Ok - phew, I still have the message.
I got this message:
{"topic":"ERROR_REPORT/TelePi/Alarm_Display/ALARM/A2","qos":0,"retain":false,"error":{"message":"Failed to parse JSON string","source":{"id":"fc06e466.761568","type":"mqtt in","name":"All alarms","count":1}},"_msgid":"b574722.201349","time":"2020-08-31 06:54:03","payload":{"message":"Failed to parse JSON string","source":{"id":"fc06e466.761568","type":"mqtt in","name":"All alarms","count":1}},"ttl":0,"_queuetimestamp":1598820843868,"_queueCount":73}
The source points to a MQTT IN node. (Yeah, it tells me that)
The node is this:
[{"id":"98a12d23.4caf","type":"subflow","name":"Time Stamp","info":"","category":"","in":[{"x":80,"y":100,"wires":[{"id":"b51453d8.f777"}]}],"out":[{"x":640,"y":180,"wires":[{"id":"537f67d0.440958","port":0},{"id":"b51453d8.f777","port":0}]},{"x":640,"y":230,"wires":[{"id":"b51453d8.f777","port":0},{"id":"436ec434.1175cc","port":0}]},{"x":640,"y":280,"wires":[{"id":"c77ad598.3b98e8","port":0},{"id":"b51453d8.f777","port":0}]}],"env":[],"color":"#FF8888","outputLabels":["For logging use","msg.time","For filename use"],"icon":"node-red/timer.svg"},{"id":"537f67d0.440958","type":"moment","z":"98a12d23.4caf","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Australia/Sydney","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-MM-DD HH:mm:ss","locale":"en_AU","output":"payload","outputType":"msg","outTz":"Australia/Sydney","x":390,"y":180,"wires":[["c77ad598.3b98e8","9a6e708b.c8249"]]},{"id":"c77ad598.3b98e8","type":"string","z":"98a12d23.4caf","name":"","methods":[{"name":"replaceAll","params":[{"type":"str","value":":"},{"type":"str","value":""}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":440,"y":280,"wires":[[]]},{"id":"9a6e708b.c8249","type":"change","z":"98a12d23.4caf","name":"TOPIC","rules":[{"t":"move","p":"payload","pt":"msg","to":"time","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":230,"wires":[["436ec434.1175cc"]]},{"id":"204888d7.8b194","type":"change","z":"98a12d23.4caf","name":"Save","rules":[{"t":"set","p":"payload","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":140,"wires":[["93239165.b7976"]]},{"id":"436ec434.1175cc","type":"change","z":"98a12d23.4caf","name":"Get","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":230,"wires":[[]]},{"id":"b51453d8.f777","type":"switch","z":"98a12d23.4caf","name":"check topic","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"TIMESTAMP","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":200,"y":100,"wires":[[],["204888d7.8b194"]]},{"id":"93239165.b7976","type":"change","z":"98a12d23.4caf","name":"TimeStamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":180,"wires":[["537f67d0.440958"]]},{"id":"df12de57.5f0de8","type":"tab","label":"Alarm display","disabled":false,"info":"This flow is to receive messages via MQTT on\nEVENT/EVENT\nWork in progress.\n"},{"id":"fc06e466.761568","type":"mqtt in","z":"df12de57.5f0de8","name":"All alarms","topic":"ALARM/#","qos":"2","datatype":"auto","broker":"1ecd3a9e.dc5bfd","x":150,"y":270,"wires":[["dcf93904.c4f75","e19ab931.4054","418ba4ad.aecb94"]]},{"id":"dcf93904.c4f75","type":"debug","z":"df12de57.5f0de8","name":"RAW","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":160,"y":220,"wires":[]},{"id":"e4e27985.7e8bc8","type":"comment","z":"df12de57.5f0de8","name":"Error catcher","info":"","x":4400,"y":120,"wires":[]},{"id":"9120c098.72a8d","type":"inject","z":"df12de57.5f0de8","name":"Stop","topic":"CONTROL","payload":"STOP","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":4220,"y":150,"wires":[["7018404b.f96d9","a2460395.61625"]]},{"id":"32cd9951.2823ee","type":"inject","z":"df12de57.5f0de8","name":"Go","topic":"CONTROL","payload":"GO","payloadType":"str","repeat":"","crontab":"","once":true,"onceDelay":"1","x":4220,"y":190,"wires":[["7018404b.f96d9","a2460395.61625"]]},{"id":"7018404b.f96d9","type":"gate","z":"df12de57.5f0de8","name":"","controlTopic":"CONTROL","defaultState":"open","openCmd":"GO","closeCmd":"STOP","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":4394,"y":240,"wires":[["f6b6fb7e.24f27"]]},{"id":"f6b6fb7e.24f27","type":"function","z":"df12de57.5f0de8","name":"Set