Is possible to drag and drop a marker and then save the new coord position?
I'm quite new to the world of node red and I have a project where I don't really know where to start, and I need some advice, currently my project includes a reading part from an mqtt server, of several "buoys" of which it shows the location on a world map. I would like to be able to drag and drop these buoys and have as a result a coordinate to return to the mqtt server, to then be processed by another program
here is my actual flow, i know, it's messy, and it probably doesn't work if the server or the py program aren't up :confused:
        "id": "f6f2187d.f17ca8",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info":
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": ""
        "id": "dff0a33eddfabb82",
        "type": "mqtt in",
        "z": "f6f2187d.f17ca8",
        "name": "mqtt moquitto",
        "topic": "mavlink_data_10.8.0.55/json",
        "qos": "2",
        "datatype": "auto-detect",
        "broker": "b66b9508dd319e39",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 690,
        "y": 140,
                "cceba5e11f8002d8"
        "id": "28b6af694511feba",
        "type": "comment",
        "name": "json from py scrpit .55",
        "info": "",
        "x": 720,
        "y": 100,
        "id": "aa370cdd0f7f75d0",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "nomeprova",
        "payloadType": "str",
        "x": 160,
        "y": 500,
                "afa709ea469d3081"
        "id": "4eaab1b2536db849",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "boa",
        "x": 150,
        "y": 540,
                "24d6f91998f64cc3"
        "id": "afa709ea469d3081",
        "type": "mqtt out",
        "name": "mqttt out name",
        "topic": "datiFromNodeRed/name",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 380,
        "y": 500,
        "id": "24d6f91998f64cc3",
        "type": "mqtt out",
        "topic": "datiFromNodeRed/tipoIcona",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 380,
        "y": 540,
        "id": "8abc5c3869b88330",
        "type": "mqtt out",
        "topic": "heartBeat/redNodeBeat",
        "qos": "",
        "retain": "",
        "respTopic": "",
        "contentType": "",
        "userProps": "",
        "correl": "",
        "expiry": "",
        "x": 470,
        "y": 220,
        "id": "0aa91f91f6a6eea4",
        "type": "inject",
        "props": [
                "p": "payload.heartbeat",
                "v": "alive",
                "vt": "str"
                "p": "topic",
                "vt": "str"
        "repeat": "3",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "heartBeat",
        "x": 250,
        "y": 180,
                "8abc5c3869b88330"
        "id": "2e1e788158631905",
        "type": "comment",
        "name": "inject to mqtt",
        "info": "",
        "x": 150,
        "y": 460,
        "id": "15431a6fc8164dbe",
        "type": "comment",
        "name": "heart beat refresh py code",
        "info": "",
        "x": 290,
        "y": 140,
        "id": "86953eeeb7351ae8",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "terminate",
        "x": 260,
        "y": 220,
                "8abc5c3869b88330"
        "id": "72bb8a399974e091",
        "type": "mqtt in",
        "topic": "mavlink_data_10.8.0.54/json",
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 690,
        "y": 240,
                "bf5722e7779dea0d"
        "id": "10da5394b0bc5843",
        "type": "comment",
        "name": "json from py scrpit .54",
        "info": "",
        "x": 720,
        "y": 200,
        "id": "357f844a1d39d6a8",
        "type": "mqtt in",
        "topic": "mavlink_data_10.8.0.53/json",
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 690,
        "y": 340,
                "329b7874ddc94e8e"
        "id": "7eca921ad8cc344a",
        "type": "comment",
        "name": "json from py scrpit .53",
        "info": "",
        "x": 720,
        "y": 300,
        "id": "0652516107900e82",
        "type": "mqtt in",
        "topic": "mavlink_data_10.8.0.52/json",
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 690,
        "y": 440,
                "dd910edfc8b2fe75"
        "id": "e918dec245d69e78",
        "type": "comment",
        "name": "json from py scrpit .52",
        "info": "",
        "x": 720,
        "y": 400,
        "id": "09767dfd01360ce4",
        "type": "mqtt in",
        "topic": "mavlink_data_10.8.0.50/json",
        "qos": "2",
        "nl": false,
