Live monitoring of energy usage
I wanna do a live monitoring of energy usage. my problem is that my chart is completely empty at the dashboard. Thats my code.
        "id": "36fa3994398c3c99",
        "type": "tab",
        "label": "Datenaufnahme",
        "disabled": false,
        "info": "",
        "env": []
        "id": "fb0560e6fbaf9f57",
        "type": "inject",
        "z": "36fa3994398c3c99",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "3600",
        "crontab": "",
        "once": false,
        "onceDelay": "300",
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 190,
        "y": 180,
                "a59ecdd3cf7436d4"
        "id": "a59ecdd3cf7436d4",
        "type": "function",
        "name": "Abfrage der Werte",
        "func": "\n// 🌡 Werte abrufen\nlet leistung = global.get(\"Leistung\") || 0;\n\n\n\n// 🕒 Zeitstempel generieren\nlet timestamp = new Date().toISOString();\n\n// 📄 CSV-Zeile erstellen\nmsg.payload = `${timestamp},${leistung}\\n`;\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 470,
        "y": 180,
                "c9bac3d96d3bd19e"
        "id": "c9bac3d96d3bd19e",
        "type": "file",
        "filename": "C:\\Users\\Labor\\Desktop\\messwert.csv",
        "filenameType": "str",
        "appendNewline": false,
        "createDir": true,
        "overwriteFile": "false",
        "encoding": "utf8",
        "x": 770,
        "y": 180,
        "id": "b8635a54e085e25b",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "3600",
        "crontab": "",
        "once": false,
        "onceDelay": "300",
        "topic": "",
        "payload": "",
        "x": 190,
        "y": 260,
                "853caafa45a3ed6a"
        "id": "7cb7dff101dec369",
        "type": "function",
        "name": "function 3",
        "func": "let rawData = msg.payload; // JSON-Daten\n\n// Sicherstellen, dass rawData ein Array ist\nlet dataArray = Array.isArray(rawData) ? rawData : [rawData];\n\n// Initialisiere das Dataset für den Chart\nlet dataset = {\n    labels: [],\n    series: [[]]  // Leistung\n};\n\n// Letzte 50 Werte übernehmen\nlet lastEntries = dataArray.slice(-20);\n\nlastEntries.forEach(entry => {\n    if (typeof entry === \"object\" && entry.timestamp && entry.leistung !== undefined) {\n        dataset.labels.push(entry.timestamp);  // ✅ Korrekt: Zeitstempel extrahieren\n        dataset.series[0].push(parseFloat(entry.leistung));  // ✅ Leistung\n    } else {\n        node.warn(\"⚠️ Ungültige Daten: \" + JSON.stringify(entry));\n    }\n});\n\nmsg.payload = dataset;\nreturn msg;\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 960,
        "y": 260,
                "a330ecd6d7a88ca6",
                "cda824069da2144a"
        "id": "853caafa45a3ed6a",
        "type": "file in",
        "format": "utf8",
        "chunk": false,
        "sendError": false,
        "encoding": "utf8",
        "allProps": false,
        "x": 490,
        "y": 260,
                "38f0994dc9c1ccf4"
        "id": "38f0994dc9c1ccf4",
        "type": "csv",
        "name": "csv zu JSON",
        "spec": "rfc",
        "sep": ",",
        "hdrin": "",
        "hdrout": "none",
        "multi": "mult",
        "ret": "\\r\\n",
        "temp": "timestamp,leistung,luftfeuchte,temperatur",
        "skip": "0",
        "strings": true,
        "include_empty_strings": false,
        "include_null_values": "",
        "x": 770,
        "y": 260,
                "7cb7dff101dec369"
        "id": "a330ecd6d7a88ca6",
        "type": "debug",
        "name": "debug 7",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1180,
        "y": 380,
        "id": "cda824069da2144a",
        "type": "ui_chart",
        "group": "72214d4980ae2e55",
        "order": 2,
        "width": 0,
        "height": 0,
        "label": "chart",
        "chartType": "line",
        "legend": "true",
        "xformat": "auto",
        "interpolate": "linear",
        "nodata": "",
        "dot": false,
        "ymin": "",
        "ymax": "",
        "removeOlder": 1,
        "removeOlderPoints": "",
        "removeOlderUnit": "3600",
        "cutout": 0,
        "useOneColor": false,
        "useUTC": true,
        "colors": [
            "#1f77b4",
            "#aec7e8",
            "#ff7f0e",
            "#2ca02c",
            "#98df8a",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "outputs": 1,
        "useDifferentColor": false,
        "className": "",
        "x": 1250,
        "y": 260,
        "id": "8553351e581deca0",
        "type": "ui_spacer",
        "name": "spacer",
        "order": 4,
        "width": 1,
        "height": 1
        "id": "0b082a4e23d14bae",
        "name": "spacer",
        "order": 4,
        "width": 1,
        "height": 1
        "id": "72214d4980ae2e55",
        "type": "ui_group",
        "name": "Graph",
        "tab": "7d7df438f2fb4675",
        "order": 4,
        "disp": true,
        "width": 6,
        "collapse": false,
        "className": ""
        "id": "7d7df438f2fb4675",
        "type": "ui_tab",
        "name": "Microgreens Zelt",
        "icon": "dashboard",
        "order": 7,
        "disabled": false,
        "hidden": false
This is the last debug message before the data is transferred to the chart:
{"labels":["2025-03-16T11:39:48.375Z","2025-03-16T12:39:48.395Z","2025-03-16T13:39:48.406Z","2025-03-16T14:39:48.417Z","2025-03-16T15:39:48.436Z","2025-03-16T16:39:48.451Z","2025-03-16T17:39:48.470Z","2025-03-16T18:39:48.478Z","2025-03-16T19:39:48.496Z","2025-03-16T20:39:48.513Z","2025-03-16T21:39:48.532Z","2025-03-16T22:39:48.552Z","2025-03-16T23:39:48.558Z","2025-03-17T00:39:48.572Z","2025-03-17T01:39:48.580Z","2025-03-17T02:39:48.593Z","2025-03-17T03:39:48.600Z","2025-03-17T04:39:48.613Z","2025-03-17T05:39:48.622Z","2025-03-17T06:39:48.716Z"],"series":[[324,321.8,326.8,332.2,324.7,325.1,330.4,322.4,322,66.9,65.8,66.9,67.7,65.3,68.4,66.6,64.8,65.3,68,66.4]]}
Closed due to double post, please use your original topic you can add info there or edit there postrs.
