JSON to xml code
Hi There,
I have the following example XML code:
 <?xml version="1.0" encoding="UTF-8"?>
<RequestCall>
     <RequestName>TestDBUser.Insert</RequestName>
     <Params>
<TestDBUser>
 <ExtUserID>33333</ExtUserID>
 <FirstName>Peter</FirstName>
 <LastName>NodeRed</LastName>
 <Title>Mr</Title>
 <UserExpiration.Enabled> 1 </UserExpiration.Enabled>
 <UserExpiration> 2025-01-31 </UserExpiration>
 <KeyExpirationDifferentFromUserExpiration> 1 </KeyExpirationDifferentFromUserExpiration>
 <KeyRevalidation.UpdatePeriod> 3 </KeyRevalidation.UpdatePeriod>
 <KeyRevalidation.UnitOfUpdatePeriod>0</KeyRevalidation.UnitOfUpdatePeriod>
     </TestDBUser>
   </Params>
</RequestCall>
If I insert it in an inject node msg.payload and send it through the HTTP Request node, it works fine and creates the user in my 3rd Party system.
But I will receive the name from an other system in JSON in a msg.username payload. How Can I insert this username into my xml code to make the First and LastName dynamic?
There are multiple ways, but let's take an example inject node
Next use a template node:
there you can use 'mustache' templates, so you can create a base template in xml and fill whatever details you want.
 <FirstName>{{payload.firstname}}</FirstName>
 <LastName>{{payload.lastname}}</LastName>
Output:
<RequestCall>
     <Params>
<TestDBUser>
 <FirstName>John</FirstName>
 <LastName>Doe</LastName>
 <Title>Mr</Title>
     </TestDBUser>
   </Params>
</RequestCall>
WOW, i did not think about this, I over killed it .
Thank you very much!!!
