Layout Editor dosnt work
Node Red 3.1.15
node-red-dashboard 3.6.5
when i login in to the Dashboard 2.0 the link is
192.168.96.253:3000/plugins/signalk-node-red/redApi/dashboard/page1 and it works
when i would go to the layout editor the link is
192.168.96.253:3000/dashboard/page1?edit-key=r89o1avmgwh&editor-path=plugins%2Fsignalk-node-red%2FredAdmin and it dosnt work
it works only when i edit the link to
192.168.96.253:3000/plugins/signalk-node-red/redApi/dashboard/page1?edit-key=r89o1avmgwh&editor-path=plugins%2Fsignalk-node-red%2FredAdmin
but i dont can save any editing
Error saving changes
Request failed with status code 404
Please can anyone help me.
THANKS
What are you running Node-RED embedded in?
Those are not standalone Node-RED routes, and the Dashboard editor expects to not behind a proxy that is injecting elements into the path
Welcome to the forum @Fritz1
The current release of Node-red is 4.0.8, why are you using a superceded version?
The current release of Dashboard 2 (@flowfuse/node-red-dashboard) is 1.21.0.
Dashboard 3.6.5 - looks like you also have node-red-dashboard.
This version is irrelevant to the dashboard 2 layout editor.
Thanks for your answers!
Node Red runs as a web app under a Signal K server.
The last released version is 3.1.15
i have also installed (@flowfuse/node-red-dashboard 1.21.0)
Is there another way to adjust the layout?
Thanks Fritz
The original and Dashboard 2 are totally separate. You can't use the layout editor from one dashboard on the other and the dashboard is presented at a different URL.
Because you have a packaged up version of Node-red from Signal K and they alter the URLs I can't tell which dashboard you have.
Maybe they can advise you, or perhaps someone else here is familiar with the Node-red from Signal K.
If it's the original dashboard it has a rudimentary layout editor you can access from the Dashboard sidebar
And the editor looks like this
That's what I see.
Looks a little different
That does look like dashboard 2.
I have very little experience with that layout editor, I struggle to get it to do anything.
Can I also use the old editor with the new Gauges?
Your question is ambiguous. But see this:
Thanks,
I'll use the old editor with the old gauges, maybe the Dashboard 2.0 will run with a new version.
Fritz