topic","func":"var device_name =global.get('myDeviceName');\nmsg.topic =\"ERROR_REPORT/\" + device_name + \"/\" + msg.topic;\nreturn msg;","outputs":1,"noerr":0,"x":4530,"y":240,"wires":[["66a1ead7.4c42a4"]]},{"id":"a2460395.61625","type":"function","z":"df12de57.5f0de8","name":"","func":"var name = flow.get('name');\nvar ok = global.get('Error_Flow_Pass');\nvar stop = global.get('Error_Flow_Stop');\nvar caught = global.get('Error_Detected');\n\n//node.warn(\"Name of the flow \" + name);\n// -- check if this is a CONTROL message.\nif (msg.topic == 'CONTROL')\n{\n //node.warn(\"Control signal received \" + msg.payload);\n if (msg.payload == 'STOP')\n {\n context.set('notify',1);\n msg.topic = name;\n msg.colour = stop;\n } else\n {\n context.set('notify',0);\n msg.topic = name;\n msg.colour = ok;\n }\n return msg;\n}\n\n// -- Send YELLOW as the message if error detected.\n//\tThis is only if the error reporting is blocked.\nvar pass = context.get('notify') ||0;\nif (pass == 1)\n{\n // set msg.payload to indicate\n node.warn(\"Error detected check indication\");\n msg.topic = name;\n msg.colour = caught;\nreturn msg;\n}\n","outputs":1,"noerr":0,"x":4390,"y":190,"wires":[["cae09ec8.24fbd8"]]},{"id":"cae09ec8.24fbd8","type":"link out","z":"df12de57.5f0de8","name":"","links":["432257a4.443a48","bb335d19.a8936"],"x":4485,"y":190,"wires":[]},{"id":"ec1ab6c7.33a56","type":"inject","z":"df12de57.5f0de8","name":"","topic":"","payload":"Alarm_Display","payloadType":"str","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":4590,"y":120,"wires":[["579fe43.6a1609c"]]},{"id":"579fe43.6a1609c","type":"change","z":"df12de57.5f0de8","name":"","rules":[{"t":"set","p":"name","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":4820,"y":120,"wires":[[]]},{"id":"b76ee921.233498","type":"link in","z":"df12de57.5f0de8","name":"Health_Error_CTL","links":["28336f9f.11cc68"],"x":4180,"y":110,"wires":[["a2460395.61625","7018404b.f96d9"]],"l":true},{"id":"66a1ead7.4c42a4","type":"link out","z":"df12de57.5f0de8","name":"Display error TX","links":["ee9ad7ef.4664e"],"x":4710,"y":240,"wires":[],"l":true},{"id":"d8d7d681.092dd8","type":"debug","z":"df12de57.5f0de8","name":"alarm After JSON","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1090,"y":230,"wires":[]},{"id":"4e0441ac.ef44d8","type":"change","z":"df12de57.5f0de8","name":"","rules":[{"t":"set","p":"device","pt":"msg","to":"payload.device","tot":"msg"},{"t":"set","p":"error","pt":"msg","to":"payload.err","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"payload.payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1080,"y":270,"wires":[["c806c715.a74be8"]]},{"id":"c806c715.a74be8","type":"string","z":"df12de57.5f0de8","name":"","methods":[{"name":"delLeftMost","params":[{"type":"str","value":"/"}]}],"prop":"device","propout":"device","object":"msg","objectout":"msg","x":1110,"y":310,"wires":[["9303f3f0.24ad08","6b8e3318.76082c"]]},{"id":"41288c74.f19de4","type":"link in","z":"df12de57.5f0de8","name":"","links":["5066ae76.fcd418","8db457e5.950918"],"x":825,"y":450,"wires":[["35c54b6e.32f3a4"]]},{"id":"788d210f.ac4fd","type":"link in","z":"df12de57.5f0de8","name":"","links":["61ef0d8e.10c974","2ecc0896.84004"],"x":825,"y":600,"wires":[["50248f17.866398","7e393288.44121c"]]},{"id":"fe2d91ab.06b3d8","type":"link