Intervals and Function
I need help to turn on a buzzer at different intervals according to the variation in the input, I am currently simulating with a slider, but at the time of varying the interval is not deactivated, I attach the flow and function block
var msgHigh = {payload : 1};
var msgLow = {payload : 0};
var dato = {payload : 0};
var dato2 = {payload : 0};
function high(){
        node.send(msgHigh);
function low(){
        setTimeout(function(){
            node.send(msgLow);
        },1000);
if(msg.payload=="0"){
        clearInterval(dato);
        clearInterval(dato2);
}else if(msg.payload=="1"){
        dato = {payload : setInterval(high,2000)};
        dato2 = {payload : setInterval(low,2000)};
}else if(msg.payload=="2"){
}else if(msg.payload=="3"){
WhatsApp Image 2021-07-29 at 12.53.38
You need to save the timeout to a context variable and recover it each time the function node is triggered by an incoming msg. By saving a reference, you can cancel and recreate it easily.
Could you show me how?
Hmm, my live example uses a custom node.js module which would be hard to unpick.
Do you know how to get and set a context variable in a function node? If not start with the node-red docs and learn how to do that first.
When you have that, create a simple setInterval to output some text to the debug panel. and then add an if statement so that if the msg.payload = "kill", cancel the interval. Maybe something like this (untested):
let myInterval = context.get('myInterval') || null
if ( msg.payload === 'kill' ) {
   clearInterval(myInterval)
} else if ( msg.payload === 'create' ) {
   myInterval = setInterval( function() {
      node.warn('PING')
   }, 5000)
context.set('myInterval', myInterval)
