Hi, I would like to modularise my Node-RED applications - as each are on a separate upgrade path.
I would like to have several Node-RED Docker Containers, on the same host, all containers running Node-RED with their own set of flows, that then uses the --link Docker definition to send msg.objects to one another.
I could do this via mqtt, but was wondering if I cannot exploit intra-container comminications?
...not quite sure as such a thing exists.
I am under the impression, that a docker instance is a "tight" as a virtual machine, when it comes to i/o interchange.
So using a form of docker networking would have to be the basic layer and concept.
Using internal docker DNS should enable you not to only use mqtt but http or other TCP/UDP based transport methods.
...or even a database...
Have you seen this: https://flows.nodered.org/node/node-red-contrib-redlink ..looks interesting
Dis see that, but forgot, thank you for the advice!