in","z":"df12de57.5f0de8","name":"","links":["52c55fa4.0fec3","aaf36071.9db6e"],"x":825,"y":750,"wires":[["69f8ba0f.8c729c","bcfecf06.78fe78"]]},{"id":"9303f3f0.24ad08","type":"debug","z":"df12de57.5f0de8","name":"A1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1280,"y":270,"wires":[]},{"id":"8efd2068.840818","type":"debug","z":"df12de57.5f0de8","name":"A2 after JSON","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1310,"y":400,"wires":[]},{"id":"50248f17.866398","type":"debug","z":"df12de57.5f0de8","name":"A3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1280,"y":560,"wires":[]},{"id":"69f8ba0f.8c729c","type":"debug","z":"df12de57.5f0de8","name":"O1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1280,"y":710,"wires":[]},{"id":"475a5865.ce9ed","type":"switch","z":"df12de57.5f0de8","name":"Alarm type","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"ALARM/A1","vt":"str"},{"t":"eq","v":"ALARM/A2","vt":"str"},{"t":"eq","v":"ALARM/A3","vt":"str"},{"t":"eq","v":"ALARM/O1","vt":"str"},{"t":"eq","v":"ALARM/O2","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":540,"y":350,"wires":[["aa395696.df5dc8"],["8db457e5.950918"],["2ecc0896.84004"],["aaf36071.9db6e"],["8634317d.5dbd7"]]},{"id":"8db457e5.950918","type":"link out","z":"df12de57.5f0de8","name":"A2 alarm","links":["41288c74.f19de4"],"x":685,"y":310,"wires":[]},{"id":"2ecc0896.84004","type":"link out","z":"df12de57.5f0de8","name":"A3 alarm","links":["788d210f.ac4fd"],"x":685,"y":350,"wires":[]},{"id":"aaf36071.9db6e","type":"link out","z":"df12de57.5f0de8","name":"O1 alarm","links":["fe2d91ab.06b3d8"],"x":685,"y":390,"wires":[]},{"id":"6681bd46.d31f9c","type":"link in","z":"df12de57.5f0de8","name":"","links":["aa395696.df5dc8","e9478748.104e68"],"x":825,"y":270,"wires":[["4e0441ac.ef44d8"]]},{"id":"aa395696.df5dc8","type":"link out","z":"df12de57.5f0de8","name":"A1 alarm","links":["6681bd46.d31f9c"],"x":685,"y":270,"wires":[]},{"id":"f5d11f3f.60b7f","type":"comment","z":"df12de57.5f0de8","name":"A1","info":"","x":1050,"y":190,"wires":[]},{"id":"1ac1aca7.63849b","type":"json","z":"df12de57.5f0de8","name":"","property":"payload","action":"","pretty":false,"x":1070,"y":490,"wires":[["8efd2068.840818"]]},{"id":"960b6432.2ce34","type":"comment","z":"df12de57.5f0de8","name":"A2","info":"","x":1070,"y":400,"wires":[]},{"id":"76a38a3b.f31f6c","type":"comment","z":"df12de57.5f0de8","name":"A3","info":"","x":1080,"y":540,"wires":[]},{"id":"cdda7a52.c5d888","type":"comment","z":"df12de57.5f0de8","name":"O1","info":"","x":1080,"y":710,"wires":[]},{"id":"5d5a83ce.d60d8c","type":"change","z":"df12de57.5f0de8","name":"Wipe","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1910,"y":400,"wires":[["6b8e3318.76082c"]]},{"id":"6b8e3318.76082c","type":"simple-queue","z":"df12de57.5f0de8","name":"queue1","firstMessageBypass":false,"bypassInterval":"0","x":1920,"y":310,"wires":[["446e403a.32395"]]},{"id":"447c1acb.a9e3a4","type":"inject","z":"df12de57.5f0de8","name":"Wipe","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":1780,"y":400,"wires":[["5d5a83ce.d60d8c"]]},{"id":"446e403a.32395","type":"debug","z":"df12de57.5f0de8","name":"A1 errors","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":2070,"y":310,"wires":[]},{"id":"a6456881.25c85","type":"change","z":"df12de57.5f0de8","name":"Read","rules":[{"t":"set","p":"trigger","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1910,"y":360,"wires":[["6b8e3318.76082c"]]},{"id":"fe901700.5d8768","type":"inject","z":"df12de57.5f0de8","name":"Read","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":1780,"y":360,"wires":[["a6456881.25c85"]]},{"id":"7f767ba7.69f1d4","type":"debug","z":"df12de57.5f0de8","name":"A2 