Lithium Iron accu 600 Amp bij 25,6 Volt 15 KW Battery Management System BMS node red
I am intrigued, what are you powering with this size battery array?
Good day It is not so much how much current I deliver but that it is enough for the whole night then I am about 500 w per hour if of course the sun has shone the day before so 500 w divided by the voltage around 25.6 v on average then it is on average around 20 amps greetings roger
I didn't read it properly My House At Night and When the Power Goes Out
