Json Schema Holistic Validator node no longer throws exception?
Have updated Json Schema Holistic Validator node a while back, but noticed today it has more options and behaves differently. It has strict mode which is nice to validate json schema and a button to auto-generate documentation based on current schema. But it seems to no longer throw exception on validation error? At least that behavior doesn't trigger here. But it has option to output invalid message, but that seems to counter the whole point of making this separate node with single input + throw, instead of original with 2 outputs (success/fail). Now I need to add a 2nd node afterwards and add manual switch, not to mention having to duplicate this logic on every use. As such, I might as well wrap it in subflow and revert to 2 outputs haha.
Anyone else get exceptions here?
Source (not sure if it is gregoriusrippenstein or gorenje or whatever):
What exactly is the example flow?
I think the last time I updated the validator node was 4 months ago if you're using mine. I'm still using it and it does what it's meant to do.
Remember that you also might be using the original version that I forked in creating my version.
I might well have changed the functionality of the original, so that exception creation I might not be doing. So if you switched from one to the other, expect different behaviour.
Ok thanks for reply. Palette manager shows @gregoriusrippenstein/node-red-contrib-validation-and-documentation.
Now I have v0.2.1. I used to have 0.1.2 last year. Do you get exceptions? I don't. Example flow:
[{"id":"11d69aa45594c346","type":"JsonSchemaValidatorWithDocu","z":"098301557647add6","name":"no output exception nor output invalid","property":"foo","propertyType":"msg","checkentireobject":false,"func":"{\n  \"type\": \"object\",\n  \"additionalProperties\": false,\n  \"required\": [\n    \"bar\"\n  ],\n  \"properties\": {\n    \"bar\": {\n      \"type\": \"string\"\n    }\n  }\n}","schematitle":"","strictMode":true,"removeDollarSchema":true,"sendOnInvalid":false,"x":690,"y":180,"wires":[["8dbe7a8ee1477613"]],"info":"## Untitled object in undefined Type\n\n`object` ([Details](definition.md))\n\n# Untitled object in undefined Properties\n\n| Property              | Type     | Required | Nullable       | Defined by        |\n| :-------------------- | :------- | :------- | :------------- | :-------------------------------------------------------------------------------- |\n| [params](#params)     | `object` | Required | cannot be null | [Untitled schema](definition-properties-params.md \"undefined#/properties/params\") |\n| Additional Properties | Any      | Optional | can be null    |        |\n\n## params\n\n\n\n`params`\n\n* is required\n\n* Type: `object` ([Details](definition-properties-params.md))\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params.md \"undefined#/properties/params\")\n\n### params Type\n\n`object` ([Details](definition-properties-params.md))\n\n## Additional Properties\n\nAdditional properties are allowed and do not have to follow a specific schema\n\n---\n## params Type\n\n`object` ([Details](definition-properties-params.md))\n\n# params Properties\n\n| Property      | Type     | Required | Nullable       | Defined by        |\n| :------------ | :------- | :------- | :------------- | :---------------------------------------------------------------------------------------------------------------- |\n| [data](#data) | `object` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data.md \"undefined#/properties/params/properties/data\") |\n\n## data\n\n\n\n`data`\n\n* is required\n\n* Type: `object` ([Details](definition-properties-params-properties-data.md))\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data.md \"undefined#/properties/params/properties/data\")\n\n### data Type\n\n`object` ([Details](definition-properties-params-properties-data.md))\n\n---\n## data Type\n\n`object` ([Details](definition-properties-params-properties-data.md))\n\n# data Properties\n\n| Property                | Type     | Required | Nullable       | Defined by        |\n| :---------------------- | :------- | :------- | :------------- | :---------------------------------------------------------------------------------------------------------------------------------------------------------- |\n| [buildings](#buildings) | `array`  | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-buildings.md \"undefined#/properties/params/properties/data/properties/buildings\") |\n| [range](#range)         | `object` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-range.md \"undefined#/properties/params/properties/data/properties/range\")         |\n| [timezone](#timezone)   | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-timezone.md \"undefined#/properties/params/properties/data/properties/timezone\")   |\n\n## buildings\n\n\n\n`buildings`\n\n* is required\n\n* Type: `object[]` ([Details](definition-properties-params-properties-data-properties-buildings-items.md))\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-buildings.md \"undefined#/properties/params/properties/data/properties/buildings\")\n\n### buildings Type\n\n`object[]` ([Details](definition-properties-params-properties-data-properties-buildings-items.md))\n\n## range\n\n\n\n`range`\n\n* is required\n\n* Type: `object` ([Details](definition-properties-params-properties-data-properties-range.md))\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-range.md \"undefined#/properties/params/properties/data/properties/range\")\n\n### range Type\n\n`object` ([Details](definition-properties-params-properties-data-properties-range.md))\n\n## timezone\n\n\n\n`timezone`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-timezone.md \"undefined#/properties/params/properties/data/properties/timezone\")\n\n### timezone Type\n\n`string`\n\n---\n## buildings Type\n\n`object[]` ([Details](definition-properties-params-properties-data-properties-buildings-items.md))\n\n---\n## items Type\n\n`object` ([Details](definition-properties-params-properties-data-properties-buildings-items.md))\n\n# items Properties\n\n| Property        | Type     | Required | Nullable       | Defined by        |\n| :-------------- | :------- | :------- | :------------- | :-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- |\n| [id](#id)       | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-id.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/id\")       |\n| [name](#name)   | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-name.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/name\")   |\n| [label](#label) | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-label.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/label\") |\n\n## id\n\n\n\n`id`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-id.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/id\")\n\n### id Type\n\n`string`\n\n## name\n\n\n\n`name`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-name.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/name\")\n\n### name Type\n\n`string`\n\n## label\n\n\n\n`label`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-label.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/label\")\n\n### label Type\n\n`string`\n\n---\n## id Type\n\n`string`\n\n---\n## name Type\n\n`string`\n\n---\n## label Type\n\n`string`\n\n---\n## range Type\n\n`object` ([Details](definition-properties-params-properties-data-properties-range.md))\n\n# range Properties\n\n| Property        | Type     | Required | Nullable       | Defined by        |\n| :-------------- | :------- | :------- | :------------- | :------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ |\n| [start](#start) | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-range-properties-start.md \"undefined#/properties/params/properties/data/properties/range/properties/start\") |\n| [stop](#stop)   | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-range-properties-stop.md \"undefined#/properties/params/properties/data/properties/range/properties/stop\")   |\n\n## start\n\n\n\n`start`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-range-properties-start.md \"undefined#/properties/params/properties/data/properties/range/properties/start\")\n\n### start Type\n\n`string`\n\n### start Constraints\n\n**pattern**: the string must match the following regular expression: \n\n```regexp\n^[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}$\n```\n\n[try pattern](https://regexr.com/?expression=%5E%5B0-9%5D%7B4%7D-%5B0-9%5D%7B2%7D-%5B0-9%5D%7B2%7DT%5B0-9%5D%7B2%7D%3A%5B0-9%5D%7B2%7D%24 \"try regular expression with regexr.com\")\n\n## stop\n\n\n\n`stop`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-range-properties-stop.md \"undefined#/properties/params/properties/data/properties/range/properties/stop\")\n\n### stop Type\n\n`string`\n\n### stop Constraints\n\n**pattern**: the string must match the following regular expression: \n\n```regexp\n^[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}$\n```\n\n[try pattern](https://regexr.com/?expression=%5E%5B0-9%5D%7B4%7D-%5B0-9%5D%7B2%7D-%5B0-9%5D%7B2%7DT%5B0-9%5D%7B2%7D%3A%5B0-9%5D%7B2%7D%24 \"try regular expression with regexr.com\")\n\n---\n## start Type\n\n`string`\n\n## start Constraints\n\n**pattern**: the string must match the following regular expression: \n\n```regexp\n^[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}$\n```\n\n[try pattern](https://regexr.com/?expression=%5E%5B0-9%5D%7B4%7D-%5B0-9%5D%7B2%7D-%5B0-9%5D%7B2%7DT%5B0-9%5D%7B2%7D%3A%5B0-9%5D%7B2%7D%24 \"try regular expression with regexr.com\")\n\n---\n## stop Type\n\n`string`\n\n## stop Constraints\n\n**pattern**: the string must match the following regular expression: \n\n```regexp\n^[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}$\n```\n\n[try pattern](https://regexr.com/?expression=%5E%5B0-9%5D%7B4%7D-%5B0-9%5D%7B2%7D-%5B0-9%5D%7B2%7DT%5B0-9%5D%7B2%7D%3A%5B0-9%5D%7B2%7D%24 \"try regular expression with regexr.com\")\n\n---\n## timezone Type\n\n`string`\n"},{"id":"f8bbdea4bab60c00","type":"inject","z":"098301557647add6","name":"valid","props":[{"p":"foo.bar","v":"a","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":410,"y":180,"wires":[["11d69aa45594c346"]]},{"id":"2aff4fe560f0670a","type":"inject","z":"098301557647add6","name":"invalid","props":[{"p":"foo.bar","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":410,"y":220,"wires":[["11d69aa45594c346"]]},{"id":"0b453d38f16e17a1","type":"catch","z":"098301557647add6","name":"","scope":null,"uncaught":false,"x":420,"y":340,"wires":[["fe8a0769c94c62c1"]]},{"id":"fe8a0769c94c62c1","type":"debug","z":"098301557647add6","name":"debug exception","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":620,"y":340,"wires":[]},{"id":"8dbe7a8ee1477613","type":"debug","z":"098301557647add6","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":920,"y":180,"wires":[]},{"id":"302a0ba0d3b58477","type":"JsonSchemaValidatorWithDocu","z":"098301557647add6","name":"output but no exception on invalid","property":"foo","propertyType":"msg","checkentireobject":false,"func":"{\n  \"type\": \"object\",\n  \"additionalProperties\": false,\n  \"required\": [\n    \"bar\"\n  ],\n  \"properties\": {\n    \"bar\": {\n      \"type\": \"string\"\n    }\n  }\n}","schematitle":"","strictMode":true,"removeDollarSchema":true,"sendOnInvalid":true,"x":680,"y":260,"wires":[["9774f2e26d1cf4b0"]],"info":"## Untitled object in undefined Type\n\n`object` ([Details](definition.md))\n\n# Untitled object in undefined Properties\n\n| Property              | Type     | Required | Nullable       | Defined by        |\n| :-------------------- | :------- | :------- | :------------- | :-------------------------------------------------------------------------------- |\n| [params](#params)     | `object` | Required | cannot be null | [Untitled schema](definition-properties-params.md \"undefined#/properties/params\") |\n| Additional Properties | Any      | Optional | can be null    |        |\n\n## params\n\n\n\n`params`\n\n* is required\n\n* Type: `object` ([Details](definition-properties-params.md))\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params.md \"undefined#/properties/params\")\n\n### params Type\n\n`object` ([Details](definition-properties-params.md))\n\n## Additional Properties\n\nAdditional properties are allowed and do not have to follow a specific schema\n\n---\n## params Type\n\n`object` ([Details](definition-properties-params.md))\n\n# params Properties\n\n| Property      | Type     | Required | Nullable       | Defined by        |\n| :------------ | :------- | :------- | :------------- | :---------------------------------------------------------------------------------------------------------------- |\n| [data](#data) | `object` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data.md \"undefined#/properties/params/properties/data\") |\n\n## data\n\n\n\n`data`\n\n* is required\n\n* Type: `object` ([Details](definition-properties-params-properties-data.md))\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data.md \"undefined#/properties/params/properties/data\")\n\n### data