I noticed that if i export a flow using the editor export, if i try to load the flow using the admin HTTP API (or the runtime API directly) it fails. Also, vice-versa, that is if I use the get/flow:id call with the API and save the flow to a file, then i can't import the flow using the editor import option.
I know the reason is that the 2 approaches give different JSON of the flow.
I would like to know if this is intended to be like this (maybe for some security reason?), or if it's something that should be possibly fixed in the future?
thanks
