I recently updated to the version that allows modules to be added from the function node. I am trying to test this out.
I have the module installed.
Is there documentation available explaining what to do next? I can't find a 'hello world' type guide on how to use the function node to interact with module?
My first thought was to use global variables. I would assign what I want module the module to use to a global variable, named according to what the library looks for? Then run it by injecting a blank message into the function node containing the module. The output would be visible as a global variable too. Is this right?
I honestly appreciate any help understanding this, or any resource/documentation I can learn from.
Because each npm module has thier own way of exporting functionality.
If you want a simple example, then try it out. Add cowsay and call its say function as instructed in the cowsay readme
You should get...
Hi, thanks for helping me out and sorry for the slow response. Managing hobbies on top of a work and a household is like.. crazy. And I dont even have kids...
I will download cowsay and test it out.
I'm struggling with the basic level of understanding though. It sounds really simple at its core i think?
- get a module
- identify a whatever function we want to use.
- identify what information the function requires.
- Return the payload or however its assigned.
Im on mobile so i might have missed the formatting but is the gist of this correct?
ModuleName.function(necessary input){option 1: value, option 2: value, options 3: value}`
And was your function node something like this then?
msg.payload = cowsay.say('hi');
return msg.payload
And with options:
msg.payload = cowsay.say("hi"){
Text: "i'm a module",
e : "oO",
T : "U "
return msg.payload;
That would not work as the object is outside of the function parenthesis and you must always return the msg object (not the payload)
Pretty much - so long as you really mean...
- Identify a module that does what I need
- Find it in npm
- copy it's name as listed in NPM
- Add the module as named in the function setup tab modules list
- identify whatever function(s) we want to use & the parameters they require, then call it/them as prescribed by the modules instruction/docs
- Assign the result to
msg.payload
- Return the
msg
Bottom line, just give it a go
