Jsmodbus as external javascript in a function node
I know that is node-red-contrib-modbus, but I want to use clear jsmodbus inside node-red.
Inside .node-red folder I install jsmodbus ('npm install -g jsmodbus')
my settings.js
    functionGlobalContext: {
		jsmodbus: require('jsmodbus'),
		net: require('net')
my function
    // create a tcp modbus client
let Modbus = global.get('jsmodbus');
let net = global.get('net');
let socket = new net.Socket();
let client = new Modbus.client.TCP(socket);
let options = {
  host: "10.0.0.66",
  port: 502
socket.on("connect", function() {
  client
    .readHoldingRegisters(5,1)
    .then(function(resp) {
      msg.m_response = resp.response._body;
      socket.end();
    .catch(function() {
      console.error(
        require("util").inspect(arguments, {
          depth: null
      socket.end();
socket.connect(options);
[{"id":"6dc680ce450d84b1","type":"tab","label":"jsmodbus","disabled":false,"info":"","env":[]},{"id":"62559f47f6818b55","type":"function","z":"6dc680ce450d84b1","name":"","func":"    // create a tcp modbus client\n    \nlet Modbus = global.get('jsmodbus');\nlet net = global.get('net');\nlet socket = new net.Socket();\nlet client = new Modbus.client.TCP(socket);\nlet options = {\n  host: \"10.0.0.66\",\n  port: 502\n};\n\nsocket.on(\"connect\", function() {\n  client\n    .readHoldingRegisters(5,1)\n    .then(function(resp) {\n      msg.m_response = resp.response._body;\n      socket.end();\n    })\n    .catch(function() {\n      console.error(\n        require(\"util\").inspect(arguments, {\n          depth: null\n        })\n      );\n      socket.end();\n    });\n});\n\n\nsocket.connect(options);\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":240,"y":120,"wires":[["abce1ad369e230cc"]]},{"id":"fed32ff3f60dbcfe","type":"inject","z":"6dc680ce450d84b1","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":90,"y":120,"wires":[["62559f47f6818b55"]]},{"id":"abce1ad369e230cc","type":"debug","z":"6dc680ce450d84b1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":420,"y":120,"wires":[]}]
and my error
obraz
Any idea?
The obvious questions first
  • can this instance of node-red ping 10.0.0.66 ?
  • is the device online and is port 502 the correct port?
An end to end test could be performed by using node-red-node-ping (so that the node-red instance from within node env does the pinging)
Yes. I tested by Modbus Pool and its ok.
This error crashed node-red and I must have start node-red again.
That does not verify the node-red instance can contact 10.0.0.66
Please do a ping check from within node-red to the end device.
Also, is node-red running in docker?
Node-red is not from docker.
Ping from node-red is ok.
function from node-red-contrib-modbus give me values.
Problem is with net library I think.
I doubt the net library is a problem (thats node native lib)
if anything the issue is with jsmodbus or your usage.
What is wrong with using node-red-contrib-modbus anyway?
I give from database register address and Ip.
I used ModbusFlexConnector from node-red-contrib-modbus and it's work, but it very slow for many values.
Are you reading values individually or are you reading more than one at a time?
Indyvidually and packages. I have about 20 IP devices and about 100 register for each.
Are the registers spread out or near each other?
The point I am getting to is...
  • If (for example) you request MB registers 11, 13, 15, 44, 66, 68, 69, 70, 80, 88, 101 ~ 130, 150~189 as 12 reads - that is much more expensive than requesting 2 reads of 10~99 and 100~189
Yes, but sometimes is situation that 11,13 but register 12 doesn't exist.
I must have refresh time 1-5 second for all points. If I have many
obraz block it's ok, but with that
obraz I must use delay.
I have something like this
It's not all.
I have table when I set value to devices by modbus. Before I used php, but now, I try to move to node-red :slight_smile:
Do you mean that if the device does not have a register 12 that the communication fails?
To be more precise...
If you requested 3 registers starting from register 11 even though you don't need register 12, does the modbus communication work or does it fail?
Fail, or I waiting as timeout finish. I can't use it.
Is not situation that I don't need 12 register. It give me '0' or something.
I tested that situation.
In pure js I write this and it works in node.js
const Modbus = require('jsmodbus')
const net = require('net')
const socket = new net.Socket()
const client = new Modbus.client.TCP(socket, 1)
const options = {
'host' : '10.0.0.66',
'port' : 502
//const client = new modbus.client.TCP(socket)
socket.on('connect', function () {
  client.readHoldingRegisters(8737, 4)
    .then(function (resp) {
      console.log(resp.response._body.valuesAsArray)
      socket.end()
    }).catch(function () {
      console.error(require('util').inspect(arguments, {
        depth: null
      socket.end()
socket.on('error', console.error)
Ok understand.
Can you share your flow and some sample data (capture the payload from your database debug node & paste it into an inject node) so I can simulate your issue.