errors","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":2070,"y":450,"wires":[]},{"id":"35c54b6e.32f3a4","type":"simple-queue","z":"df12de57.5f0de8","name":"queue1","firstMessageBypass":false,"bypassInterval":"0","x":1920,"y":450,"wires":[["7f767ba7.69f1d4"]]},{"id":"78f49b78.bcefbc","type":"change","z":"df12de57.5f0de8","name":"Wipe","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1910,"y":540,"wires":[["35c54b6e.32f3a4"]]},{"id":"9bfa1d96.f6ee4","type":"change","z":"df12de57.5f0de8","name":"Read","rules":[{"t":"set","p":"trigger","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1910,"y":500,"wires":[["35c54b6e.32f3a4"]]},{"id":"f0daa0c9.51b65","type":"inject","z":"df12de57.5f0de8","name":"Wipe","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":1780,"y":540,"wires":[["78f49b78.bcefbc"]]},{"id":"87c3cabd.f62b7","type":"inject","z":"df12de57.5f0de8","name":"Read","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":1780,"y":500,"wires":[["9bfa1d96.f6ee4"]]},{"id":"c8da4f7b.b0099","type":"debug","z":"df12de57.5f0de8","name":"A3 errors","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":2070,"y":600,"wires":[]},{"id":"8bfb9585.8198c8","type":"simple-queue","z":"df12de57.5f0de8","name":"queue1","firstMessageBypass":false,"bypassInterval":"0","x":1920,"y":600,"wires":[["c8da4f7b.b0099"]]},{"id":"83639b7e.aa2118","type":"change","z":"df12de57.5f0de8","name":"Wipe","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1910,"y":690,"wires":[["8bfb9585.8198c8"]]},{"id":"3c24a4fb.2b8134","type":"change","z":"df12de57.5f0de8","name":"Read","rules":[{"t":"set","p":"trigger","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1910,"y":650,"wires":[["8bfb9585.8198c8"]]},{"id":"f92ca84c.210cf8","type":"inject","z":"df12de57.5f0de8","name":"Wipe","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":1780,"y":690,"wires":[["83639b7e.aa2118"]]},{"id":"3f88056c.33e282","type":"inject","z":"df12de57.5f0de8","name":"Read","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":1780,"y":650,"wires":[["3c24a4fb.2b8134"]]},{"id":"a2aae92b.39af9","type":"debug","z":"df12de57.5f0de8","name":"O1 errors","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":2070,"y":750,"wires":[]},{"id":"27c9a2fb.c08246","type":"simple-queue","z":"df12de57.5f0de8","name":"queue1","firstMessageBypass":false,"bypassInterval":"0","x":1920,"y":750,"wires":[["a2aae92b.39af9"]]},{"id":"20d29184.61331e","type":"change","z":"df12de57.5f0de8","name":"Wipe","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1910,"y":840,"wires":[["27c9a2fb.c08246"]]},{"id":"7c7ac241.e2215c","type":"change","z":"df12de57.5f0de8","name":"Read","rules":[{"t":"set","p":"trigger","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1910,"y":800,"wires":[["27c9a2fb.c08246"]]},{"id":"99e633da.1b354","type":"inject","z":"df12de57.5f0de8","name":"Wipe","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":1780,"y":840,"wires":[["20d29184.61331e"]]},{"id":"be983580.2763a","type":"inject","z":"df12de57.5f0de8","name":"Read","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":1780,"y":800,"wires":[["7c7ac241.e2215c"]]},{"id":"7e393288.44121c","type":"fan","z":"df12de57.5f0de8","x":1160,"y":600,"wires":[["8bfb9585.8198c8"]]},{"id":"bcfecf06.78fe78","type":"fan","z":"df12de57.5f0de8","x":1170,"y":750,"wires":[["27c9a2fb.c08246"]]},{"id":"8634317d.5dbd7","type":"link out","z":"df12de57.5f0de8","name":"O2 Alarm","links":["3be6d353.24e5f4"],"x":685,"y":430,"wires":[]},{"id":"3be6d353.24e5f4","type":"link in","z":"df12de57.5f0de8","name":"","links":["8634317d.5dbd7"],"x":815,"y":890,"wires":[["59e1bc6a.8f49bc","e3c0fc8.dd0168"]]},{"id":"59e1bc6a.8f49bc","type":"debug","z":"df12de57.5f0de8","name":"O2","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1280,"y":850,"wires":[]},{"id":"8a295052.1d3ff8","type":"comment","z":"df12de57.5f0de8","name":"O2","info":"","x":1080,"y":850,"wires":[]},{"id":"e3c0fc8.dd0168","type":"fan","z":"df12de57.5f0de8","x":1170,"y":890,"wires":[[]]},{"id":"7e592efc.5c50f","type":"debug","z":"df12de57.5f0de8","name":"O2 