Joining 2 buffer payloads in java script
I am trying to duplicate the join node in javascript as a learning exercise. I am trying to join a payload consisting of 2 buffers. I have a test env of:
My function node is:
var a= Buffer.from(msg.payload);
var b = Buffer.from(msg.payload);
var buf = Buffer.concat([a,b]);
msg = {payload: buf};
I am getting the following results:
I suspect my function is only processing var a for each inject node and not waiting for both. I wonder if I need a loop function in order to pick up var b.
Here is the code for reference.
[{"id":"7853b54d4b445e37","type":"function","z":"4512ac95.5bc124","name":"","func":"var a= Buffer.from(msg.payload);\nvar b = Buffer.from(msg.payload);\nvar buf = Buffer.concat([a,b]);\nmsg = {payload: buf};\nreturn msg;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":820,"wires":[["270630966f5476f3"]]},{"id":"270630966f5476f3","type":"debug","z":"4512ac95.5bc124","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":590,"y":820,"wires":[]},{"id":"0a6178d1c6bfd378","type":"inject","z":"4512ac95.5bc124","name":"a","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[82,49,124,48,124,109,101,116,101,114,32,49,46,115,114,99,61,67,79,68,45,35,49,46,110,117,109,61,49,35,49,46,110,97,109,61,77,73,67,80,69,65,75,35,49,46,108,111,119,61,45,49,53,48,46,48,35,49,46,104,105,61,50,48,46,48,35,49,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,77,73,67,32,111,117,116,112,117,116,32,105,110,32,67,79,68,69,67,35,49,46,117,110,105,116,61,100,66,70,83,35,49,46,102,112,115,61,52,48,35,50,46,115,114,99,61,67,79,68,45,35,50,46,110,117,109,61,50,35,50,46,110,97,109,61,77,73,67,35,50,46,108,111,119,61,45,49,53,48,46,48,35,50,46,104,105,61,50,48,46,48,35,50,46,100,101,115,99,61,65,118,101,114,97,103,101,32,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,77,73,67,32,111,117,112,117,116,32,105,110,32,67,79,68,69,67,35,50,46,117,110,105,116,61,100,66,70,83,35,50,46,102,112,115,61,50,48,35,51,46,115,114,99,61,84,88,45,35,51,46,110,117,109,61,53,35,51,46,110,97,109,61,72,87,65,76,67,35,51,46,108,111,119,61,45,49,53,48,46,48,35,51,46,104,105,61,50,48,46,48,35,51,46,100,101,115,99,61,86,111,108,116,97,103,101,32,112,114,101,115,101,110,116,32,97,116,32,116,104,101,32,72,97,114,100,119,97,114,101,32,65,76,67,32,82,67,65,32,80,108,117,103,35,51,46,117,110,105,116,61,100,66,70,83,35,51,46,102,112,115,61,50,48,35,52,46,115,114,99,61,82,65,68,35,52,46,110,117,109,61,51,51,52,35,52,46,110,97,109,61,43,49,51,46,56,65,35,52,46,108,111,119,61,49,48,46,53,35,52,46,104,105,61,49,53,46,48,35,52,46,100,101,115,99,61,77,97,105,110,32,114,97,100,105,111,32,105,110,112,117,116,32,118,111,108,116,97,103,101,32,97,116,32,80,65,35,52,46,117,110,105,116,61,86,111,108,116,115,35,52,46,102,112,115,61,48,35,53,46,115,114,99,61,82,65,68,35,53,46,110,117,109,61,48,35,53,46,110,97,109,61,43,49,51,46,56,66,35,53,46,108,111,119,61,49,48,46,53,35,53,46,104,105,61,49,53,46,48,35,53,46,100,101,115,99,61,77,97,105,110,32,114,97,100,105,111,32,105,110,112,117,116,32,118,111,108,116,97,103,101,32,97,116,32,67,80,85,32,40,99,111,110,116,105,110,117,111,117,115,41,35,53,46,117,110,105,116,61,86,111,108,116,115,35,53,46,102,112,115,61,48,35,54,46,115,114,99,61,82,65,68,35,54,46,110,117,109,61,51,35,54,46,110,97,109,61,77,65,73,78,70,65,78,35,54,46,108,111,119,61,48,46,48,35,54,46,104,105,61,56,49,57,50,46,48,35,54,46,100,101,115,99,61,77,97,105,110,32,114,97,100,105,111,32,102,97,110,32,82,80,77,35,54,46,117,110,105,116,61,82,80,77,35,54,46,102,