Keep data on multiple series with different axis to chart
Hi all,
I want to adding multiple series with different axis to chart. And I find the info that I want from post: 38591/5. It's excellent.
Thanks hotNipi.
The code in post:
[{"id":"26d66b9b.186034","type":"ui_template","z":"82bb9cb4.29b64","group":"304730.1de8e8d","name":"Line Chart","order":4,"width":"15","height":"10","format":"","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":710,"y":300,"wires":[[]]},{"id":"29e44bca.6d2594","type":"inject","z":"82bb9cb4.29b64","name":"","repeat":"5","crontab":"","once":false,"onceDelay":"0.62","topic":"","payload":"","payloadType":"date","x":350,"y":270,"wires":[["98fd0130.0550d"]]},{"id":"98fd0130.0550d","type":"function","z":"82bb9cb4.29b64","name":"fake live data","func":"msg.payload = {}\nmsg.payload.first = Math.random() * 300\nmsg.payload.second = -2.5 + Math.random() * 5\nreturn msg;\n","outputs":1,"noerr":0,"x":510,"y":270,"wires":[["26d66b9b.186034"]]},{"id":"55e9c5a5.e31f0c","type":"template","z":"82bb9cb4.29b64","name":"","field":"template","fieldType":"msg","format":"html","syntax":"mustache","template":"<canvas id=\"myChart\" width=600 height =300></canvas>\n<script>\nvar textcolor = getComputedStyle(document.documentElement).getPropertyValue('--nr-dashboard-widgetTextColor');\nvar gridcolor = getComputedStyle(document.documentElement).getPropertyValue('--nr-dashboard-groupBorderColor');\nvar linecolors = ['#009900','#889900']\nvar maxDataPoints = 20\n\nvar ctx = document.getElementById('myChart').getContext('2d');\nvar chart = new Chart(ctx, {\n    // The type of chart we want to create\n    type: 'line',\n\n    // The data for our dataset\n    data: {\n        labels: [],\n        datasets: [\n            {\n                label: 'first',\n                backgroundColor: linecolors[0],\n                borderColor: linecolors[0],\n                data: [],\n                yAxisID: 'left-y-axis',\n                steppedLine: true,\n                fill: false,\n                borderWidth: 1\n            },\n            {\n                label: 'second',\n                backgroundColor: linecolors[1],\n                borderColor: linecolors[1],\n                data: [],\n                yAxisID: 'right-y-axis',\n                steppedLine: false,\n                fill: false,\n                borderWidth: 1\n            }\n        ]\n    },\n\n    // Configuration options go here\n    options: {\n        scales: {\n            yAxes: [\n                {\n                    gridLines :{display:false},\n                    id: 'left-y-axis',\n                    type: 'linear',\n                    position: 'left',\n                    ticks: {\n                        fontColor: linecolors[0]\n                    }\n                },\n                {\n                    gridLines :{zeroLineColor:gridcolor,color:gridcolor,lineWidth:0.5},\n                    id: 'right-y-axis',\n                    type: 'linear',\n                    position: 'right',\n                    ticks: {\n                        fontColor:linecolors[1]\n                    }\n                }\n            ],\n            xAxes: [\n                {\n                    gridLines :{zeroLineColor:gridcolor,color:gridcolor,lineWidth:0.5},\n                    type: 'time',\n                    distribution: 'series',\n                    time:{\n                        displayFormats: {\n                            quarter: 'MMM YYYY',\n                            millisecond:'h:mm:ss',\n                            second:\t'h:mm:ss',\n                            minute:\t'h:mm',\n                            hour:\t'h'                        \n                        }\n                    },\n                    \n                    ticks: {\n                        fontColor:textcolor\n                    }\n                }\n            ]\n        }\n    }\n});\nfunction addData(chart, data, label) {\n    chart.data.datasets.forEach((dataset) => {\n        if(dataset.label == label){\n            dataset.data.push(data);\n        }\n        if(dataset.data.length > maxDataPoints){\n            dataset.data.shift()\n        }\n    });\n    chart.update(0);//0 means no animation\n}\n(function(scope) {\n  scope.$watch('msg', function(msg) {\n    if (msg) {\n      // Do something when msg arrives\n      addData(chart,{x:new Date(),y:msg.payload.first},\"first\")\n      addData(chart,{x:new Date(),y:msg.payload.second},\"second\")\n\n    }\n  });\n})(scope);\n</script>\n","output":"str","x":500,"y":330,"wires":[["26d66b9b.186034"]]},{"id":"bf7ecf9e.8f61f","type":"inject","z":"82bb9cb4.29b64","name":"","repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":350,"y":330,"wires":[["55e9c5a5.e31f0c"]]},{"id":"304730.1de8e8d","type":"ui_group","name":"Chart","tab":"ebf9c239.14c15","order":3,"disp":true,"width":"15","collapse":false},{"id":"ebf9c239.14c15","type":"ui_tab","name":"Ovens","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
But I find that the chart data will reset after I go to other tab and come back tab:Ovens. I have no idea how to keep/continue chart data after I come back Ovens tab. How to solve it?
Thanks.
I think you can find the solution from this thread. (post 24)
SteppedLine Chart together with Line Chart
Thanks hotNipi.
It works fine as my expectation.
