Java to JSON conversion
I imported a java code and received an JSON array error, can anyone help?
You will have to give a little bit more information. Did you mean Javascript code? because Java is not supported. And where did you import it?
Do you have an example flow?
Johannes
Hi @makowski13
can you share more details on what you have tried to do and what error you are getting?
@knolleary @makowski13 wrote a private message to me. He tried to import Java code.
Yes, he private messaged me as well.
@makowski13 please don't private message people who respond to your questions unless you have a good reason to. In this case, both I and @JGKK took time to respond, not knowing you had messaged the other person as well.
In general, keep the conversation in the thread you started.