112,115,61,48,35,55,46,115,114,99,61,84,88,45,35,55,46,110,117,109,61,49,35,55,46,110,97,109,61,70,87,68,80,87,82,35,55,46,108,111,119,61,48,46,48,35,55,46,104,105,61,53,51,46,48,35,55,46,100,101,115,99,61,82,70,32,80,111,119,101,114,32,70,111,114,119,97,114,100,35,55,46,117,110,105,116,61,100,66,109,35,55,46,102,112,115,61,50,48,35,56,46,115,114,99,61,84,88,45,35,56,46,110,117,109,61,50,35,56,46,110,97,109,61,82,69,70,80,87,82,35,56,46,108,111,119,61,48,46,48,35,56,46,104,105,61,53,51,46,48,35,56,46,100,101,115,99,61,82,70,32,80,111,119,101,114,32,82,101,102,108,101,99,116,101,100,35,56,46,117,110,105,116,61,100,66,109,35,56,46,102,112,115,61,50,48,35,57,46,115,114,99,61,84,88,45,35,57,46,110,117,109,61,51,35,57,46,110,97,109,61,83,87,82,35,57,46,108,111,119,61,49,46,48,35,57,46,104,105,61,57,57,57,46,48,35,57,46,100,101,115,99,61,82,70,32,83,87,82,35,57,46,117,110,105,116,61,83,87,82,35,57,46,102,112,115,61,50,48,35,49,48,46,115,114,99,61,84,88,45,35,49,48,46,110,117,109,61,52,35,49,48,46,110,97,109,61,80,65,84,69,77,80,35,49,48,46,108,111,119,61,48,46,48,35,49,48,46,104,105,61,49,48,48,46,48,35,49,48,46,100,101,115,99,61,80,65,32,84,101,109,112,101,114,97,116,117,114,101,35,49,48,46,117,110,105,116,61,100,101,103,67,35,49,48,46,102,112,115,61,48,35,49,49,46,115,114,99,61,83,76,67,35,49,49,46,110,117,109,61,48,35,49,49,46,110,97,109,61,50,52,107,72,122,35,49,49,46,108,111,119,61,45,49,52,48,46,48,35,49,49,46,104,105,61,50,48,46,48,35,49,49,46,100,101,115,99,61,50,52,107,72,122,32,98,114,111,97,100,98,97,110,100,32,115,108,105,99,101,32,114,101,99,101,105,118,101,114,32,115,105,103,110,97,108,32,108,101,118,101,108,35,49,49,46,117,110,105,116,61,100,66,70,83,35,49,49,46,102,112,115,61,49,48,35,49,50,46,115,114,99,61,83,76,67,35,49,50,46,110,117,109,61,48,35,49,50,46,110,97,109,61,79,83,67,35,49,50,46,108,111,119,61,45,49,52,48,46,48,35,49,50,46,104,105,61,50,48,46,48,35,49,50,46,100,101,115,99,61,83,105,103,110,97,108,32,83,116,114,101,110,103,116,104,32,97,102,116,101,114,32,79,83,67,35,49,50,46,117,110,105,116,61,100,66,70,83,35,49,50,46,102,112,115,61,49,48,35,49,51,46,115,114,99,61,83,76,67,35,49,51,46,110,117,109,61,48,35,49,51,46,110,97,109,61,76,69,86,69,76,35,49,51,46,108,111,119,61,45,49,53,48,46,48,35,49,51,46,104,105,61,50,48,46,48,35,49,51,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,115,105,103,110,97,108,115,32,105,110,32,116,104,101,32,102,105,108,116,101,114,32,112,97,115,115,98,97,110,100,35,49,51,46,117,110,105,116,61,100,66,109,35,49,51,46,102,112,115,61,49,48,35,49,52,46,115,114,99,61,83,76,67,35,49,52,46,110,117,109,61,48,35,49,52,46,110,97,109,61,78,82,47,65,78,70,35,49,52,46,108,111,119,61,45,49,53,48,46,48,35,49,52,46,104,105,61,50,48,46,48,35,49,52,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,97,102,116,101,114,32,78,82,47,65,78,70,35,49,52,46,117,110,105,116,61,100,66,109,35,49,52,46,102,112,115,61,49,48,35,49,53,46,115,114,99,61,83,76,67,35,49,53,46,110,117,109,61,48,35,49,53,46,110,97,109,61,65,71,67,43,35,49,53,46,108,111,119,61,45,49,53,48,46,48,35,49,53,46,104,105,61,48,46,48,35,49,53,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,97,102,116,101,114,32,65,71,67,35,49,53,46,117,110,105,116,61,100,66,70,83,35,49,53,46,102,112,115,61,49,48,35,49,54,46,115,114,99,61,84,88,45,35,49,54,46,110,117,109,61,56,35,49,54,46,110,97,109,61,67,79,68,69,67,35,49,54,46,108,111,119,61,45,49,53,48,46,48,35,49,54,46,104,105,61,50,48,46,48,35,49,54,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,67,79,68,69,67