Hi All,
I'm getting this on a template node with CSS code:
It's set up as "added to site section", so there's no place for a group. Code seems to work. How do I figure this out?
Russ
Hi All,
Russ
Do following:
Change the Template type to "widget in the group", then Deploy, and then change Template type back to "Added to side head section".
Awesome, thanks! If I had another 100 years
I might learn half the stuff you know...
Russ
Edit: Speaking of CSS, is there a way to comment inside the script tags? I inadvertently broke my node this morning by adding //comment. The editor didn't show/say anything wrong, but it sure didn't work!
/*like this*/
Thanks you kind sir!
Russ
