<html>
<style>
video {
border: 1px solid #ddd;
border-radius: 8px;
padding: 2px;
width: 400px;
height:300px;
.norm {
border:4px outset;
color:white;
background:#FBF14D;
</style>
<script>
//Make scope available in functions
var theScope = scope;
// Watch the payload and update corresponding picture
(function(scope) {
//alert(msg);
inMessage(msg.payload);
})(scope);
function inMessage(event) {
if (event.match('hello')) {
alert(event);
function SendMessage(eventname, el){
theScope.send({payload:eventname});
return false;
</script>
<body>
<center>
<table>
<tr><!-- Row 1 -->
<td style="text-align: center"><video width="405px" controls autoplay><source id="CAM31" src="/dooropen.mp4" type="video/mp4"></video></td>
</tr>
</table>
<br>
<br>
<table width="100%" border="1">
</table>
</center>
</body>
</html>
Your code works fine here when I try with my 10 sec recording
What browser are you using? It has to support playing mp4
What happens if you try to play the movie directly?
http://your.ip:1880/dooropen.mp4
If I try here with http://192.168.0.243:1880/dooropen.mp4 it works as expected
i use google chrome. it said Cannot GET /dooropen.mp4 error
You have a path problem...I think
Try to change in settings.js
httpStatic: '/home/pi',
Restart NR
It has to work with http://your.ip:1880/dooropen.mp4
You have to try to figure out, otherwise no meaning trying
already did what u suggested. same error
already works. thank you very much. sorry for my weakness
Everything fine now?
yes. thank you very much
OK, fine, happy to hear! Now you can explore further and continue your project!
So in this exercise we looked at how to use the ui template node and html code in the dashboard. This allows us to use all nice options available in html and javascript to design a web ui we like
Another option for the dashboard, mention by Paul @zenofmud is to use the ui media node (node-red-contrib-ui-media)
Here is a simple flow that will show your recorded video on the dashboard
Is a matter of taste what you prefer. My personal choice was to use ui template node to give me most possible options in terms of design etc
[{"id":"3c184a96.327466","type":"ui_media","z":"dbfb0dbc.c8a91","group":"4246a880.b5ddb8","name":"","width":"8","height":"6","order":26,"category":"","file":"","layout":"adjust","showcontrols":true,"loop":true,"onstart":true,"muted":true,"scope":"local","tooltip":"","x":910,"y":2790,"wires":[[]]},{"id":"167c69d3.74ad56","type":"change","z":"dbfb0dbc.c8a91","name":"","rules":[{"t":"set","p":"mimetype","pt":"msg","to":"video/mp4","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":2790,"wires":[["3c184a96.327466"]]},{"id":"771443b1.9c392c","type":"file in","z":"dbfb0dbc.c8a91","name":"","filename":"/home/pi/dooropen.mp4","format":"","chunk":false,"sendError":false,"encoding":"none","x":450,"y":2790,"wires":[["167c69d3.74ad56"]]},{"id":"8fa5e49a.4877a8","type":"inject","z":"dbfb0dbc.c8a91","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":230,"y":2790,"wires":[["771443b1.9c392c"]]},{"id":"4246a880.b5ddb8","type":"ui_group","name":"Video Test","tab":"e338d88b.0fb2b8","order":15,"disp":false,"width":"23","collapse":false},{"id":"e338d88b.0fb2b8","type":"ui_tab","name":"Video Test","icon":"dashboard","disabled":false,"hidden":false}]
