Hi There,
Taking this string Teiüäösß utf8 fïléñámê.m4a, encode as base64[1]: echo "Teiüäösß utf8 fïléñámê.m4a" | base64 and get this string VGVpdcyIYcyIb8yIc8OfIHV0ZjggZmnMiGxlzIFuzINhzIFtZcyCLm00YQo=
If I take the b64 string and push it through the JSONata $base64decode(..) function, I get TeiuÌaÌoÌsà utf8 fiÌleÌnÌaÌmeÌ.m4a.
Demonstrated by this flow:
[{"id":"9a543998ea22e0eb","type":"inject","z":"6378c786ada4ddc2","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"VGVpdcyIYcyIb8yIc8OfIHV0ZjggZmnMiGxlzIFuzINhzIFtZcyCLm00YQ==","payloadType":"str","x":500,"y":430,"wires":[["a56ae1312fde1caf"]]},{"id":"a56ae1312fde1caf","type":"change","z":"6378c786ada4ddc2","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$base64decode($$.payload)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":728,"y":477,"wires":[["f98636d0205a090e"]]},{"id":"f98636d0205a090e","type":"debug","z":"6378c786ada4ddc2","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1016,"y":489,"wires":[]}]
Tested with NR 4.0.9
Work around is to use the JS code NodeJS code[2] in a function node instead of using $base64decode in a change node.
[1]: can also be done using the following JS code (gives the same b64 string):
const blobToBase64 = (blob) => {
return new Promise((resolve, reject) => {
const reader = new FileReader();
reader.onloadend = () => {
const base64String = reader.result.split(',')[1]; // Remove the prefix
resolve(base64String);
reader.onerror = reject;
reader.readAsDataURL(blob); // Read the Blob as a data URL
blobToBase64(new Blob(["Teiüäösß utf8 fïléñámê.m4a"], {type: 'text/plain'})).then( base64 => console.log(base64))
[2]: NodeJS function code
msg.payload = Buffer.from(msg.payload, "base64").toString("utf-8").trim()
return msg