        "rap": true,
        "rh": 0,
        "inputs": 0,
        "x": 690,
        "y": 540,
                "0393d95c9d305015"
        "id": "7eb080477792a051",
        "type": "comment",
        "name": "json from py scrpit .50",
        "info": "",
        "x": 720,
        "y": 500,
        "id": "cceba5e11f8002d8",
        "type": "link out",
        "name": "json .55",
        "mode": "link",
        "links": [
            "6a8b5ca9e7d44816"
        "x": 795,
        "y": 160,
        "id": "bf5722e7779dea0d",
        "type": "link out",
        "name": "json .54",
        "mode": "link",
        "links": [
            "914a4edf01860285"
        "x": 795,
        "y": 260,
        "id": "329b7874ddc94e8e",
        "type": "link out",
        "name": "json .53",
        "mode": "link",
        "links": [
            "573612281c915aee"
        "x": 795,
        "y": 360,
        "id": "dd910edfc8b2fe75",
        "type": "link out",
        "name": "json .52",
        "mode": "link",
        "links": [
            "f5dcad1e83c54b2a"
        "x": 795,
        "y": 460,
        "id": "0393d95c9d305015",
        "type": "link out",
        "name": "json .50",
        "mode": "link",
        "links": [
            "8705087cb84eca16"
        "x": 795,
        "y": 560,
        "id": "cfd3bbc2a0aca344",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "CLEAR",
        "payload": "",
        "payloadType": "date",
        "x": 730,
        "y": 40,
        "id": "067d5b4a048b79c0",
        "type": "ui_worldmap",
        "group": "7a70e5c28d8ec144",
        "order": 0,
        "width": 0,
        "height": 0,
        "lat": "",
        "lon": "",
        "zoom": "",
        "layer": "OSMC",
        "cluster": "",
        "maxage": "",
        "usermenu": "hide",
        "layers": "hide",
        "panit": "false",
        "panlock": "false",
        "zoomlock": "false",
        "hiderightclick": "true",
        "coords": "none",
        "showgrid": "false",
        "showruler": "false",
        "allowFileDrop": "false",
        "path": "/worldmap",
        "overlist": "DR,CO,RA,DN,HM",
        "maplist": "OSMG,OSMC,EsriC,EsriS,EsriT,EsriDG,UKOS",
        "mapname": "",
        "mapurl": "",
        "mapopt": "",
        "mapwms": false,
        "x": 1500,
        "y": 480,
        "id": "573612281c915aee",
        "type": "link in",
        "name": "world map",
        "links": [
            "329b7874ddc94e8e"
        "x": 1085,
        "y": 380,
                "e9de89b6e75d70e0"
        "id": "e9de89b6e75d70e0",
        "type": "function",
        "name": "function 1",
        "func": "const lat = msg.payload.GPS_RAW_INT.lat;\nconst lon = msg.payload.GPS_RAW_INT.lon;\nconst hdg = msg.payload.GLOBAL_POSITION_INT.hdg\nconst vel = msg.payload.GPS_RAW_INT.vel\n\nmsg.payload = {\n    lat: lat / Math.pow(10, 7),\n    lon: lon / Math.pow(10, 7),\n    hdg: hdg / Math.pow(10, 2),\n    vel: vel,\n    name: \"default name 53\",\n    icon: \"ship\"\n};\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1180,
        "y": 380,
                "757a9596885d71cc"
        "id": "72f84c9f274b5875",
        "type": "comment",
        "name": "map .53",
        "info": "",
        "x": 1160,
        "y": 340,
        "id": "914a4edf01860285",
        "type": "link in",
        "links": [
            "bf5722e7779dea0d"
        "x": 1085,
        "y": 280,
                "b371467e59067587"
        "id": "b371467e59067587",
        "type": "function",
        "name": "function 2",
        "func": "const lat = msg.payload.GPS_RAW_INT.lat;\nconst lon = msg.payload.GPS_RAW_INT.lon;\nconst hdg = msg.payload.GLOBAL_POSITION_INT.hdg\nconst vel = msg.payload.GPS_RAW_INT.vel\n\nmsg.payload = {\n    lat: lat / Math.pow(10, 7),\n    lon: lon / Math.pow(10, 7),\n    hdg: hdg / Math.pow(10, 2),\n    vel: vel,\n    name: \"default name 54\",\n    icon: \"ship\"\n};\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1180,
        "y": 280,
                "757a9596885d71cc"
        "id": "f6b8ed4f34568b85",
        "type": "comment",
        "name": "map .54",
        "info": "",
        "x": 1160,
        "y": 240,
        "id": "6a8b5ca9e7d44816",
        "type": "link in",
        "links": [
            "cceba5e11f8002d8"
        "x": 1085,
        "y": 180,
                "a81efc8cea338596"
        "id": "a81efc8cea338596",
        "type": "function",
        "name": "function 3",
