Hey it's me againš
I'm trying to put a link in the stats node.
But working with the change node and doing this
"< hef="{{msg.link}}" target="_blank" rel="noopener noreferrer">{{msg.payload}}</"a" >"
doesn't work, is that even possible?
Yes, in a change node use JSONata or use a template node
example flow
[{"id":"215c7b5140159f2d","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"link","v":"www.google.com","vt":"str"},{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"www.msn.com","payloadType":"str","x":340,"y":1400,"wires":[["496f648e34957cd7","ebe19130c9e5cdcb"]]},{"id":"496f648e34957cd7","type":"change","z":"d1395164b4eec73e","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"'< hef=\"' & $$.link & '\" target=\"_blank\" rel=\"noopener noreferrer\">' & $$.payload & '</a>'","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":1380,"wires":[["2b701357156994b7"]]},{"id":"ebe19130c9e5cdcb","type":"template","z":"d1395164b4eec73e","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"< hef=\"{{{link}}}\" target=\"_blank\" rel=\"noopener noreferrer\">{{{payload}}}</a>","output":"str","x":520,"y":1440,"wires":[["2b701357156994b7"]]},{"id":"2b701357156994b7","type":"debug","z":"d1395164b4eec73e","name":"debug 2456","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":790,"y":1340,"wires":[]}]
JSONata
'< hef="' & $$.link & '" target="_blank" rel="noopener noreferrer">' & $$.payload & '</a>'
Template mustache
< hef="{{{link}}}" target="_blank" rel="noopener noreferrer">{{{payload}}}</a>
Not a flexdash user, but i think flexdash uses R markdown
I think the html < > are replaced, so displays the full text not the href link.
You could try this
