If it is the same user, there is no difference. User is pi?
How did you instal NR? Using the script?
What version of NR
How is the exec node configured? Show image like this below
I still believe in some kind of access rights issue
yes. user is pi. yes installed using script. this is the exec node configuration - command used is ffmpeg -rtsp_transport tcp -i rtsp://xxx:xxx@192.168.1.236:554//h264Preview_01_main -r 10 -t 10 -vcodec copy -acodec copy /home/pi/video.mp4 -y
you mean try using http link? but ur command doesnt have time in it. i only want to record a fragment of it for example 60 sec only. already tried the spawn mode. same result
