I have installed the krakul/node-red-modbus-rtu-slave pakage on my raspi with node-red version 3.0.2,
I need to write a response on the following request.
The modbus-rtu-writer in the pakage can only write one value,.but i need a response with 6 registers.
Setting the registers separately does not work.
Request from my inverter:
msg : Object
object
payload: "ModbusRTURequest {↵ _address: 1,↵ _body: ReadInputRegistersRequestBody { _fc: 4, _start: 12, _count: 6 },↵ _corrupted: false↵}"
In the help from the Modbus-RTU-Slave is written:
In order to write registers, a message with the following payload format must be passed as input:
"register": TARGET_REGISTER,
"data": [ U16, U16, U16 ]
But i dont know, how to do this. I need your help for this.
Thank you.
