Hi together,
currently I am working on a project where I get data from a robot and visualize it in the Dashbaord. For visualization I use an external JS library. I searched through the forum and was able to import the Javascript Library into Node-RED. Import JavaScript library into node-red
So I can access the script in the Browser (http://localhost:1880/rv-master/src/RobotViewer.js)
However, I guess I am making a mistake by using the script tag.
I try to add it to the Head section so that it is being loaded and in another template node I try to access it. However, I get a reference error which says RobotViewer not defined.
What is wrong here?
RobotVisualization.json (1.9 KB)
Thats how it should like like in the end:
Thanks for helping.