I think I know your issue with the contrib node.
If that doesn't work, I'll help you get the function node working.
Sample with ModbusFlexConnector
[{"id":"ca6d31db8909b2f6","type":"inject","z":"13b11b04.342725","name":"","repeat":"3600","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":130,"y":1220,"wires":[["ec442f7307e32a81","acac9bff0a533975"]]},{"id":"ec442f7307e32a81","type":"function","z":"13b11b04.342725","name":"","func":"var table1 = msg.c1;\nvar query = \"SELECT delta, nazwa, host, modbus_id from temp_tid where delta>0\";\nmsg.topic = query;\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":1220,"wires":[["36ac1d98a418f21c"]]},{"id":"36ac1d98a418f21c","type":"mysql","z":"13b11b04.342725","mydb":"36c886e2.421612","name":"db","x":430,"y":1220,"wires":[["ebe864bd81c84cc5"]]},{"id":"ebe864bd81c84cc5","type":"debug","z":"13b11b04.342725","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":600,"y":1220,"wires":[]},{"id":"931f37b035f53f14","type":"modbus-flex-connector","z":"13b11b04.342725","name":"","maxReconnectsPerMinute":4,"emptyQueue":false,"showStatusActivities":true,"showErrors":false,"server":"5cac7a09.32364c","x":630,"y":1320,"wires":[["bb18a1e21ba1d629"]]},{"id":"c4ae37ebd438db19","type":"modbus-flex-sequencer","z":"13b11b04.342725","name":"sequencer 1","sequences":[{"name":"1","unitid":"1","fc":"FC4","address":"10009","quantity":"1"}],"server":"5cac7a09.32364c","showStatusActivities":true,"showErrors":true,"logIOActivities":false,"useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"keepMsgProperties":false,"x":1010,"y":1320,"wires":[["bc2bc1764d1916c2","e12b723b657d0bcb"],[]]},{"id":"bc2bc1764d1916c2","type":"debug","z":"13b11b04.342725","name":"output","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1170,"y":1320,"wires":[]},{"id":"bb18a1e21ba1d629","type":"delay","z":"13b11b04.342725","name":"","pauseType":"delay","timeout":"9","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":840,"y":1320,"wires":[["c4ae37ebd438db19"]]},{"id":"52b1389934190985","type":"function","z":"13b11b04.342725","name":"f1","func":"var devices1 =[{\"delta\":1,\"nazwa\":\"ED_9373\",\"host\":\"10.0.0.202\",\"modbus_id\":8},{\"delta\":2,\"nazwa\":\"ED_9376\",\"host\":\"10.0.0.132\",\"modbus_id\":2},{\"delta\":3,\"nazwa\":\"ED_9377\",\"host\":\"10.0.0.201\",\"modbus_id\":4},{\"delta\":4,\"nazwa\":\"ED_9375\",\"host\":\"10.0.0.203\",\"modbus_id\":9},{\"delta\":5,\"nazwa\":\"ED_9379\",\"host\":\"10.0.0.204\",\"modbus_id\":5},{\"delta\":6,\"nazwa\":\"ED_9374\",\"host\":\"10.0.0.203\",\"modbus_id\":3},{\"delta\":8,\"nazwa\":\"ED_9380\",\"host\":\"10.0.0.202\",\"modbus_id\":7},{\"delta\":9,\"nazwa\":\"ED_9381\",\"host\":\"10.0.0.203\",\"modbus_id\":6},{\"delta\":7,\"nazwa\":\"ED_9378\",\"host\":\"10.0.0.131\",\"modbus_id\":10}];\nvar devices = msg.payload;\n\n\ndevices.forEach(dev => {\n\n   node.send({\n      \"topic\": dev.nazwa,\n      \"payload\": {\n         \"connectorType\" : \"TCP\",\n         \"tcpHost\": dev.host,\n         \"tcpPort\": \"502\",\n         \"unitId\": dev.modbus_id\n      },\n      \"sequences\": [\n    {\n        name: dev.host,\n        unitid: dev.modbus_id,\n        fc: 4,\n        address: 10009,\n        quantity: 1\n    }\n    ]\n   });\n\n})\n\n\n\nreturn null;","outputs":1,"noerr":0,"x":230,"y":1320,"wires":[["589fdf93fe8d790d","297df7472b57f343"]]},{"id":"589fdf93fe8d790d","type":"debug","z":"13b11b04.342725","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":410,"y":1360,"wires":[]},{"id":"297df7472b57f343","type":"delay","z":"13b11b04.342725","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"10","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":400,"y":1320,"wires":[["931f37b035f53f14"]]},{"id":"e12b723b657d0bcb","type":"function","z":"13b11b04.342725","name":"","func":"var table = 'alarmy';\nvar bat = msg.payload[0];\nvar modbus_id = msg.unitId;\nvar query = '';\n\n\nquery= `UPDATE temp_tid