I'd like to have a fixed list of available topics for the mqtt-in node. As far as I can see, using a subflow is not option, or maybe I am missing something.
In other words, I need that the user - upon deploying the node - has not to type in the topic but should make a choice from a dropdown list.
The mqtt-in node needs the topic hardcoded. If the topics being published have a formal format that they all abide by, you code subscribe to the main topic and then filter the results with switches.
Lets say you have 5 weather stations and you want tp pick the data from station 5. If the topics were arranged like
weatherstation/office/bme280
weatherstation/home/bme280
weatherstation/farm/ds18b20
you could subscribe to 'weatherstation/#' and you would get the data from all the stations. Then you could filter it by the second level in the topic
If you haven't read the MQTT Topics & Best Practices - MQTT Essentials: Part 5 I suggest you spend some time and read it
I have read very well the mqtt essentials, and I know that the mqtt-in need the topic hardcoded. I was just wondering if there could be a possibility not to leave this to the user, who can mistype the topic.
Is the user editing the node? or are they just using a dashboard and picking from a list.
It they are picking it from a list, you can programatically limit what gets to them.
If they are editing the node then, yup tehy can mistype the topic (heck, I've done that multiple times
This would, in my opinion, need a different node. MQTT is so flexible that adding this to the standard mqtt-in would add complexity to it that most people would not use.
The nice thing (one of many of course
) about Node-RED is that it is easy enough to create a new, more specialist node from an existing example.
You can use a subflow to do this.
- Set the mqtt-in topic to
${TOPIC} - Wrap that node in a subflow.
- Edit the subflow properties and define a property called
TOPIC. By expanding the row in the properties table, you can customise the UI for how the property will be shown. One of the options is a select box where you can predefine a set of options.
You made my day, Nick! Thank you.