After JSON","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1480,"y":850,"wires":[]},{"id":"b9999c05.62437","type":"fan","z":"df12de57.5f0de8","x":4220,"y":240,"wires":[["a2460395.61625","7018404b.f96d9"]]},{"id":"31509fc1.1bacb8","type":"catch","z":"df12de57.5f0de8","name":"","scope":null,"x":3290,"y":240,"wires":[["d514fd4e.1760f","c931deb2.1eb0d8"]]},{"id":"a51977b6.ec4d","type":"inject","z":"df12de57.5f0de8","name":"","topic":"","payload":"Test","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":3300,"y":280,"wires":[["c931deb2.1eb0d8"]]},{"id":"d307a93d.1cb888","type":"comment","z":"df12de57.5f0de8","name":"Error catching","info":"","x":3850,"y":60,"wires":[]},{"id":"1052fc4f.7af0d4","type":"function","z":"df12de57.5f0de8","name":"Name flow","func":"var device_name =global.get('myDeviceName') || \"Artificial Device Name\";\nvar flow_name = flow.get('name') || \"Artificial Flow Name\";\nmsg.topic =\"ERROR_REPORT/\" + device_name + \"/\" + flow_name + \"/\" + msg.topic;\nreturn msg;","outputs":1,"noerr":0,"x":3660,"y":240,"wires":[["d6da28ac.68d528","57a1422e.4a21f4"]]},{"id":"dda0bf46.8734a8","type":"change","z":"df12de57.5f0de8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"error","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":4055,"y":240,"wires":[["b9999c05.62437","27e4bafe.7e477e"]]},{"id":"e54cd4b0.3f74d","type":"inject","z":"df12de57.5f0de8","name":"Read","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":3495,"y":291,"wires":[["56bf456.5235d3c"]]},{"id":"b20b83cb.261338","type":"inject","z":"df12de57.5f0de8","name":"Wipe","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":3495,"y":331,"wires":[["93003a95.234268"]]},{"id":"93003a95.234268","type":"change","z":"df12de57.5f0de8","name":"Wipe","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":3675,"y":331,"wires":[["27e4bafe.7e477e"]]},{"id":"56bf456.5235d3c","type":"change","z":"df12de57.5f0de8","name":"Read","rules":[{"t":"set","p":"trigger","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":3675,"y":291,"wires":[["27e4bafe.7e477e"]]},{"id":"27e4bafe.7e477e","type":"simple-queue","z":"df12de57.5f0de8","name":"queue1","firstMessageBypass":false,"bypassInterval":"0","x":3861,"y":291,"wires":[["e993f476.73b1f"]]},{"id":"e993f476.73b1f","type":"debug","z":"df12de57.5f0de8","name":"Local Readings error list","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":4055,"y":291,"wires":[]},{"id":"4daf2ef0.abfdb","type":"inject","z":"df12de57.5f0de8","name":"Stop","topic":"control","payload":"stop","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":3680,"y":160,"wires":[["57a1422e.4a21f4"]],"icon":"node-red/alert.png"},{"id":"ac230f5b.64b228","type":"inject","z":"df12de57.5f0de8","name":"Go","topic":"control","payload":"go","payloadType":"str","repeat":"","crontab":"","once":true,"onceDelay":"1","x":3680,"y":200,"wires":[["57a1422e.4a21f4"]]},{"id":"d6da28ac.68d528","type":"debug","z":"df12de57.5f0de8","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":3850,"y":200,"wires":[]},{"id":"57a1422e.4a21f4","type":"gate","z":"df12de57.5f0de8","name":"","controlTopic":"control","defaultState":"open","openCmd":"go","closeCmd":"stop","toggleCmd":"toggle","defaultCmd":"default","persist":false,"x":3850,"y":240,"wires":[["dda0bf46.8734a8"]]},{"id":"c931deb2.1eb0d8","type":"subflow:98a12d23.4caf","z":"df12de57.5f0de8","name":"","x":3500,"y":240,"wires":[[],["1052fc4f.7af0d4"],[]]},{"id":"3dd7f1a6.2f5406","type":"function","z":"df12de57.5f0de8","name":"This will throw an error","func":"var n = 23 + 56 / a;\n//var n = 23 + 56 ;\nmsg.payload = n;\nreturn msg;","outputs":1,"noerr":0,"x":3910,"y":580,"wires":[["e77adc91.b479d8"]]},{"id":"c860799a.1dfe08","type":"inject","z":"df12de57.5f0de8","name":"","topic":"","payload":"Cause an