Javascript help to remove NaN from array
This is actually a follow-up related to a previous post, but is a totally different question...
In an HTTP GET request, I grab the price of nickel (which is returned as a value that must be divided by 1), convert to lbs and then store in Influx, all via this function:
msg.payload = msg.payload.map(function (value) {
    return {
        measurement: "CommodityData",
        fields: {
            Ni_price: 1.0 /value.NI / 2204.623,
        timestamp: new Date(value.date).valueOf()
I have found that for reasons unknown, when grabbing historical data, it can return NaN (maybe it's a holiday or whatever). Influx does not like this, and displays:
"Error: invalid float value for field 'Ni_price': NaN"
I found at least two objects that were NaN.
Is there a quick and easy way to modify my function above to exclude any time Ni_price is NaN? Thanks in advance for any pointers.
Ok, I'll try.
Pass the message through a function node and look at the message.
Then - using your example - you would have something like:
if (msg.payload.CommodityData.Ni_price == nan)
      //  Code to stop the error
Alas you may need to do a few iterations of the code but I hope that helps.
nan is not a thing. The safest way is to use isNaN
if (isNaN(msg.payload.CommodityData.Ni_price)) {
    return null // stop the msg being passed to next node
PS, if you use monaco, you will see that :smiley:
Yes, ok. I didn't actually write the code in NR. I did it on the fly and nope that the mistake would be read around.
It was an example. Sorry, but I am having a bit of trouble at my end and just dropped the quick reply.