,32,111,117,116,112,117,116,35,49,54,46,117,110,105,116,61,100,66,70,83,35,49,54,46,102,112,115,61,49,48,35,49,55,46,115,114,99,61,84,88,45,35,49,55,46,110,117,109,61,56,35,49,55,46,110,97,109,61,83,67,95,77,73,67,35,49,55,46,108,111,119,61,45,49,53,48,46,48,35,49,55,46,104,105,61,50,48,46,48,35,49,55,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,77,73,67,32,111,117,116,112,117,116,35,49,55,46,117,110,105,116,61,100,66,70,83,35,49,55,46,102,112,115,61,49,48,35,49,56,46,115,114,99,61,84,88,45,35,49,56,46,110,117,109,61,56,35,49,56,46,110,97,109,61,67,79,77,80,80,69,65,75,35,49,56,46,108,111,119,61,45,49,53,48,46,48,35,49,56,46,104,105,61,50,48,46,48,35,49,56,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,115,105,103,110,97,108,115,32,97,102,116,101,114,32,116,104,101,32,67,76,73,80,80,69,82,32,40,67,111,109,112,114,101,115,115,105,111,110,41,35,49,56,46,117,110,105,116,61,100,66,70,83,35,49,56,46,102,112,115,61,50,48,35,49,57,46,115,114,99,61,84,88,45,35,49,57,46,110,117,109,61,56,35,49,57,46,110,97,109,61,83,67,95,70,73,76,84,95,49,35,49,57,46,108,111,119,61,45,49,53,48,46,48,35,49,57,46,104,105,61,50,48,46,48,35,49,57,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,97,102,116,101,114,32,70,105,108,116,101,114,32,49,35,49,57,46,117,110,105,116,61,100,66,70,83,35,49,57,46,102,112,115,61,49,48,35,50,48,46,115,114,99,61,84,88,45,35,50,48,46,110,117,109,61,56,35,50,48,46,110,97,109,61,65,76,67,35,50,48,46,108,111,119,61,45,49,53,48,46,48,35,50,48,46,104,105,61,50,48,46,48,35,50,48,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,115,105,103,110,97,108,115,32,97,102,116,101,114,32,83,87,32,65,76,67,32,40,83,83,66,32,80,101,97,107,41,35,50,48,46,117,110,105,116,61,100,66,70,83,35,50,48,46,102,112,115,61,49,48,35,50,49,46,115,114,99,61,84,88,45,35,50,49,46,110,117,109,61,56,35,50,49,46,110,97,109,61,80,82,69,95,87,65,86,69,95,65,71,67,35,50,49,46,108,111,119,61,45,49,53,48,46,48,35,50,49,46,104,105,61,50,48,46,48,35,50,49,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,98,101,102,111,114,101,32,87,97,118,101,102,111,114,109,32,65,71,67,35,50,49,46,117,110,105,116,61,100,66,70,83,35,50,49,46,102,112,115,61,49,48]","payloadType":"bin","x":210,"y":800,"wires":[["7853b54d4b445e37"]]},{"id":"e9720adfb13ce577","type":"inject","z":"4512ac95.5bc124","name":"b","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[45,35,50,53,46,110,117,109,61,56,35,50,53,46,110,97,109,61,65,70,82,65,77,80,35,50,53,46,108,111,119,61,45,49,53,48,46,48,35,50,53,46,104,105,61,50,48,46,48,35,50,53,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,115,105,103,110,97,108,115,32,97,102,116,101,114,32,116,104,101,32,114,97,109,112,35,50,53,46,117,110,105,116,61,100,66,70,83,35,50,53,46,102,112,115,61,49,48,35,50,54,46,115,114,99,61,84,88,45,35,50,54,46,110,117,109,61,56,35,50,54,46,110,97,109,61,80,79,83,84,95,80,35,50,54,46,108,111,119,61,45,49,53,48,46,48,35,50,54,46,104,105,61,48,46,48,35,50,54,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,97,102,116,101,114,32,97,108,108,32,112,114,111,99,101,115,115,105,110,103,32,105,115,32,100,111,110,101,32,98,117,116,32,98,101,102,111,114,101,32,97,116,116,101,110,117,97,116,105,111,110,32,102,111,114,32,112,111,119,101,114,32,99,111,110,116,114,111,108,35,50,54,46,117,110,105,116,61,100,66,70,83,35,50,54,46,102,112,115,61,49,48,35,50,55,46,115,114,99,61,84,88,45,35,50,55,46,110,117,109,61,56,35,50,55,46,110,97,109,61,71,65,73,78,35,50,55,46,108,111,119,61,45,49,53,48,46,48,35,50,55,46,104,105,61,48,46,48,