Hello all!
I have problem with timezone in Node-Red. I read a lot about this issue but cannot find the solution yet. I use opcda-read node to read out data from OPC DA server. This node gives an object about the data including id, timestamp and value. I use node-red as an interface ie. I just collect data and write into the jason file for the other application running on same pc. The problem is that the timestamp in the object is UTC and it would be good to be the local time. As this is the output of the opcda-read node I don't think so it's too easy to convert the time with some function especially in case with large number of data. I tried to add process.env.TZ = 'Europe/Budapest' to the settings.js file but there is no change. I tried this on other pc's as well with JS expression $now() both on Windows and Linux OS machines but the situation is same. Is there any chance to force locatime instead of UTC in this object?
greetz
saalty
