Hi experts!
I'm using Buffer.from(xyz); in a function node and it works exactly as intended, but linter gives an error:
Buffer.from(xyz);
[msg] 'Buffer' is not defined.
How can I prevent this?
(Or: how to put ascii character 182 into a string and send it correct via tcp?)
How are you using the buffer ?
const bla = "hello" const test = Buffer.from(bla) msg.payload = test return msg;
no linting error (?)
That does give the error, assuming that you have nrlint installed.
I think it is because Buffer is a nodejs thing, not basic javascript, though I think there is an option you can select somewhere to tell it to pick up the nodjs types.
@protonmw the workaround is to open the linter panel, click the dropdown arrow against the error and select to disable that warning.
