Keep state of sensor
Hi
I have a contact sensor, that tell me if something stop the rollercoaster from shutting down.
I want to add, that send the command on the right, only if other sensor is closed
However, That other sensor report to MQTT, and I cannot query MQTT for current state. I need to keep that as a variable or flag, that I can query during my flow.
How can I achieve that functionality ?
You could use a change node to store the state in a flow variable, when a message comes from MQTT.
Then in a switch node check the value of the flow var.
