(Locally) how to apply an updated subflow over multiple machines?
Yeah, I probably have asked before.
I have just had a lot of fun retrospectively rolling out an update of a subflow I wrote over my machines.
Is there an easier way?
I had to copy/export the new code, go to each machine, edit the subflow and paste in the new code and hook it up.
Not the worst but a bit tedious.
Keeping things LOCAL...
(Oh and keeping it simple.)
If it involves too much stuff, it may not be easy for me.
(I nearly asked again, but as I found the original post)
Sorry, but it is sort of becoming a bit more frequent in happening and I would prefer to keep things local.
I haven't done this, but I guess you could package it as a module which can then be installed into each machine and updated via npm as usual. Put in a github repository rather than publishing to npm of course since, presumably, it will only be of use to you. Packaging a Subflow as a module : Node-RED
You could do via. the following programmatically
  1. Get global flows from target.
  2. Get global flows from source.
  3. Isolate the subflow from the source global - using subflow name.
  4. Replace the subflow in target global - using sub flow name . Replace it by subflow from #3.
  5. Send back global to target
1,2,5 you use NR APIs.
3,4 function nodes.
Thanks Colin.
But reading that link I fear you are overestimating my skills.
I'm not sure what is going on with me, but I do not feel confident enough to want to go down that path. Yeah, ok, so that means what I want to do can't be done.
Such is life.
But thanks.
Hi Sandeep.
Again, I think you are giving me too much credit for intelligence.
What you wrote is (basically) a foreign language to me.
All I am seeing is words. Their meaning is unknown.
Packaging my first nodes seemed intimidating at first (still new, I just learn as I go), but it really wasn't bad, and definitely worth learning.
Thanks. When I have the energy (just sustained other high priority things) would you mind helping me get my head around it?
Yeah, absolutely. Just send a message when you got time.
Andrew, have you considered moving away from subflows?
As you have multiple node-reds, you could elect one (the important one) to be a "master" (with ONE COPY of your important nodes & functions) on a regular flow TAB.
Then using HTTP or some other transport, call the remote code.
Example...
NODE-RED1 - TAB "shared functions" (Master Flows)
HTTP IN "/calculate-colour" → <some nodes> → HTTP Response
NODE-RED2
<some nodes> → HTTP Request to "/calculate-colour" → <some nodes, use result>
NODE-RED3
NODE-RED4
This way, all you code is in one place (on NODE-RED1) - no need to update subflows in multiple places.
I'm not sure that will always work.
If that machine dies.... I have multiple points of failure because of their dependency on it.
Not sure that is a good strategy. Still thinking.
That's true. But if there is a critical part that "must always be 'up"' then it's a viable option. Since if there is a critical element to your setup, the failure of that is more critical than some globally shared functionality.
And believe me, I am having the devil's own trying to work out where this line is....
I get that I may never REALLY NEED this stuff, but my curiosity is painful at best.
I am (just now) having a big discussion about push buttons and what they say.
Do they say/display the state or do they show what will happen when they are pressed.
(Sorry. Off topic)
But it is annoying with this mind set.
