My server has now crashed from this flow:
[{"id":"beb2fc2f.9da3b","type":"tcp in","z":"53f246d7.f619f8","name":"","server":"client","host":"xxx","port":"xxx","datamode":"stream","datatype":"utf8","newline":"","topic":"WaveBuoy","base64":false,"x":150,"y":280,"wires":[["d0a41ac5.9f11e8"]]},{"id":"d0a41ac5.9f11e8","type":"function","z":"53f246d7.f619f8","name":"","func":"var parts = msg.payload.split(\",\");\n\nmsg.payload = {\n \"deviceID\": \"WaveBuoy\",\n \"SAK\": \"XXX=\",\n \"Protocol\": \"mqtt\",\n \"Data\": {\n \"Heave\": msg.payload[4],\n \"Northings\": msg.payload[5] \n //\"Eastings\": msg.payload[6] \n }\n};\n\nmsg.payload = JSON.stringify(msg.payload);\n\nreturn msg;","outputs":1,"noerr":0,"x":530,"y":280,"wires":[["a40d774a.bf8648","4073cbfd.cf8d14"]]},{"id":"a40d774a.bf8648","type":"azureiothub","z":"53f246d7.f619f8","name":"Azure IoT Hub","protocol":"mqtt","x":780,"y":120,"wires":[[]]}]
The error is as follows:
27 Jun 15:30:37 - [error] [azureiothub:Azure IoT Hub] TypeError: Cannot read property 'toString' of undefined
at Mqtt.publish (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\node_modules\azure-iot-mqtt-base\lib\mqtt.js:131:57)
at Mqtt.sendEvent (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\node_modules\azure-iot-device-mqtt\lib\mqtt.js:71:14)
at Client.sendEvent (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\node_modules\azure-iot-device\lib\client.js:271:19)
at sendData (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\azureiothub.js:38:16)
at sendMessageToIoTHub (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\azureiothub.js:65:13)
at AzureIoTHubNode.<anonymous> (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\azureiothub.js:159:13)
at emitOne (events.js:116:13)
at AzureIoTHubNode.emit (events.js:211:7)
at AzureIoTHubNode.Node.receive (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red\red\runtime\nodes\Node.js:215:14)
at FunctionNode.Node.send (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red\red\runtime\nodes\Node.js:202:14)
at sendResults (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red\nodes\core\core\80-function.js:52:18)
at FunctionNode.<anonymous> (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red\nodes\core\core\80-function.js:221:21)
at FunctionNode.emit (events.js:211:7)
at FunctionNode.Node.receive (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red\red\runtime\nodes\Node.js:215:14)
at TcpIn.Node.send (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red\red\runtime\nodes\Node.js:137:22)
at Socket.<anonymous> (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red\nodes\core\io\31-tcpin.js:76:34)
at Socket.emit (events.js:211:7)
at addChunk (_stream_readable.js:263:12)
at readableAddChunk (_stream_readable.js:250:11)
at Socket.Readable.push (_stream_readable.js:208:10)
27 Jun 15:30:38 - [error] [azureiothub:Azure IoT Hub] Could not connect: Connection refused: Not authorized
27 Jun 15:30:38 - [info] [azureiothub:Azure IoT Hub] Connected to Azure IoT Hub.
27 Jun 15:30:38 - [red] Uncaught Exception:
27 Jun 15:30:38 - TypeError: Cannot read property 'on' of undefined
at C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\azureiothub.js:89:24
at C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\node_modules\azure-iot-device\lib\client.js:240:9
at Mqtt.<anonymous> (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\node_modules\azure-iot-device-mqtt\lib\mqtt.js:45:17)
at MqttClient.errCallback (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\node_modules\azure-iot-mqtt-base\lib\mqtt.js:75:7)
at emitNone (events.js:111:20)
at MqttClient.emit (events.js:208:7)
at TLSSocket.f (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\node_modules\once\once.js:25:25)
at TLSSocket.onend (C:\Users\admin\AppData\Roaming\npm\node_modules\node-red-contrib-azure-iot-hub\node_modules\end-of-stream\index.js:35:27)
at TLSSocket.emit (events.js:208:7)
at endReadableNT (_stream_readable.js:1064:12)
at _combinedTickCallback (internal/process/next_tick.js:138:11)
at process._tickCallback (internal/process/next_tick.js:180:9)
