Last time stamped value from array
I am using a exec block to fetch temperature and humidity from my verisure system. The output gives several timestamped values in return. I am only interested in the "newest / current" value. Is there some function I can use to filter out the latest temperature and humidity based on the time?
My flow:
The output:
br
Stian
Here's the documentation of JavaScript array. See if you find the way
https://www.w3schools.com/js/js_arrays.asp
And remember that an array can also contain arrays!
