Is it possible to enable fractional zoom levels (e.g. 2.5) for node-red-contrib-web-worldmap ?
I can specify a fractional zoom level but it doesn't take the fractional part into account. When a fractional part is specified it seems to be rounding it to the nearest integer.
Not currently no. I guess it could be enabled but we have to pick a step level. And it then lets the browser scale the tiles so the quality may not be brilliant
I have used the leaflet library before with a fractional step level (e.g 0.1) and that works fine and also looks good.
I would suggest to keep the default step level (= 1) but make this configurable through the node configuration.
Ok - will let it accept fractional values.
Thanks a lot. After some consideration is zoom level 3 not that bad for me. New Zealand is no longer visible on my screen with zoom level 3 but that is acceptable for my use case.
sounds like a good excuse to buy a bigger screen
(now in v2.10.0 - spinner is the same but you can type in whatever you want)
version 2.10.0 indeed makes it now possible to specify a fractional zoom level.
Thanks a lot.
Phew - hopefully NZ now back in the world
Indeed NZ is back on the map