error","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":3890,"y":540,"wires":[["3dd7f1a6.2f5406"]]},{"id":"e77adc91.b479d8","type":"debug","z":"df12de57.5f0de8","name":"Fake error message","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":3910,"y":620,"wires":[]},{"id":"33709acc.7e5c3e","type":"comment","z":"df12de57.5f0de8","name":"Test error generation","info":"","x":3890,"y":500,"wires":[]},{"id":"fdd06ad6.58f648","type":"subflow:98a12d23.4caf","z":"df12de57.5f0de8","name":"","x":360,"y":350,"wires":[[],["475a5865.ce9ed"],[]]},{"id":"debb7d4f.24dc98","type":"link out","z":"df12de57.5f0de8","name":"Runaway","links":["8da8c919.68c64","3462a866.13a728","22b06b49.92507c","fdc3ca8f.7a24b8"],"x":3860,"y":120,"wires":[],"l":true},{"id":"550e83e8.cea0bc","type":"change","z":"df12de57.5f0de8","name":"Stop","rules":[{"t":"set","p":"payload","pt":"msg","to":"stop","tot":"str"},{"t":"set","p":"topic","pt":"msg","to":"CONTROL","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":3680,"y":120,"wires":[["debb7d4f.24dc98","57a1422e.4a21f4"]]},{"id":"1f09d605.a0d692","type":"switch","z":"df12de57.5f0de8","name":"> 30","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"30","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":3520,"y":120,"wires":[["550e83e8.cea0bc"]]},{"id":"d514fd4e.1760f","type":"msg-speed","z":"df12de57.5f0de8","name":"Speed check","frequency":"sec","estimation":false,"ignore":false,"x":3500,"y":200,"wires":[["1f09d605.a0d692"],[]]},{"id":"e19ab931.4054","type":"function","z":"df12de57.5f0de8","name":"MQTT Decoder","func":"var newMsg = msg.payload; \nreturn newMsg;","outputs":1,"noerr":0,"x":170,"y":350,"wires":[["fdd06ad6.58f648"]],"info":"This node takes the *modified* message and puts it back to what it was on the other machine before it was sent via MQTT.\nSimple.\n2 lines of code."},{"id":"c7a35c66.615b08","type":"switch","z":"df12de57.5f0de8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"json","vt":"json"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":930,"y":490,"wires":[["1ac1aca7.63849b"],[]]},{"id":"14bca9f3.42be86","type":"debug","z":"df12de57.5f0de8","name":"Raw alarm messages","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":630,"y":210,"wires":[]},{"id":"418ba4ad.aecb94","type":"simple-queue","z":"df12de57.5f0de8","name":"queue1","firstMessageBypass":false,"bypassInterval":"0","x":440,"y":210,"wires":[["14bca9f3.42be86"]]},{"id":"309cbd1b.871c72","type":"change","z":"df12de57.5f0de8","name":"Wipe","rules":[{"t":"set","p":"reset","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":160,"wires":[["418ba4ad.aecb94"]]},{"id":"36b4dfe0.14a7a8","type":"change","z":"df12de57.5f0de8","name":"Read","rules":[{"t":"set","p":"trigger","pt":"msg","to":"1","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":430,"y":120,"wires":[["418ba4ad.aecb94"]]},{"id":"7a0da546.b3aea4","type":"inject","z":"df12de57.5f0de8","name":"Wipe","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":300,"y":160,"wires":[["309cbd1b.871c72"]]},{"id":"53e388a0.89a718","type":"inject","z":"df12de57.5f0de8","name":"Read","topic":"","payload":" ","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":"","x":300,"y":120,"wires":[["36b4dfe0.14a7a8"]]},{"id":"1ecd3a9e.dc5bfd","type":"mqtt-broker","z":"","name":"MQTT host","broker":"192.168.0.99","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"SOM","birthQos":"0","birthPayload":"TelePi comms up","closeTopic":"EOM","closePayload":"TelePi shutting down","willTopic":"EOM","willQos":"0","willPayload":"TelePi Comms Failure"}]
Are the settings correct in that node to parse that message?
I got a (somewhat large) crash this morning and about 75 of those errors.
I didn't check all of them, but the ones at which I looked were all the same.
It was a bit of a run away that didn't quite run away.