set bat = ${bat} WHERE modbus_id= ${modbus_id};`;\n\n\nmsg.query = query;\nmsg.topic = query;\n\n\nreturn msg;\n\n\n\n\n","outputs":1,"noerr":0,"x":1020,"y":1400,"wires":[["9cba012d79a7d3e1"]]},{"id":"9cba012d79a7d3e1","type":"mysql","z":"13b11b04.342725","mydb":"36c886e2.421612","name":"db","x":1150,"y":1400,"wires":[[]]},{"id":"59dd46656ff38922","type":"comment","z":"13b11b04.342725","name":"json","info":"[{\"delta\":1,\"nazwa\":\"ED_9373\",\"host\":\"192.168.98.201\",\"modbus_id\":8},{\"delta\":2,\"nazwa\":\"ED_9376\",\"host\":\"192.168.98.203\",\"modbus_id\":2},{\"delta\":3,\"nazwa\":\"ED_9377\",\"host\":\"192.168.98.202\",\"modbus_id\":4},{\"delta\":4,\"nazwa\":\"ED_9375\",\"host\":\"192.168.98.203\",\"modbus_id\":9},{\"delta\":5,\"nazwa\":\"ED_9379\",\"host\":\"192.168.98.204\",\"modbus_id\":5},{\"delta\":6,\"nazwa\":\"ED_9374\",\"host\":\"192.168.98.203\",\"modbus_id\":4},{\"delta\":8,\"nazwa\":\"ED_9380\",\"host\":\"192.168.98.202\",\"modbus_id\":7},{\"delta\":9,\"nazwa\":\"ED_9381\",\"host\":\"192.168.1.132\",\"modbus_id\":6},{\"delta\":7,\"nazwa\":\"ED_9378\",\"host\":\"10.0.0.1\",\"modbus_id\":10}]","x":770,"y":1220,"wires":[]},{"id":"acac9bff0a533975","type":"function","z":"13b11b04.342725","name":"","func":"msg.payload = [{\"delta\":1,\"nazwa\":\"ED_9373\",\"host\":\"192.168.98.201\",\"modbus_id\":8},{\"delta\":2,\"nazwa\":\"ED_9376\",\"host\":\"192.168.98.203\",\"modbus_id\":2},{\"delta\":3,\"nazwa\":\"ED_9377\",\"host\":\"192.168.98.202\",\"modbus_id\":4},{\"delta\":4,\"nazwa\":\"ED_9375\",\"host\":\"192.168.98.203\",\"modbus_id\":9},{\"delta\":5,\"nazwa\":\"ED_9379\",\"host\":\"192.168.98.204\",\"modbus_id\":5},{\"delta\":6,\"nazwa\":\"ED_9374\",\"host\":\"192.168.98.203\",\"modbus_id\":4},{\"delta\":8,\"nazwa\":\"ED_9380\",\"host\":\"192.168.98.202\",\"modbus_id\":7},{\"delta\":9,\"nazwa\":\"ED_9381\",\"host\":\"192.168.1.132\",\"modbus_id\":6},{\"delta\":7,\"nazwa\":\"ED_9378\",\"host\":\"10.0.0.1\",\"modbus_id\":10}];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":100,"y":1320,"wires":[["52b1389934190985"]]},{"id":"36c886e2.421612","type":"MySQLdatabase","name":"","host":"localhost","port":"3306","db":"chema","tz":"","charset":"UTF8"},{"id":"5cac7a09.32364c","type":"modbus-client","name":"","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.98.203","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"0","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":false,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true}]
Sample with Modbus Read
[{"id":"7eef272d35972c7e","type":"modbus-read","z":"6dc680ce450d84b1","name":"","topic":"","showStatusActivities":true,"logIOActivities":false,"showErrors":true,"unitid":"","dataType":"HoldingRegister","adr":"8637","quantity":"100","rate":"1","rateUnit":"h","delayOnStart":false,"startDelayTime":"","server":"81dd93cb.5ed208","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":true,"x":450,"y":360,"wires":[["5b58d539eec7b040"],[]]},{"id":"5b58d539eec7b040","type":"debug","z":"6dc680ce450d84b1","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":640,"y":360,"wires":[]},{"id":"81dd93cb.5ed208","type":"modbus-client","name":"10.0.0.151","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"10.0.0.151","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","serialAsciiResponseStartDelimiter":"","unit_id":"1","commandDelay":"1","clientTimeout":"10000","reconnectOnTimeout":true,"reconnectTimeout":"20000","parallelUnitIdsAllowed":true}]
If some register not exist's I have error
obraz
On that example, you are asking for 100 REG from 8637 (8637 ~ 8736) - is it not a case of going above some internal memory max location?
Or is it definitely some random unavailable address(es) inside that range?
No, I tested 4 000 register (0-99, 100-199...4000) and it was OK. Refresh time 5 sec from PLC.
Yes. Some devices has separately range like 0-10 20-30 and address 11 will give unavailable error.
