Let or const with use of if statement
Which is the better method of writing JavaScript functions? 1st one uses let variable and 2nd uses a const variable.
let isRadioOn;
 if (global.get("radios").length !== 0) {
    isRadioOn = 1
 }else
   isRadioOn = 0;
or
const isRadioOn = function() {
    return 1;
 }else
   return 0;
Thanks in advance...
Honestly, if your not going to alter the value of isRadioOn after it's been evaluated,
I would go with the function method - I don't think there is much of a difference
BONUS - this is my preference so is neither right or wrong, but I tend to use arrow functions, especially if dealing with outer context
const isRadioOn = () => {
    return 1;
 } else {
    return 0;
However!
You might need to consider if using the value multiple times in your code block - therefore another run off the function methods, might yield an updated output
What about something like:
const isRadioOn = global.get("radios").length !== 0
Executed only once in the function node which is the more common use-case and returns true or false.
If you really want a numeric return:
const isRadioOn = global.get("radios").length !== 0 ? 1 : 0;
I like it. I just learned about ternary operators but the trick is know when to use it... Appreciate the schooling..
I also wanted to add that I was familiar with
and it produces a Boolean value. However the course I am taking the instructor advised they never used. That is why I did not use it.
Regards
I generally don't use it if the ternary version is longer than a standard if :slight_smile:
There is an occasional exception though. When wanting to use a const assignment, you can't do that inside an if block if you want the const outside the block. So if you don't want to use let instead, then a ternary is still useful.
