I was able to implement a system similar to your example. It includes panel nodes and some information about the time and date of the maximum and minimum records.
The flow is attached:
[{"id":"8a137bbe.92b958","type":"change","z":"cfbb6e4f.6526a","name":"","rules":[{"t":"set","p":"max","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1170,"y":160,"wires":[["4b392913.b6cd48"]]},{"id":"a638cb2f.c87ac8","type":"ui_button","z":"cfbb6e4f.6526a","name":"","group":"cf817aa5.c91f38","order":5,"width":8,"height":1,"passthru":false,"label":"Reset - Valor máximo","tooltip":"","color":"","bgcolor":"","icon":"","payload":"-1","payloadType":"num","topic":"","x":960,"y":160,"wires":[["8a137bbe.92b958"]]},{"id":"a14d793c.ec4b88","type":"ui_text","z":"cfbb6e4f.6526a","group":"cf817aa5.c91f38","order":1,"width":3,"height":1,"name":"valor max","label":"","format":"{{msg.payload}}","layout":"row-left","x":1440,"y":180,"wires":[]},{"id":"3d26ea37.f552b6","type":"switch","z":"cfbb6e4f.6526a","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gt","v":"max","vt":"flow"},{"t":"lt","v":"min","vt":"flow"}],"checkall":"true","repair":false,"outputs":2,"x":1030,"y":200,"wires":[["8a137bbe.92b958"],["1377db47.ec6675"]]},{"id":"4b392913.b6cd48","type":"function","z":"cfbb6e4f.6526a","name":"","func":"if(msg.payload == -1)\n{\n msg.payload = \"-\"\n}else\n{\n msg.payload = msg.payload + \" cm \"\n}\nreturn msg;","outputs":1,"noerr":0,"x":1310,"y":160,"wires":[["a14d793c.ec4b88","17c6fe5d.7c1092"]]},{"id":"17c6fe5d.7c1092","type":"simpletime","z":"cfbb6e4f.6526a","name":"Data/hora","x":1440,"y":140,"wires":[["8d7fc11.652a84"]]},{"id":"8d7fc11.652a84","type":"function","z":"cfbb6e4f.6526a","name":"Composição data/hora","func":"var a = \"(\"+msg.mydom+\"/\"+msg.mymonthn+\"/\"+msg.myyear+ \" - \" +msg.mytimes+\")\";\nmsg.payload = a;\nreturn msg;","outputs":1,"noerr":0,"x":1640,"y":140,"wires":[["57f633dc.17b0fc"]]},{"id":"57f633dc.17b0fc","type":"ui_text","z":"cfbb6e4f.6526a","group":"cf817aa5.c91f38","order":2,"width":5,"height":1,"name":"Data/horário max","label":"","format":"{{msg.payload}}","layout":"row-left","x":1650,"y":180,"wires":[]},{"id":"1377db47.ec6675","type":"change","z":"cfbb6e4f.6526a","name":"","rules":[{"t":"set","p":"min","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1170,"y":240,"wires":[["d99940c4.a82bf"]]},{"id":"9e8de5b.9ed3318","type":"ui_button","z":"cfbb6e4f.6526a","name":"","group":"cf817aa5.c91f38","order":6,"width":8,"height":1,"passthru":false,"label":"Reset - Valor mínimo","tooltip":"","color":"","bgcolor":"","icon":"","payload":"10000","payloadType":"num","topic":"","x":960,"y":240,"wires":[["1377db47.ec6675"]]},{"id":"d99940c4.a82bf","type":"function","z":"cfbb6e4f.6526a","name":"","func":"if(msg.payload == 10000)\n{\n msg.payload = \"-\"\n}else\n{\n msg.payload = msg.payload + \" cm \"\n}\nreturn msg;","outputs":1,"noerr":0,"x":1310,"y":240,"wires":[["105c2154.24f3cf","366a70a1.6a146"]]},{"id":"105c2154.24f3cf","type":"ui_text","z":"cfbb6e4f.6526a","group":"cf817aa5.c91f38","order":3,"width":3,"height":1,"name":"valor min","label":"","format":"{{msg.payload}}","layout":"row-left","x":1440,"y":260,"wires":[]},{"id":"366a70a1.6a146","type":"simpletime","z":"cfbb6e4f.6526a","name":"Data/hora","x":1440,"y":220,"wires":[["df36bba2.63e798"]]},{"id":"df36bba2.63e798","type":"function","z":"cfbb6e4f.6526a","name":"Composição data/hora","func":"var a = \"(\"+msg.mydom+\"/\"+msg.mymonthn+\"/\"+msg.myyear+ \" - \" +msg.mytimes+\")\";\nmsg.payload = a;\nreturn msg;","outputs":1,"noerr":0,"x":1640,"y":220,"wires":[["d0f47e73.808f5"]]},{"id":"d0f47e73.808f5","type":"ui_text","z":"cfbb6e4f.6526a","group":"cf817aa5.c91f38","order":4,"width":5,"height":1,"name":"Data/horário min","label":"","format":"{{msg.payload}}","layout":"row-left","x":1650,"y":260,"wires":[]},{"id":"edf76319.1dc86","type":"function","z":"cfbb6e4f.6526a","name":"","func":"\nmsg.payload = Number(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":910,"y":200,"wires":[["3d26ea37.f552b6"]]},{"id":"cf817aa5.c91f38","type":"ui_group","z":"","name":"Valor máximo e mínimo registrados","tab":"afeb27be.73ba48","order":4,"disp":true,"width":"16","collapse":false},{"id":"afeb27be.73ba48","type":"ui_tab","z":"","name":"HC-SR04 - Distância","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
NOTE: I am Brazilian, so some terms are in Portuguese.
Thank you very much for your help and everyone who contributed in any way.
