Hello everbody,
i have a number messages which are the result of a split node. I want to use the parts.index property of this messages to set the message topics. I try to do it by a change node with the follwing JSONata code:
"/dio/" & $string($flowContext("Pins")[0][(parts.index)]) & "/value"
The flow variable Pins looks like:
Pins = [
[11,12,13,14],
[21,22,23,24]
If I replace (parts.index) with an number it works (I get the correct topic with the pin nummer looked up in Pins). If set the JSONata to parts.index only, it works, too (I get the split index as topic). But if put it together, it doesn't work. What did I miss.
Thanks for any suggestions.
L4rs
