JSONata: From Array of objects to array of array with appending data
So there is this input array
      "time": 1591653600,
      "level": 100
      "time": 1591657200,
      "level": 110
To each array content there should be appended { "tag" : "east" }, so that we get an array of arrays and it looks like
      "time": 1591653600,
      "level": 100
      "tag": "east"
      "time": 1591657200,
      "level": 110
      "tag": "east"
Since the real object contains much more key/value pairs than time and level I need a general solution.
I've tried
        "tag": "east"
But this adds the tag only once in the end and doesn't create a real array of arrays.
You can try at https://try.jsonata.org/Dfz2Antml
Try this....
$map(payload, function($v) {
        $v,
        { "tag": "east" }
I think the following jsonata query does the job:
      "tag": "east"
Thanks. Both provided solutions work. Here in this case it is "$" instead of payload, but in NodeRED than payload is the right term
$map($, function($v) {
        $v,
        { "tag": "east" }
For the interested: I like understanding what I'm doing so I've looked it up. The second solution, which I marked as solution is basically the same as short term for "$map" and the function as filter
