JSON array parse
Hi all,
I'm fairly new to Node-RED and totally unfamiliar with javascript. Who can help me with my code?
I'm trying to parse a WooCommerce webhook and send some information to my phone thru join (joaoapps).
I searched the web for solutions and I think i'm almost there. I found this example on stackoverflow and hacked up this little code on https://js.do/code/json_iteration.
This displays the result what i'm looking for.
When i'm trying to translate this into Node-RED, i'm only getting the last part (Book D) of the array.
Here's my flow code:
        "id": "cc4c4710.0e42f8",
        "type": "tab",
        "label": "Flow 1",
        "disabled": false,
        "info": ""
        "id": "6b97b4d9.508d9c",
        "type": "inject",
        "z": "cc4c4710.0e42f8",
        "name": "Test JSON inject",
        "topic": "",
        "payload": "{\"status\":\"completed\",\"total\":\"80.50\",\"line_items\":[{\"name\":\"Book A\",\"quantity\":1},{\"name\":\"Book B\",\"quantity\":2},{\"name\":\"Book C\",\"quantity\":3},{\"name\":\"Book D\",\"quantity\":4}]}",
        "payloadType": "json",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 240,
        "y": 160,
                "71becfa3.e7d4b"
        "id": "71becfa3.e7d4b",
        "type": "switch",
        "property": "payload.status",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "completed",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 1,
        "x": 250,
        "y": 260,
                "b082823.37b478"
        "id": "b082823.37b478",
        "type": "function",
        "name": "Message format",
        "func": "var arr = msg.payload.line_items;\n\nfor (var i = 0; i < arr.length; i++){\n    var obj = arr[i];\n    book = (\"\\n What: \" + obj.name);\n    amount = (\"\\n How many: \" + obj.quantity);\n}\n\nmoney = msg.payload.total;\nmsg.title = \"Books sold!\";\nmsg.text = book + amount + \"\\n\\n Total money earned: \" + money\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "x": 260,
        "y": 360,
                "49943e66.fc353"
        "id": "49943e66.fc353",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "x": 270,
        "y": 460,
The WooCommerce JSON output is redacted of course, and the switch node is there to only display when a order is completed.
I think my for loop is wrong because of my book and amount variable being overwritten by each iteration :thinking:
But how can I fix this? Just thinking out loud here :upside_down_face:
In the loop, create your output
I'm a bit further by putting the values in a new array.
var newMsg = [];
    var obj = arr[i];
    newMsg.push("\n What: " + obj.name + "\n How many: " + obj.quantity);
msg.title = "Books sold!";
msg.text = newMsg;
This will show all the books in the msg.text but I think join doesn't support a object or array. So now I need to turn it into a string to work I guess. :thinking:
try this
var output = ''
    var obj = arr[i];
    output += ("\n What: " + obj.name);
    output += ("\n How many: " + obj.quantity);
output += "\n\n Total money earned: " + money
msg.text = output
I think I got it fixed :smiley:
I converted newMsg.toString() and now it shows up on join
Working code here:
var newMsg = [];
    var obj = arr[i];
var convMsg = newMsg.toString();
msg.text = convMsg;
If there's a better or easier way, please do tell. For now i'm excited it works.
Sorry for thinking out loud here :crazy_face:
Sorry just saw your proposal now. Will test that as well :slightly_smiling_face:
There is always multiple ways to solve a problem :grin:
I chose your solution because it looks neater and no conversion toString is needed :wink:
Thank you for looking at my code and your proposal :+1:t3:
P.S. I marked your reply as the solution