35,50,55,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,97,102,116,101,114,32,71,97,105,110,35,50,55,46,117,110,105,116,61,100,66,70,83,35,50,55,46,102,112,115,61,49,48,35,10,45,35,50,53,46,110,117,109,61,56,35,50,53,46,110,97,109,61,65,70,82,65,77,80,35,50,53,46,108,111,119,61,45,49,53,48,46,48,35,50,53,46,104,105,61,50,48,46,48,35,50,53,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,111,102,32,115,105,103,110,97,108,115,32,97,102,116,101,114,32,116,104,101,32,114,97,109,112,35,50,53,46,117,110,105,116,61,100,66,70,83,35,50,53,46,102,112,115,61,49,48,35,50,54,46,115,114,99,61,84,88,45,35,50,54,46,110,117,109,61,56,35,50,54,46,110,97,109,61,80,79,83,84,95,80,35,50,54,46,108,111,119,61,45,49,53,48,46,48,35,50,54,46,104,105,61,48,46,48,35,50,54,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,97,102,116,101,114,32,97,108,108,32,112,114,111,99,101,115,115,105,110,103,32,105,115,32,100,111,110,101,32,98,117,116,32,98,101,102,111,114,101,32,97,116,116,101,110,117,97,116,105,111,110,32,102,111,114,32,112,111,119,101,114,32,99,111,110,116,114,111,108,35,50,54,46,117,110,105,116,61,100,66,70,83,35,50,54,46,102,112,115,61,49,48,35,50,55,46,115,114,99,61,84,88,45,35,50,55,46,110,117,109,61,56,35,50,55,46,110,97,109,61,71,65,73,78,35,50,55,46,108,111,119,61,45,49,53,48,46,48,35,50,55,46,104,105,61,48,46,48,35,50,55,46,100,101,115,99,61,83,105,103,110,97,108,32,115,116,114,101,110,103,116,104,32,97,102,116,101,114,32,71,97,105,110,35,50,55,46,117,110,105,116,61,100,66,70,83,35,50,55,46,102,112,115,61,49,48,35,10]","payloadType":"bin","x":210,"y":860,"wires":[["7853b54d4b445e37"]]}]
Regards
That's exactly right, it's flow based programming: a message arrives at a node, is processed, then it's gone.
Your function has no knowledge of previous messsages.
There are two ways to deal with it:
  1. Use context storage to retain the previous payload - assuming you can tell if a given message is type a or type b.
  2. Use a Join node to combine the two messages into one. This will require msg.topic to distinguish a from b messages.
Thanks for the confirmation. What I have been attempting to do form the onset is duplicate the join node. You can select how many msgs it collects before the join. I am just trying to do this in java script as an exercise.
Avoiding a Join node then, your context variable could be an array.
Either push the latest value to the array or else concatenate all the array elements and pass the result on.
as jbudd mentioned, you need to use Context .. which is like a higher scope of memory to remember each previous payload before concat and some sort of counter that resets after 2 messages.
maybe something like this ?
// read count from Context or set to 1
let count = context.get("count") || 1
if (count == 1) {
    context.set("a", Buffer.from(msg.payload));
    context.set("count", 2)
if (count == 2) {
    context.set("b", Buffer.from(msg.payload));
    context.set("count", 1) // reset counter
    let a = context.get("a");
    let b = context.get("b");
    let buf = Buffer.concat([a, b]);
    msg = { payload: buf };
Thank you. I did not realize context could be used like this.
but there is a problem with the code .. if you trigger the same inject node twice .. it still adds the buffers
maybe thats not what you need ? .. if not you need to do additional checks by possibly sending a msg.topic to differentiate the two separate msgs
ps. its good for coding practice but personally i would stick with the Join node .. its much more powerful