        "func": "const lat = msg.payload.GPS_RAW_INT.lat;\nconst lon = msg.payload.GPS_RAW_INT.lon;\nconst hdg = msg.payload.GLOBAL_POSITION_INT.hdg\nconst vel = msg.payload.GPS_RAW_INT.vel\n\nmsg.payload = {\n    lat: lat / Math.pow(10, 7),\n    lon: lon / Math.pow(10, 7),\n    hdg: hdg / Math.pow(10, 2),\n    vel: vel,\n    name: \"default name 55\",\n    icon: \"ship\"\n};\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1180,
        "y": 180,
                "757a9596885d71cc"
        "id": "4b9e5ae8ad9f47ce",
        "type": "comment",
        "name": "map .55",
        "info": "",
        "x": 1160,
        "y": 140,
        "id": "f5dcad1e83c54b2a",
        "type": "link in",
        "links": [
            "dd910edfc8b2fe75"
        "x": 1245,
        "y": 220,
                "7c71964a7dc8facd"
        "id": "7c71964a7dc8facd",
        "type": "function",
        "name": "function 4",
        "func": "const lat = msg.payload.GPS_RAW_INT.lat;\nconst lon = msg.payload.GPS_RAW_INT.lon;\nconst hdg = msg.payload.GLOBAL_POSITION_INT.hdg\nconst vel = msg.payload.GPS_RAW_INT.vel\n\nmsg.payload = {\n    lat: lat / Math.pow(10, 7),\n    lon: lon / Math.pow(10, 7),\n    hdg: hdg / Math.pow(10, 2),\n    vel: vel,\n    name: \"default name 52\",\n    icon: \"ship\"\n};\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1340,
        "y": 220,
                "757a9596885d71cc"
        "id": "71b00b5410e36d10",
        "type": "comment",
        "name": "map .52",
        "info": "",
        "x": 1320,
        "y": 180,
        "id": "757a9596885d71cc",
        "type": "worldmap",
        "lat": "",
        "lon": "",
        "zoom": "",
        "layer": "OSMG",
        "cluster": "",
        "maxage": "",
        "usermenu": "show",
        "layers": "show",
        "panit": "false",
        "panlock": "false",
        "hiderightclick": "false",
        "coords": "none",
        "overlist": "DR,CO,RA,DN",
        "maplist": "OSMG,OSMC,EsriC,EsriS,UKOS",
        "mapname": "",
        "mapurl": "",
        "mapopt": "",
        "mapwms": false,
        "x": 1700,
        "y": 260,
        "id": "8705087cb84eca16",
        "type": "link in",
        "links": [
            "0393d95c9d305015"
        "x": 1245,
        "y": 320,
                "dca4f5a2676e91f1"
        "id": "dca4f5a2676e91f1",
        "type": "function",
        "name": "function 5",
        "func": "const lat = msg.payload.GPS_RAW_INT.lat;\nconst lon = msg.payload.GPS_RAW_INT.lon;\nconst hdg = msg.payload.GLOBAL_POSITION_INT.hdg\nconst vel = msg.payload.GPS_RAW_INT.vel\n\nmsg.payload = {\n    lat: lat / Math.pow(10, 7),\n    lon: lon / Math.pow(10, 7),\n    hdg: hdg / Math.pow(10, 2),\n    vel: vel,\n    name: \"default name 50\",\n    icon: \"ship\"\n};\n\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1340,
        "y": 320,
                "757a9596885d71cc"
        "id": "8f8fa833ab72be7c",
        "type": "comment",
        "name": "map .50",
        "info": "",
        "x": 1320,
        "y": 280,
        "id": "b66b9508dd319e39",
        "type": "mqtt-broker",
        "name": "mosquitto boe",
        "broker": "10.0.0.99",
        "port": "1888",
        "clientid": "",
        "autoConnect": true,
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "autoUnsubscribe": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthRetain": "false",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closeRetain": "false",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willRetain": "false",
        "willPayload": "",
        "willMsg": {},
        "userProps": "",
        "sessionExpiry": ""
        "id": "7a70e5c28d8ec144",
        "type": "ui_group",
        "tab": "451791de0953f8e1",
        "order": 1,
        "disp": true,
        "width": "11",
        "collapse": true,
        "className": ""
        "id": "451791de0953f8e1",
        "type": "ui_tab",
        "name": "home",
        "icon": "dashboard",
        "order": 1,
        "disabled": false,
        "hidden": false
Hi. In cases where you're flow includes things that won't work outside your environment, it is generally a good idea to share a picture of the flow. You should also try to create a minimal test flow that can be shared without the need for the MQTT, etc connections.
Worldmap supports various events and you should be able to work with these to get notifications of a moved buoy marker and therefore do whatever processing is necessary.
thanks for the suggestion, I didn't know about this possibility regarding the world map block, the next time I post on this forum I will try to apply your suggestions, thanks for that too :grin:
