Is it possible to configure a single Inject node to connect and subscribe to an MQTT broker using Dynamic Connections?
I am getting to grips with the concept of Dynamic MQTT connections and related Pub/Sub. However I am curious as to whether it would be possible to use the same Inject Node to do the following:
  1. Force connect to an MQTT broker
  2. Subscribe to a desired topic
I tried doing the following within an inject node:
  • msg.action set to connect
  • msg.broker set to {"broker": "internal-mqtt-broker", "port":1883, "force":true}
  • msg.action set to subscribe
  • msg.topic set to $SYS/#
Upon deploying the flow, the inject node is not able to connect to the Broker.
Logs:
node-red              | 20 Apr 19:55:55 - [info] Server now running at http://127.0.0.1:1880/
node-red              | 20 Apr 19:55:55 - [info] Starting flows
node-red              | 20 Apr 19:55:55 - [info] Started flows
node-red              | 20 Apr 20:00:47 - [info] Stopping flows
node-red              | 20 Apr 20:00:47 - [info] Stopped flows
node-red              | 20 Apr 20:00:47 - [info] Starting flows
node-red              | 20 Apr 20:00:47 - [info] Started flows
Flow Diagram:
Inject Node Properties
Whereas upon removing the subscribe action and topic from the Inject node, I am able to connect to the broker and subscribe to a topic via a separate node.
Would there be some way to merge the connection + subscription actions of the node into one node?
Kind of - use a delay to cause 2 messages, the 1st one to connect, the 2nd to subscribe
chrome_d0H8etCnwR
Why your example doesnt work...
... This is easily visible by adding a debug node AFTER the inject (debug node set to "show complete message")
