAL:
[20:53:10] FATAL: Please ensure the certificate file exists and
[20:53:10] FATAL: is placed in the ‘/ssl/’ directory.
[20:53:10] FATAL:
[20:53:10] FATAL: In case you don’t have SSL yet, consider getting
[20:53:10] FATAL: a SSL certificate or setting the ‘ssl’ option
[20:53:10] FATAL: to ‘false’ in case you are not planning on using
[20:53:10] FATAL: SSL with this add-on.
[20:53:10] FATAL:
[20:53:10] FATAL: Check the add-on manual for more information.
Not sure how to change the ssl certificate. New to this so any help would be greatly appreciated.