Type\n\n`object` ([Details](definition-properties-params-properties-data.md))\n\n---\n## data Type\n\n`object` ([Details](definition-properties-params-properties-data.md))\n\n# data Properties\n\n| Property                | Type     | Required | Nullable       | Defined by        |\n| :---------------------- | :------- | :------- | :------------- | :---------------------------------------------------------------------------------------------------------------------------------------------------------- |\n| [buildings](#buildings) | `array`  | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-buildings.md \"undefined#/properties/params/properties/data/properties/buildings\") |\n| [range](#range)         | `object` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-range.md \"undefined#/properties/params/properties/data/properties/range\")         |\n| [timezone](#timezone)   | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-timezone.md \"undefined#/properties/params/properties/data/properties/timezone\")   |\n\n## buildings\n\n\n\n`buildings`\n\n* is required\n\n* Type: `object[]` ([Details](definition-properties-params-properties-data-properties-buildings-items.md))\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-buildings.md \"undefined#/properties/params/properties/data/properties/buildings\")\n\n### buildings Type\n\n`object[]` ([Details](definition-properties-params-properties-data-properties-buildings-items.md))\n\n## range\n\n\n\n`range`\n\n* is required\n\n* Type: `object` ([Details](definition-properties-params-properties-data-properties-range.md))\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-range.md \"undefined#/properties/params/properties/data/properties/range\")\n\n### range Type\n\n`object` ([Details](definition-properties-params-properties-data-properties-range.md))\n\n## timezone\n\n\n\n`timezone`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-timezone.md \"undefined#/properties/params/properties/data/properties/timezone\")\n\n### timezone Type\n\n`string`\n\n---\n## buildings Type\n\n`object[]` ([Details](definition-properties-params-properties-data-properties-buildings-items.md))\n\n---\n## items Type\n\n`object` ([Details](definition-properties-params-properties-data-properties-buildings-items.md))\n\n# items Properties\n\n| Property        | Type     | Required | Nullable       | Defined by        |\n| :-------------- | :------- | :------- | :------------- | :-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- |\n| [id](#id)       | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-id.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/id\")       |\n| [name](#name)   | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-name.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/name\")   |\n| [label](#label) | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-label.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/label\") |\n\n## id\n\n\n\n`id`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-id.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/id\")\n\n### id Type\n\n`string`\n\n## name\n\n\n\n`name`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-name.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/name\")\n\n### name Type\n\n`string`\n\n## label\n\n\n\n`label`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-buildings-items-properties-label.md \"undefined#/properties/params/properties/data/properties/buildings/items/properties/label\")\n\n### label Type\n\n`string`\n\n---\n## id Type\n\n`string`\n\n---\n## name Type\n\n`string`\n\n---\n## label Type\n\n`string`\n\n---\n## range Type\n\n`object` ([Details](definition-properties-params-properties-data-properties-range.md))\n\n# range Properties\n\n| Property        | Type     | Required | Nullable       | Defined by        |\n| :-------------- | :------- | :------- | :------------- | :------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ |\n| [start](#start) | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-range-properties-start.md \"undefined#/properties/params/properties/data/properties/range/properties/start\") |\n| [stop](#stop)   | `string` | Required | cannot be null | [Untitled schema](definition-properties-params-properties-data-properties-range-properties-stop.md \"undefined#/properties/params/properties/data/properties/range/properties/stop\")   |\n\n## start\n\n\n\n`start`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-range-properties-start.md \"undefined#/properties/params/properties/data/properties/range/properties/start\")\n\n### start Type\n\n`string`\n\n### start Constraints\n\n**pattern**: the string must match the following regular expression: \n\n```regexp\n^[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}$\n```\n\n[try pattern](https://regexr.com/?expression=%5E%5B0-9%5D%7B4%7D-%5B0-9%5D%7B2%7D-%5B0-9%5D%7B2%7DT%5B0-9%5D%7B2%7D%3A%5B0-9%5D%7B2%7D%24 \"try regular expression with regexr.com\")\n\n## stop\n\n\n\n`stop`\n\n* is required\n\n* Type: `string`\n\n* cannot be null\n\n* defined in: [Untitled schema](definition-properties-params-properties-data-properties-range-properties-stop.md \"undefined#/properties/params/properties/data/properties/range/properties/stop\")\n\n### stop Type\n\n`string`\n\n### stop Constraints\n\n**pattern**: the string must match the following regular expression: \n\n```regexp\n^[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}$\n```\n\n[try pattern](https://regexr.com/?expression=%5E%5B0-9%5D%7B4%7D-%5B0-9%5D%7B2%7D-%5B0-9%5D%7B2%7DT%5B0-9%5D%7B2%7D%3A%5B0-9%5D%7B2%7D%24 \"try regular expression with regexr.com\")\n\n---\n## start Type\n\n`string`\n\n## start Constraints\n\n**pattern**: the string must match the following regular expression: \n\n```regexp\n^[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}$\n```\n\n[try pattern](https://regexr.com/?expression=%5E%5B0-9%5D%7B4%7D-%5B0-9%5D%7B2%7D-%5B0-9%5D%7B2%7DT%5B0-9%5D%7B2%7D%3A%5B0-9%5D%7B2%7D%24 \"try regular expression with regexr.com\")\n\n---\n## stop Type\n\n`string`\n\n## stop Constraints\n\n**pattern**: the string must match the following regular expression: \n\n```regexp\n^[0-9]{4}-[0-9]{2}-[0-9]{2}T[0-9]{2}:[0-9]{2}$\n```\n\n[try pattern](https://regexr.com/?expression=%5E%5B0-9%5D%7B4%7D-%5B0-9%5D%7B2%7D-%5B0-9%5D%7B2%7DT%5B0-9%5D%7B2%7D%3A%5B0-9%5D%7B2%7D%24 \"try regular expression with regexr.com\")\n\n---\n## timezone Type\n\n`string`\n"},{"id":"a8f3f5a124949e68","type":"inject","z":"098301557647add6","name":"valid","props":[{"p":"foo.bar","v":"a","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":410,"y":260,"wires":[["302a0ba0d3b58477"]]},{"id":"be81f3cd67ce0d1f","type":"inject","z":"098301557647add6","name":"invalid","props":[{"p":"foo.bar","v":"1","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":410,"y":300,"wires":[["302a0ba0d3b58477"]]},{"id":"9774f2e26d1cf4b0","type":"debug","z":"098301557647add6","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":920,"y":260,"wires":[]},{"id":"0a1ca32476f72209","type":"global-config","env":[],"modules":{"@gregoriusrippenstein/node-red-contrib-validation-and-documentation":"0.2.1"}}]
According to the documentation it says:
Unlike the original, instead of two outputs this has only one. Previously the two outputs where used to diverge messages that where valid and those that weren't. Instead this throws an exception that can be caught if validation fails. For the author this makes more sense since a validation that fails represents an unknown state of the system, likely to cause failure - fail fast, fail early is the motto.
Looking at 0.1.2, that also had one output and threw an exception. I.e. the comment has always been there, so I made that change with just one output right from the beginning.
But having a look at this change made from 0.2.0 to 0.2.1, it seems like the done with the error message was removed and therefore no exception is raised. That's because I added the "send on invalid" option, i.e. send a message if invalid, else do nothing.
I'll fix that so that the exception is generated if the "send on invalid" option isn't set, i.e., the default behaviour before 0.2.1.
That will be version 0.2.2. I'll post here once it's out (should be later today).
Thanks for the test flow, I'll use that to test the change.
Glorious, thanks! I also enjoyed the other new options but it was a little bit difficult to understand what they meant. However with some AI assistance I figured it out.
Ok, v0.2.2 is out. I don't know how long the NR catalogue will take to update, i.e., how long until the version is shown in the palette manager.
I even had tests for this this stuff! I'm just straighten those out for future reference.
Thanks for the feedback :+1:
