Hi !
I want to use a technic with JS like .h file in C/C++ and definitively, modify any label at a only one file or node...
For exemple, if i have an array from buffer IoT named o[] with 100 values ; in C, i will put in my header .h file :
#define temp1 o[0]
#define temp2 o[1]
#define temp3 o[2]
#define temp4 o[3]
#define temp100 o[99]
I found on the web this 'map' object :
map = {
1: "FISH",
2: "CHIPS",
3: "EAT",
4: "SLEEP",
5: "CODE",
input = 5
alert(map[5]) // Will alert CODE, as required.
How can i adapt my case and if possible, where can i add this code ?
Thank you very much,
